[petsc-users] local to global mapping for DMPlex
Matthew Knepley
knepley at gmail.com
Wed Dec 20 16:51:27 CST 2017
I'm glad it worked. Maybe I should take what you have done an abstract it
into something generally
useful for output.
Matt
On Wed, Dec 20, 2017 at 4:30 PM, Yann JOBIC <yann.jobic at univ-amu.fr> wrote:
> That's working just fine. I don't know if that could be useful for
> someone, just in case here is the methodology :
> I got the cell-vertex connectivity from the function
> DMPlexWriteTopology_Vertices_HDF5_Static of petsc/src/dm/impls/plex/plexhdf5.c.
> The interesting result is in cellIS.
> The vertex coordinates are from the function DMPlexWriteCoordinates_HDF5_Static
> of the same file. The global numering is just by adding the position of
> the vertex in the Vec + all the other ones from previous proc numbers.
> The cell global numbering is trivial : we use the function
> DMPlexGetCellNumbering.
> The global numbering is quite strange, but is consistant. Here is some
> examples, for 2x2 Cells (4 vertex per cell).
> I attach a text file for a better reading
> On 1 processor, we have :
> 6-----7-----8
> | 2 | 3 |
> 3-----4-----5
> | 0 | 1 |
> 0-----1-----2
> On 2 processors we have :
> 0-----1-----2
> | 0 | 1 |
> 6-----7-----8
> | 2 | 3 |
> 3-----4-----5
> Cells 0 and 1 are on proc 0; 2 and 3 are on proc 1.
> On 4 processors we have :
> 0-----1-----2
> | 0 | 1 |
> 7-----8-----4
> | 3 | 2 |
> 5-----6-----3
> On cell per proc : cell 0 on proc 0, cell 1 on proc 1, ...
> The text file (edit with notepad++) contains all the ISView for
> understanding purpose.
> Matthew, many thanks for the help !!
> Regards,
> Yann
> Le 20/12/2017 à 17:40, Matthew Knepley a écrit :
> On Wed, Dec 20, 2017 at 11:08 AM, Yann JOBIC <yann.jobic at univ-amu.fr>
> wrote:
>> On 12/19/2017 05:50 PM, Matthew Knepley wrote:
>> On Tue, Dec 19, 2017 at 11:40 AM, Yann JOBIC <yann.jobic at univ-amu.fr>
>> wrote:
>>> Hello,
>>> We want to extract the cell connectivity from a DMPlex. We have no
>>> problem for a sequential run.
>> Do you want it on disk? If so, you can just DMView() for HDF5. That
>> outputs the connectivity in a global numbering.
>> I can show you the calls I use inside if you want.
>> I looked at the code, specifically DMPlexWriteTopology_Vertices_H
>> DF5_Static
>> cellIS should have what i want.
>> However it seems that it is not the case. Do i look at the right spot in
>> the code ?
> cellIS has the entire connectivity. You sound like you want cell-vertex
> only. You could get that by just
> DMPlexUninterpolate(dm, &udm);
> <get your cellIS from udm>
> DMDestroy(&udm);
>> I also looked at DMPlexGetCellNumbering, which does exactly what i want
>> for the global numbering of Cells, even if the ordering is different for
>> different number of processors.
> Yes.
>> When i use DMPlexGetVertexNumbering, i've got negative values, which is
>> correctly handeled by DMPlexWriteTopology_Vertices_HDF5_Static, but i
>> really don't understand this part.
> There are no shared cells in your partition, so you get all positive
> numbers. You have shared vertices, so the negative numbers are for vertices
> you do not own. If the negative number is n, the corresponding global
> number is -(n+1). Notice that the transformation is 1-1 and its square is I.
>> I succeed in having the coordinates, but maybe not in the right order. I
>> reused DMPlexWriteCoordinates_HDF5_Static, which create a Vec of vertex
>> coordinates, but i couldn't understand the order of vertex coordinate
>> linked (or not) with DMPlexWriteTopology_Vertices_HDF5_Static. The
>> number of local coordinates is also strange, and does not correspond to the
>> cell's topology.
> It matches the order of the global numbering.
> Thanks
> Matt
>> Thanks for the help!
>> Regards,
>> Yann
>> I usually put
>> DMViewFromOptions(dm, NULL, "-dm_view")
>> Then
>> -dm_view hdf5:mesh.h5
>> Thanks,
>> Matt
>>> However for parallel ones, we need to get the node numbering in the
>>> global ordering, as when we distribute the mesh, we only have local nodes,
>>> and thus local numbering.
>>> It seems that we should use DMGetLocalToGlobalMapping (we are using
>>> Fortran with Petsc 3.8p3). However, we get the running error :
>>> [0]PETSC ERROR: No support for this operation for this object type
>>> [0]PETSC ERROR: DM can not create LocalToGlobalMapping
>>> Is it the right way to do it ?
>>> Many thanks,
>>> Regards,
>>> Yann
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171220/632a7b86/attachment.html>
