[petsc-users] configure fails with batch+scalapack
    Santiago Andres Triana
    repepo at gmail.com
    Tue Dec 19 06:05:08 CST 2017
Epilogue:
I was able to complete the configuration and compilation using an
interactive session in one compute node. Certainly, there was no need for
the --with-batch option.
However, at run time, the SGI MPT's mpiexec_mpt (required by the job
scheduler in this cluster) throws a cryptic error: Cannot find executable:
-f
It seems not petsc specific, though, as other mpi programs also fail.
In any case I would like to thank you all for the prompt help!
Santiago
On Mon, Dec 18, 2017 at 1:03 AM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   Configure runs fine. When it runs fine absolutely no reason to run it
> with --with-batch.
>    Make test fails because it cannot launch parallel jobs directly using
> the mpiexec it is using.
>    You need to determine how to submit jobs on this system and then you
> are ready to go.
>    Barry
> > On Dec 17, 2017, at 4:55 PM, Santiago Andres Triana <repepo at gmail.com>
> wrote:
> > Thanks for your quick responses!
> > Attached is the configure.log obtained without using the --with-batch
> option. Configures without errors but fails at the 'make test' stage. A
> snippet of the output with the error (which I attributed to the job
> manager) is:
> > >   Local host:              hpca-login
> > >   Registerable memory:     32768 MiB
> > >   Total memory:            65427 MiB
> > > Your MPI job will continue, but may be behave poorly and/or hang.
> > 3c25
> > <     0 KSP Residual norm 0.239155
> > >     0 KSP Residual norm 0.235858
> > 6c28
> > <     0 KSP Residual norm 6.81968e-05
> > >     0 KSP Residual norm 2.30906e-05
> > 9a32,33
> > > [hpca-login:38557] 1 more process has sent help message
> help-mpi-btl-openib.txt / reg mem limit low
> > > [hpca-login:38557] Set MCA parameter "orte_base_help_aggregate" to 0
> to see all help / error messages
> > /home/trianas/petsc-3.8.3/src/snes/examples/tutorials
> > Possible problem with ex19_fieldsplit_fieldsplit_mumps, diffs above
> > Possible error running Fortran example src/snes/examples/tutorials/ex5f
> with 1 MPI process
> > See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > WARNING: It appears that your OpenFabrics subsystem is configured to only
> > allow registering part of your physical memory.  This can cause MPI jobs
> to
> > run with erratic performance, hang, and/or crash.
> > This may be caused by your OpenFabrics vendor limiting the amount of
> > physical memory that can be registered.  You should investigate the
> > relevant Linux kernel module parameters that control how much physical
> > memory can be registered, and increase them to allow registering all
> > physical memory on your machine.
> > See this Open MPI FAQ item for more information on these Linux kernel
> module
> > parameters:
> >     http://www.open-mpi.org/faq/?category=openfabrics#ib-locked-pages
> > Number of SNES iterations =     4
> > Completed test examples
> > Now to evaluate the computer systems you plan use - do:
> > make PETSC_DIR=/home/trianas/petsc-3.8.3 PETSC_ARCH=arch-linux2-c-debug
> streams
> > On Sun, Dec 17, 2017 at 11:32 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Sun, Dec 17, 2017 at 3:29 PM, Santiago Andres Triana <
> repepo at gmail.com> wrote:
> > Dear petsc-users,
> > I'm trying to install petsc in a cluster that uses a job manager.  This
> is the configure command I use:
> > ./configure --known-mpi-shared-libraries=1 --with-scalar-type=complex
> --with-mumps=1 --download-mumps --download-parmetis
> --with-blaslapack-dir=/sw/sdev/intel/psxe2015u3/composer_xe_2015.3.187/mkl
> --download-metis --with-scalapack=1 --download-scalapack --with-batch
> > This fails when including the option --with-batch together with
> --download-scalapack:
> > We need configure.log
> >              Configuring PETSc to compile on your system
> > TESTING: check from config.libraries(config/
> BuildSystem/config/libraries.py:158)
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
> for details):
> > Unable to find scalapack in default locations!
> > Perhaps you can specify with --with-scalapack-dir=<directory>
> > If you do not want scalapack, then give --with-scalapack=0
> > You might also consider using --download-scalapack instead
> > However, if I omit the --with-batch option, the configure script manages
> to succeed (it downloads and compiles scalapack; the install fails later at
> the make debug because of the job manager).
> > Can you send this failure as well?
> >   Thanks,
> >      Matt
> > Any help or suggestion is highly appreciated. Thanks in advance!
> > Andres
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/
> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171219/564066d3/attachment.html>
