[petsc-users] [petsc-dev] Golub-Kahan bidiagonalization
Karin&NiKo niko.karin at gmail.com
Mon Dec 18 10:32:11 CST 2017
The N matrix is not mandatory ; in some case, it can be usefull to
accelerate the convergence.
So you confirm we should look at a fieldsplit implementation with a new
-pc_fieldsplit_type gk?
Nicolas
2017-12-18 14:03 GMT+01:00 Matthew Knepley <knepley at gmail.com>:
> On Mon, Dec 18, 2017 at 7:42 AM, Karin&NiKo <niko.karin at gmail.com> wrote:
>> Dear PETSc team,
>> I would like to implement and possibly commit to PETSc the Golub-Kahan
>> bidiagonalization algorithm (GK) describe in Arioli's paper :
>> http://epubs.siam.org/doi/pdf/10.1137/120866543.
>> In this work, Mario Arioli uses GK to solve saddle point problems, of the
>> form A=[A00, A01; A10, A11]. There is an outer-loop which treats the
>> constraints and an inner-loop, with its own KSP, to solve the linear
>> systems with A00 as operator. We have evaluated this algorithm on different
>> problems and have found that it exhibits very nice convergence of the
>> outer-loop (independant of the problem size).
>> In order to developp a source that could be commited to PETSc, I would
>> like to have your opinion on how to implement it. Since the algorithm
>> treats saddle point problems, it seems to me that it should be implemented
>> in the fieldsplit framework. Should we add for instance a
>> new -pc_fieldsplit_type, say gk? Have you other ideas?
> That was my first idea. From quickly looking at the paper, it looks like
> you need an auxiliary matrix N which
> does not come from the decomposition, so you will have to attach it to
> something, like we do for LSC, or
> demand that it come in as the (1,1) block of the preconditioning matrix
> which is a little hacky as well.
>   Thanks,
>      Matt
>> I look forward to hearing your opinion on the best design for
>> implementing this algorithm in PETSc.
>> Regards,
>> Nicolas
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171218/37db2cdc/attachment.html>
