[petsc-users] configure fails with batch+scalapack
Satish Balay
balay at mcs.anl.gov
Sun Dec 17 16:26:49 CST 2017
Note: you don't need --with-batch for PETSc - just because the cluster
uses the job manager.
PETSc configure attempts to compile/run trivial MPI snippets [without
mpi_int] - that usually works on the frontend for most MPI impls
installed on clusters. Only if this fails [and configure gives a
failure] - you would need the --with-batch=1 option
Satish
On Sun, 17 Dec 2017, Smith, Barry F. wrote:
> It helps if we have configure.log
> But if the non-batch version installed the Scalapack then why not just run a second time with the batch option; it should automatically use the scalapack that was already successfully installed. Send configure.log if it fails.
> Barry
> > On Dec 17, 2017, at 2:29 PM, Santiago Andres Triana <repepo at gmail.com> wrote:
> > Dear petsc-users,
> > I'm trying to install petsc in a cluster that uses a job manager. This is the configure command I use:
> > ./configure --known-mpi-shared-libraries=1 --with-scalar-type=complex --with-mumps=1 --download-mumps --download-parmetis --with-blaslapack-dir=/sw/sdev/intel/psxe2015u3/composer_xe_2015.3.187/mkl --download-metis --with-scalapack=1 --download-scalapack --with-batch
> > This fails when including the option --with-batch together with --download-scalapack:
> > Configuring PETSc to compile on your system
> > TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:158) *******************************************************************************
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> > Unable to find scalapack in default locations!
> > Perhaps you can specify with --with-scalapack-dir=<directory>
> > If you do not want scalapack, then give --with-scalapack=0
> > You might also consider using --download-scalapack instead
> > However, if I omit the --with-batch option, the configure script manages to succeed (it downloads and compiles scalapack; the install fails later at the make debug because of the job manager). Any help or suggestion is highly appreciated. Thanks in advance!
> > Andres
