[petsc-users] How to disable debugging mode?
Fri Dec 15 05:35:38 CST 2017
On Fri, Dec 15, 2017 at 3:41 AM, Edoardo alinovi <edoardo.alinovi at gmail.com>
wrote:
> Dear users,
> I would like to disable the debugging mode in petsc and turn it on when
> needed.
> my actual configure is:
> --prefix=/home/edo/software/petsc_3.8.1/ --with-mpi-dir=/home/edo/software/openMPI-3.0/
> --download-fblaslapack=1 --download-superlu_dist --download-mumps  &
> --download-hypre --download-metis --download-parmetis --download-scalapack
> Have I only to add the flag "--with-debugging=no" to the above lines and
> re-run the configure script?
Yes.
> Have I to substitute "--download-libname" with --with-libname-lib=<lib>
> for each external library?
No.
> Sorry for the dummy question, but I really do not want to mess up the
> current working install :)
You do not have to. Rerun the configure like this:
  $PETSC_DIR/$PETSC_ARCH/lib/petsc/conf/reconfgiure-$PETSC_ARCH.py
--with-debugging=0 --PETSC_ARCH=arch-opt
     Matt
> Thak you very much,
> Edoardo
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171215/48f9bba3/attachment.html>
