[petsc-users] Problem with DMRefine and DMLabel
Santos Teixeira Frederico
fsantost at student.ethz.ch
Wed Dec 13 03:30:01 CST 2017
Hi folks,
In the example SNES/62.c, when I use "-simplex 1" and "-refinement_limit 0.05", it seems the refined DMPlex does not carry all the labels from the original DM.
You can see that if you place, in the function CreateMesh, one DMViewFromOptions right after the DMPlexCreateBoxMesh and another DMViewFromOptions after DMRefine. The first output is
DM Object: DM_0x84000000_0 1 MPI processes
type: plex
DM_0x84000000_0 in 2 dimensions:
0-cells: 9
1-cells: 16
2-cells: 8
Labels:
Face Sets: 4 strata with value/size (1 (2), 4 (2), 2 (2), 3 (2))
marker: 4 strata with value/size (4 (5), 1 (3), 2 (5), 3 (3))
depth: 3 strata with value/size (0 (9), 1 (16), 2 (8))
which is correct w.r.t. the definition from DMPlexCreateBoxMesh. However, the second output is
DM Object: DM_0x84000000_1 1 MPI processes
type: plex
DM_0x84000000_1 in 2 dimensions:
0-cells: 145
1-cells: 400
2-cells: 256
Labels:
marker: 4 strata with value/size (4 (3), 1 (57), 2 (3), 3 (1))
depth: 3 strata with value/size (0 (145), 1 (400), 2 (256))
Note that the label "Face Sets" disappeared and that the label "marker" does not include all the boundary points.
The full set of options is:
-run_type full
-refinement_limit 0.005
-simplex 1
-dm_view
-dm_plex_separate_marker
-interpolate 1
-vel_petscspace_order 2
-pres_petscspace_order 1
-ksp_view
-ksp_monitor
-ksp_type fgmres
-ksp_gmres_restart 10
-ksp_rtol 1.0e-9
-pc_type fieldsplit
-pc_fieldsplit_type schur
-pc_fieldsplit_schur_factorization_type full
-fieldsplit_pressure_ksp_rtol 1e-10
-fieldsplit_velocity_ksp_type gmres
-fieldsplit_velocity_pc_type lu
-fieldsplit_pressure_pc_type jacobi
-snes_error_if_not_converged
-ksp_error_if_not_converged
-snes_view
-snes_monitor
Am I missing anything?
Fred.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171213/1e22429d/attachment-0001.html>
