[petsc-users] MatPtAP problem after subsequent call to MatDuplicate
Samuel Lanthaler
s.lanthaler at gmail.com
Tue Dec 5 09:42:21 CST 2017
Thank you for your swift reply, Hong!
Yes, what you said is exactly what I'm doing. No, I don't get an error
when doing a MatView of matC.
Samuel
On 12/05/2017 04:38 PM, Hong wrote:
> Samuel:
> You try to do following:
> 1) Create A;
> 2) Create P;
> 3) C = PtAP:
> CALL MatPtAP(matA,matP,MAT_INITIAL_MATRIX,PETSC_DEFAULT_REAL,matC,ierr);
> 4) MatDestroy(matA,ierr);
> 5) MatDuplicate(matC,MAT_COPY_VALUES,matA,ierr);
> 6) MatView(matA,PETSC_VIEWER_STDOUT_WORLD,ierr);
> The error occurs at (6). Do you get any error for
> MatView(matC)?
> C has some special data structures as a matrix product which could be
> lost during
> MatDuplicate for matA. It might be a bug in our code. I'll check it.
> Hong
> Hi there,
> I am getting error messages after using MatPtAP to create a new
> matrix C = Pt*A*P and then trying to assign A=C. The following is
> a minimal example reproducing the problem:
> #include "slepc/finclude/slepc.h"
> USE slepcsys
> USE slepceps
> IMPLICIT NONE
> LOGICAL :: cause_error
> ! --- pure PETSc
> PetscErrorCode :: ierr
> PetscScalar :: vals(3,3), val
> Mat :: matA, matP, matC
> PetscInt :: m,idxn(3),idxm(3),idone(1)
> ! initialize SLEPc & Petsc etc.
> CALL SlepcInitialize(PETSC_NULL_CHARACTER,ierr)
> ! Set up a new matrix
> m = 3
> CALL MatCreate(PETSC_COMM_WORLD,matA,ierr); CHKERRQ(ierr);
> CALL MatSetType(matA,MATMPIAIJ,ierr); CHKERRQ(ierr);
> CALL
> MatSetSizes(matA,PETSC_DECIDE,PETSC_DECIDE,m,m,ierr);
> CHKERRQ(ierr);
> CALL
> MatMPIAIJSetPreallocation(matA,3,PETSC_NULL_INTEGER,3,PETSC_NULL_INTEGER,ierr);
> CHKERRQ(ierr);
> ! [.... call to MatSetValues to set values of matA]
> ! assemble matrix
> CALL MatAssemblyBegin(matA,MAT_FINAL_ASSEMBLY,ierr);
> CHKERRQ(ierr);
> CALL MatAssemblyEnd(matA,MAT_FINAL_ASSEMBLY,ierr);
> CHKERRQ(ierr);
> ! duplicate matrix
> CALL
> MatDuplicate(matA,MAT_DO_NOT_COPY_VALUES,matP,ierr);
> CHKERRQ(ierr);
> ! [.... call to MatSetValues to set values of matP]
> ! assemble matrix
> CALL MatAssemblyBegin(matP,MAT_FINAL_ASSEMBLY,ierr);
> CHKERRQ(ierr);
> CALL MatAssemblyEnd(matP,MAT_FINAL_ASSEMBLY,ierr);
> CHKERRQ(ierr);
> ! compute C=Pt*A*P
> cause_error = .TRUE. ! set to .TRUE. to cause error,
> .FALSE. seems to work fine
> IF(.NOT.cause_error) THEN
> CALL MatDuplicate(matA,MAT_COPY_VALUES,matC,ierr);
> CHKERRQ(ierr);
> ELSE
> CALL
> CHKERRQ(ierr);
> END IF
> ! destroy matA and duplicate A=C
> CALL MatDestroy(matA,ierr); CHKERRQ(ierr);
> CALL MatDuplicate(matC,MAT_COPY_VALUES,matA,ierr);
> CHKERRQ(ierr);
> ! display resulting matrix A
> CALL MatView(matA,PETSC_VIEWER_STDOUT_WORLD,ierr);
> CHKERRQ(ierr);
> Whether A and P are assigned any values doesn't seem to matter at
> all. The error message I'm getting is:
> Mat Object: 1 MPI processes
> type: mpiaij
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
> Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> <http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind>
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and
> Apple Mac OS X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: --------------------- Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are
> not available,
> [0]PETSC ERROR: INSTEAD the line number of the start of
> the function
> [0]PETSC ERROR: is given.
> [0]PETSC ERROR: [0] MatView_MPIAIJ_PtAP line 23
> /home/lanthale/Progs/petsc-3.8.2/src/mat/impls/aij/mpi/mpiptap.c
> [0]PETSC ERROR: [0] MatView line 949
> /home/lanthale/Progs/petsc-3.8.2/src/mat/interface/matrix.c
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See
> <http://www.mcs.anl.gov/petsc/documentation/faq.html> for
> trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.8.2, Nov, 09, 2017
> Could someone maybe tell me where I'm doing things wrong? The
> documentation for MatPtAP
> <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatPtAP.html>
> says that C will be created and that this routine is "currently
> only implemented for pairs of AIJ matrices and classes which
> inherit from AIJ". Does this maybe exclude MPIAIJ matrices?
> Thanks,
> Samuel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171205/5961a53d/attachment.html>
