[petsc-users] 2 Dirichlet conditions for one Element in PetscFE
Yann Jobic yann.jobic at univ-amu.fr
Tue Dec 5 08:12:31 CST 2017
Hello,
I tried the master of the git directory, as you have merged the branch.
It works ! Many thanks for the fix.
Best regards,
Yann
Le 22/11/2017 à 18:51, Matthew Knepley a écrit :
> On Wed, Nov 22, 2017 at 12:39 PM, Yann Jobic <yann.jobic at univ-amu.fr
> <mailto:yann.jobic at univ-amu.fr>> wrote:
>     Hello,
>     I've found a strange behavior when looking into a bug for the
>     pressure convergence of a simple Navier-Stokes problem using PetscFE.
>     I followed many examples for labeling boundary faces. I first use
>     DMPlexMarkBoundaryFaces, (label=1 to the faces).
>     I find those faces using DMGetStratumIS and searching 1 as it is
>     the value of the marked boundary faces.
>     Finally i use DMPlexLabelComplete over the new label.
>     I then use :
>       ierr = PetscDSAddBoundary(prob, DM_BC_ESSENTIAL, "in", "Faces",
>     0, Ncomp, components, (void (*)(void)) uIn, NWest, west,
>     NULL);CHKERRQ(ierr);
>     in order to impose a dirichlet condition for the faces labeled by
>     the correct value (west=1, south=3,...).
>     However, the function "uIn()" is called in all the Elements
>     containing the boundary faces, and thus impose the values at nodes
>     that are not in the labeled faces.
>     Is it a normal behavior ? I then have to test the position of the
>     node calling uIn, in order to impose the good value.
>     I have this problem for a Poiseuille flow, where at 2 corner
>     Elements i have a zero velocity dirichlet condition (wall) and a
>     In flow velocity one.
> I believe I have fixed this in knepley/fix-plex-bc-multiple which
> should be merged soon. Do you know how to merge that branch and try?
>   Thanks,
>      Matt
>     The pressure is then very high at the corner nodes of those 2
>     Elements.
>     Do you think my pressure problem comes from there ? (The velocity
>     field is correct)
>     Many thanks,
>     Regards,
>     Yann
>     PS : i'm using those runtime options :
>     -vel_petscspace_order 2 -pres_petscspace_order 1 \
>     -ksp_type fgmres -pc_type fieldsplit -pc_fieldsplit_type schur
>     -pc_fieldsplit_schur_fact_type full  \
>     -fieldsplit_velocity_pc_type lu -fieldsplit_pressure_ksp_rtol
>     1.0e-10 -fieldsplit_pressure_pc_type jacobi
>     L'absence de virus dans ce courrier électronique a été vérifiée
>     par le logiciel antivirus Avast.
>     https://www.avast.com/antivirus <https://www.avast.com/antivirus>
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
___________________________
Yann JOBIC
HPC engineer
IUSTI-CNRS UMR 7343 - Polytech Marseille
Technopôle de Château Gombert
5 rue Enrico Fermi
13453 Marseille cedex 13
Tel : (33) 4 91 10 69 43
Fax : (33) 4 91 10 69 69
L'absence de virus dans ce courrier électronique a été vérifiée par le logiciel antivirus Avast.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171205/ee9be226/attachment-0001.html>
