[petsc-users] Shell matrix MatCreateVecs
Jed Brown jed at jedbrown.org
Fri Aug 25 09:19:48 CDT 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
>> On Aug 24, 2017, at 7:42 PM, Jed Brown <jed at jedbrown.org> wrote:
>> "Jose E. Roman" <jroman at dsic.upv.es> writes:
>>>> El 24 ago 2017, a las 22:51, Greg Meyer <gregory.meyer at gmail.com> escribió:
>>>> Hi,
>>>> I have written a shell matrix for non-standard vectors (CUDA to be specific) that works great. MatMult and MatNorm perform as they should. However, when I try to use it in a SLEPc algorithm, it breaks because MatCreateVecs yields standard vectors even if I set "-vec_type cuda". Looking through the source etc. it seems that MatShellSetOperation can't be used to implement a new MatCreateVecs function (MATOP_CREATEVECS does not exist). Is there a way to change the type of vector that comes from MatCreateVecs for shell matrices?
>>>> Thanks in advance,
>>>> Greg
>>> It is MATOP_GET_VECS. If you implement this operation, most SLEPc functionality should work with CUDA.
>>> PETSc developers: shouldn't MATOP_GET_VECS be renamed to MATOP_CREATE_VECS ?
>> Yes, in their eagerness to rename interfaces,
>   You mean, eagerness to improve PETSc
Exactly.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170825/c56a02bf/attachment-0001.sig>
