[petsc-users] Shell matrix MatCreateVecs
Jed Brown
jed at jedbrown.org
Thu Aug 24 21:42:38 CDT 2017
"Jose E. Roman" <jroman at dsic.upv.es> writes:
>> El 24 ago 2017, a las 22:51, Greg Meyer <gregory.meyer at gmail.com> escribió:
>> Hi,
>> I have written a shell matrix for non-standard vectors (CUDA to be specific) that works great. MatMult and MatNorm perform as they should. However, when I try to use it in a SLEPc algorithm, it breaks because MatCreateVecs yields standard vectors even if I set "-vec_type cuda". Looking through the source etc. it seems that MatShellSetOperation can't be used to implement a new MatCreateVecs function (MATOP_CREATEVECS does not exist). Is there a way to change the type of vector that comes from MatCreateVecs for shell matrices?
>> Thanks in advance,
>> Greg
> It is MATOP_GET_VECS. If you implement this operation, most SLEPc functionality should work with CUDA.
> PETSc developers: shouldn't MATOP_GET_VECS be renamed to MATOP_CREATE_VECS ?
Yes, in their eagerness to rename interfaces, people often forget to
complete all parts of the job. The MATOP interface has shown itself to
be high maintenance.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170824/c35bce7b/attachment.sig>
