[petsc-users] Petsc ILU PC Change between 3.6.4 and 3.7.x?
Barry Smith
bsmith at mcs.anl.gov
Fri Aug 11 14:03:15 CDT 2017
Thanks for confirming this. The change was actually in the 3.4 release. I have updated the 3.4 changes file to include this change in both the maint and master branches.
Barry
> On Aug 11, 2017, at 12:47 PM, Gaetan Kenway <gaetank at gmail.com> wrote:
> OK, so that was certainly it. I vaguely recall reading something about this on the mailing list at one point in time, but couldn't find anything.
> I would definitely put something on the 3.7 change doc since I looked there first to see if anything stuck out.
> Thanks!
> On Fri, Aug 11, 2017 at 10:28 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Run with the additional option
> -sub_pc_factor_shift_type nonzero
> does this resolve the problem. We changed the default behavior for ILU when it detects "zero" pivots.
> Please let us know if this resolves the problem and we'll update the changes file.
> Barry
> > On Aug 11, 2017, at 12:14 PM, Gaetan Kenway <gaetank at gmail.com> wrote:
> > Hi All
> > I'm in the process of updating a code that uses PETSc for solving linear systems for an unstructured CFD code. As of recently, it was using an ancient version (3.3). However, when I updated it up to 3.7.6 I ended up running into issues with one of the KSP solves. The remainder of the code is identical,
> > I've tracked the issue down to occurring between version 3.6.4 and version 3.7.0 . The same issue is present on the most recent version 3.7.6.
> > Specifically the issue is that on the second iteration, on the 3.7 version the KSP kicks out with KSP converged reason of -11 or KSP_DIVERGED_PCSETUP_FAILED . After that the two runs differ. The KSPView for each of the two are given below which are identical, up to small formatting changes. There is still more I can track down, but I thought I would ask if someone knows what might have changed between these two versions which could save me a lot of time.
> > Thanks,
> > Gaetan
> > 3.6 KSP View:
> > KSP Object: 8 MPI processes
> > type: gmres
> > GMRES: restart=3, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
> > GMRES: happy breakdown tolerance 1e-30
> > maximum iterations=3
> > using preconditioner applied to right hand side for initial guess
> > tolerances: relative=1e-08, absolute=1e-20, divergence=1e+15
> > left preconditioning
> > using nonzero initial guess
> > using PRECONDITIONED norm type for convergence test
> > PC Object: 8 MPI processes
> > type: bjacobi
> > block Jacobi: number of blocks = 8
> > Local solve is same for all blocks, in the following KSP and PC objects:
> > KSP Object: (sub_) 1 MPI processes
> > type: preonly
> > maximum iterations=10000, initial guess is zero
> > tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> > using NONE norm type for convergence test
> > PC Object: (sub_) 1 MPI processes
> > type: ilu
> > ILU: out-of-place factorization
> > 0 levels of fill
> > tolerance for zero pivot 2.22045e-14
> > matrix ordering: natural
> > factor fill ratio given 1, needed 1
> > Factored matrix follows:
> > Mat Object: 1 MPI processes
> > type: seqaij
> > rows=46439, cols=46439
> > package used to perform factorization: petsc
> > total: nonzeros=502615, allocated nonzeros=502615
> > total number of mallocs used during MatSetValues calls =0
> > not using I-node routines
> > linear system matrix = precond matrix:
> > type: seqaij
> > total: nonzeros=502615, allocated nonzeros=504081
> > Mat Object: 8 MPI processes
> > type: mpiaij
> > rows=368656, cols=368656
> > total: nonzeros=4.63682e+06, allocated nonzeros=4.64417e+06
> > not using I-node (on process 0) routines
> > <my output: reason, iterations, rtol, atol>
> > reason,its: 2 3 0.001 1e-20
> > Petsc 3.7 KSP View
> > type: gmres
> > type: bjacobi
> > type: preonly
> > tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> > type: ilu
> > 0 levels of fill
> > factor fill ratio given 1., needed 1.
> > type: seqaij
> > type: seqaij
> > type: mpiaij
> > total: nonzeros=4636822, allocated nonzeros=4644168
> > reason,its: -11 0 0.001 1e-20
