[petsc-users] MatMPIAIJSetPreallocation question
Xiangdong
epscodes at gmail.com
Mon Aug 7 07:40:39 CDT 2017
Hi Barry,
Thanks for your response. So these extra allocated memory is just a waste
of memory, but no harm for other mat related computation. Is it correct?
Thank you.
Xiangdong
On Fri, Aug 4, 2017 at 4:52 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Aug 4, 2017, at 2:52 PM, Xiangdong <epscodes at gmail.com> wrote:
> > Hello everyone,
> > I have a quick questions on the MatMPIAIJSetPreallocation. If we do not
> pass the exact number of nonzeros for o_nnz and d_nnz, (for example,
> MAT_INFO_NZ_ALLOCATED is 50% more than MAT_INFO_NZ_USED), will the
> performance of MatMult be affected? What effect will these allocated but
> unused memory cause?
> It is not a big deal to have extra memory, it won't slow things down.
> If you under estimate it can slow things down a lot.
> > Thank you.
> > Best,
> > Xiangdong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170807/33daae6e/attachment.html>
