[petsc-users] DMPlex ghost cells
Matthew Knepley
knepley at gmail.com
Fri Aug 4 09:37:51 CDT 2017
On Thu, Aug 3, 2017 at 10:52 PM, Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> Would it also work if I just didn't use DMPlexGetHybridBounds() to
> differentiate between partition ghost cells and boundary ghost cells, but
> instead checked the value of the "ghost" DMLabel?
Yes.
Matt
> It appears that DMPlexConstructGhostCells() labels boundary ghosts with
> the ghost label value 1, and partition ghosts with value 2 (in
> DMPlexShiftLabels_Internal()).
> If that is reliable, then it might save me having to make sure the
> boundary ghosts always come last.
> - Adrian
> On 04/08/17 15:11, Matthew Knepley wrote:
> On Thu, Aug 3, 2017 at 10:07 PM, Adrian Croucher <
> a.croucher at auckland.ac.nz> wrote:
>> I am adding cells onto a DMPlex (for dual porosity). I notice that
>> normally the ghost cells in a DMPlex are at the end of the cell list.
>> Does it matter if the cells I add come after those ghost cells, or should
>> the ghosts always come last?
>> It seems to me it probably shoudn't matter if the partition ghosts
>> (created by DMPlexDistribute()) are not at the end. In my cell loops I just
>> check the value of the ghost DMLabel and skip them if necessary.
>> But perhaps the boundary ghosts (created by DMPlexConstructGhostCells())
>> need to come last? Otherwise the output from DMPlexGetHybridBounds() (to
>> get the bounds on 'interior' cells, i.e. non-boundary-ghosts) probably
>> wouldn't make much sense?
> Yes, the only reason to have them last is to have GetHybridBounds() work
> for that case.
> Thanks,
> Matt
>> - Adrian
>> Dr Adrian Croucher
>> Senior Research Fellow
>> Department of Engineering Science
>> University of Auckland, New Zealand
>> email: a.croucher at auckland.ac.nz
>> tel: +64 (0)9 923 4611
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
> Dr Adrian Croucher
> tel: +64 (0)9 923 4611 <+64%209-923%204611>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170804/2f2fde23/attachment-0001.html>
