[petsc-users] strange convergence
    Hoang Giang Bui
    hgbk2008 at gmail.com
    Mon Apr 24 03:16:33 CDT 2017
Thanks Barry, trying with -fieldsplit_u_type lu gives better convergence. I
still used 4 procs though, probably with 1 proc it should also be the same.
The u block used a Nitsche-type operator to connect two non-matching
domains. I don't think it will leave some rigid body motion leads to not
sufficient constraints. Maybe you have other idea?
    Residual norms for fieldsplit_u_ solve.
    0 KSP Residual norm 3.129067184300e+05
    1 KSP Residual norm 5.906261468196e-01
    Residual norms for fieldsplit_wp_ solve.
    0 KSP Residual norm 0.000000000000e+00
  0 KSP preconditioned resid norm 3.129067184300e+05 true resid norm
9.015150492169e+06 ||r(i)||/||b|| 1.000000000000e+00
    0 KSP Residual norm 9.999955993437e-01
    1 KSP Residual norm 4.019774691831e-06
  1 KSP preconditioned resid norm 5.003913641475e-01 true resid norm
4.692996324114e+01 ||r(i)||/||b|| 5.205677185522e-06
    0 KSP Residual norm 1.000012180204e+00
    1 KSP Residual norm 1.017367950422e-05
  2 KSP preconditioned resid norm 2.330910333756e-07 true resid norm
3.474855463983e+01 ||r(i)||/||b|| 3.854461960453e-06
    0 KSP Residual norm 1.000004200085e+00
    1 KSP Residual norm 6.231613102458e-06
  3 KSP preconditioned resid norm 8.671259838389e-11 true resid norm
3.545103468011e+01 ||r(i)||/||b|| 3.932384125024e-06
Linear solve converged due to CONVERGED_ATOL iterations 3
KSP Object: 4 MPI processes
  type: gmres
    GMRES: restart=1000, using Modified Gram-Schmidt Orthogonalization
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=1000, initial guess is zero
  tolerances:  relative=1e-20, absolute=1e-09, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 4 MPI processes
  type: fieldsplit
    FieldSplit with MULTIPLICATIVE composition: total splits = 2
    Solver info for each split is in the following KSP objects:
    Split number 0 Defined by IS
    KSP Object:    (fieldsplit_u_)     4 MPI processes
      type: richardson
        Richardson: damping factor=1
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
    PC Object:    (fieldsplit_u_)     4 MPI processes
      type: lu
        LU: out-of-place factorization
        tolerance for zero pivot 2.22045e-14
        matrix ordering: natural
        factor fill ratio given 0, needed 0
          Factored matrix follows:
            Mat Object:             4 MPI processes
              type: mpiaij
              rows=938910, cols=938910
              package used to perform factorization: pastix
              total: nonzeros=0, allocated nonzeros=0
      Error :                        3.36878e-14
          total number of mallocs used during MatSetValues calls =0
                PaStiX run parameters:
                  Matrix type :                      Unsymmetric
                  Level of printing (0,1,2):         0
                  Number of refinements iterations : 3
  Error :                        3.36878e-14
      linear system matrix = precond matrix:
      Mat Object:      (fieldsplit_u_)       4 MPI processes
        type: mpiaij
        rows=938910, cols=938910, bs=3
  Error :                        3.36878e-14
  Error :                        3.36878e-14
        total: nonzeros=8.60906e+07, allocated nonzeros=8.60906e+07
          using I-node (on process 0) routines: found 78749 nodes, limit
used is 5
    Split number 1 Defined by IS
    KSP Object:    (fieldsplit_wp_)     4 MPI processes
      type: richardson
    PC Object:    (fieldsplit_wp_)     4 MPI processes
      type: lu
              type: mpiaij
              rows=34141, cols=34141
                Error :                        -nan
  Error :                        -nan
  Error :                        -nan
                  Matrix type :                      Symmetric
                  Number of refinements iterations : 0
  Error :                        -nan
      Mat Object:      (fieldsplit_wp_)       4 MPI processes
        type: mpiaij
        total: nonzeros=485655, allocated nonzeros=485655
          not using I-node (on process 0) routines
    type: mpiaij
    rows=973051, cols=973051
    total: nonzeros=9.90037e+07, allocated nonzeros=9.90037e+07
      using I-node (on process 0) routines: found 78749 nodes, limit used
is 5
Giang
On Sun, Apr 23, 2017 at 10:19 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Apr 23, 2017, at 2:42 PM, Hoang Giang Bui <hgbk2008 at gmail.com> wrote:
> > Dear Matt/Barry
> > With your options, it results in
> >   0 KSP preconditioned resid norm 1.106709687386e+31 true resid norm
> 9.015150491938e+06 ||r(i)||/||b|| 1.000000000000e+00
> >     0 KSP Residual norm 2.407308987203e+36
> >     1 KSP Residual norm 5.797185652683e+72
> It looks like Matt is right, hypre is seemly producing useless garbage.
> First how do things run on one process. If you have similar problems then
> debug on one process (debugging any kind of problem is always far easy on
> one process).
> First run with -fieldsplit_u_type lu (instead of using hypre) to see if
> that works or also produces something bad.
> What is the operator and the boundary conditions for u? It could be
> singular.
> > 999 KSP preconditioned resid norm 2.920157329174e+12 true resid norm
> 9.015683504616e+06 ||r(i)||/||b|| 1.000059124102e+00
> >     0 KSP Residual norm 1.533726746719e+36
> >     1 KSP Residual norm 3.692757392261e+72
> > Do you suggest that the pastix solver for the "wp" block encounters
> small pivot? In addition, seem like the "u" block is also singular.
> > Giang
> > On Sun, Apr 23, 2017 at 7:39 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    Huge preconditioned norms but normal unpreconditioned norms almost
> always come from a very small pivot in an LU or ILU factorization.
> >    The first thing to do is monitor the two sub solves. Run with the
> additional options -fieldsplit_u_ksp_type richardson
> -fieldsplit_u_ksp_monitor -fieldsplit_u_ksp_max_it 1
> -fieldsplit_wp_ksp_type richardson -fieldsplit_wp_ksp_monitor
> -fieldsplit_wp_ksp_max_it 1
> > > On Apr 23, 2017, at 12:22 PM, Hoang Giang Bui <hgbk2008 at gmail.com>
> wrote:
> > > Hello
> > > I encountered a strange convergence behavior that I have trouble to
> understand
> > > KSPSetFromOptions completed
> > >   1 KSP preconditioned resid norm 2.933141742664e+29 true resid norm
> 9.015152282123e+06 ||r(i)||/||b|| 1.000000198575e+00
> > >   2 KSP preconditioned resid norm 9.686409637174e+16 true resid norm
> 9.015354521944e+06 ||r(i)||/||b|| 1.000022631902e+00
> > >   3 KSP preconditioned resid norm 4.219243615809e+15 true resid norm
> 9.017157702420e+06 ||r(i)||/||b|| 1.000222648583e+00
> > > 999 KSP preconditioned resid norm 3.043754298076e+12 true resid norm
> 9.015425041089e+06 ||r(i)||/||b|| 1.000030454195e+00
> > > 1000 KSP preconditioned resid norm 3.043000287819e+12 true resid norm
> 9.015424313455e+06 ||r(i)||/||b|| 1.000030373483e+00
> > > Linear solve did not converge due to DIVERGED_ITS iterations 1000
> > >   type: gmres
> > >   type: fieldsplit
> > >       type: preonly
> > >       maximum iterations=10000, initial guess is zero
> > >       using NONE norm type for convergence test
> > >       type: hypre
> > >         HYPRE BoomerAMG preconditioning
> > >         HYPRE BoomerAMG: Cycle type V
> > >         HYPRE BoomerAMG: Maximum number of levels 25
> > >         HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
> > >         HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
> > >         HYPRE BoomerAMG: Threshold for strong coupling 0.6
> > >         HYPRE BoomerAMG: Interpolation truncation factor 0
> > >         HYPRE BoomerAMG: Interpolation: max elements per row 0
> > >         HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
> > >         HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
> > >         HYPRE BoomerAMG: Maximum row sums 0.9
> > >         HYPRE BoomerAMG: Sweeps down         1
> > >         HYPRE BoomerAMG: Sweeps up           1
> > >         HYPRE BoomerAMG: Sweeps on coarse    1
> > >         HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
> > >         HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
> > >         HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
> > >         HYPRE BoomerAMG: Relax weight  (all)      1
> > >         HYPRE BoomerAMG: Outer relax weight (all) 1
> > >         HYPRE BoomerAMG: Using CF-relaxation
> > >         HYPRE BoomerAMG: Measure type        local
> > >         HYPRE BoomerAMG: Coarsen type        PMIS
> > >         HYPRE BoomerAMG: Interpolation type  classical
> > >         type: mpiaij
> limit used is 5
> > >       type: preonly
> > >       type: lu
> > >               type: mpiaij
> > >             Error :                        -nan
> > >   Error :                        -nan
> > >             Error :                        -nan
> > >   Error :                        -nan
> > >         type: mpiaij
> > >     type: mpiaij
> used is 5
> > > The pattern of convergence gives a hint that this system is somehow
> bad/singular. But I don't know why the preconditioned error goes up too
> high. Anyone has an idea?
> > > Best regards
> > > Giang Bui
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170424/ea5464c9/attachment-0001.html>
