[petsc-users] sees convergence with pc_fieldsplit
Manav Bhatia
bhatiamanav at gmail.com
Thu Apr 20 14:40:00 CDT 2017
Hi Barry,
Attached is the output.
-Manav
|| R ||_2 = 433013 : || R_i ||_2 = ( 2.81069e-07 , 433013 )
0 SNES Function norm 4.330127018922e+05
0 KSP Residual norm 1.746840810717e-02
1 KSP Residual norm 5.983637077441e-12
Linear solve converged due to CONVERGED_RTOL iterations 1
|| R ||_2 = 5.07622e-07 : || R_i ||_2 = ( 5.07622e-07 , 7.12896e-11 )
1 SNES Function norm 5.076218984984e-07
Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 1
Time step: 1 : t = 0.001 : xdot-L2 = 2.01301e-06
|| R ||_2 = 1.73186e+06 : || R_i ||_2 = ( 5.77273e-07 , 1.73186e+06 )
0 SNES Function norm 1.731856101521e+06
0 KSP Residual norm 1.745842035995e-02
1 KSP Residual norm 2.366595812944e-12
|| R ||_2 = 1.29889e+06 : || R_i ||_2 = ( 9.7379e-07 , 1.29889e+06 )
1 SNES Function norm 1.298892076140e+06
Nonlinear solve converged due to CONVERGED_SNORM_RELATIVE iterations 1
Time step: 2 : t = 0.002 : xdot-L2 = 2.72522e-06
|| R ||_2 = 433159 : || R_i ||_2 = ( 1.35694e-06 , 433159 )
0 SNES Function norm 4.331589481273e+05
0 KSP Residual norm 1.744848431182e-02
1 KSP Residual norm 7.650255893811e-12
|| R ||_2 = 866074 : || R_i ||_2 = ( 8.42454e-07 , 866074 )
1 SNES Function norm 8.660737893156e+05
Time step: 3 : t = 0.003 : xdot-L2 = 3.59383e-06
|| R ||_2 = 2.59764e+06 : || R_i ||_2 = ( 1.12168e-06 , 2.59764e+06 )
0 SNES Function norm 2.597639281693e+06
0 KSP Residual norm 1.743859969865e-02
1 KSP Residual norm 1.045225058356e-11
|| R ||_2 = 2.16477e+06 : || R_i ||_2 = ( 9.73157e-07 , 2.16477e+06 )
1 SNES Function norm 2.164772029312e+06
Changing dt: old dt = 0.001 new dt = 0.001
Time step: 4 : t = 0.004 : xdot-L2 = 4.9281e-06
|| R ||_2 = 1.29933e+06 : || R_i ||_2 = ( 1.2554e-06 , 1.29933e+06 )
0 SNES Function norm 1.299329216581e+06
0 KSP Residual norm 1.742876625743e-02
1 KSP Residual norm 6.512084951772e-12
|| R ||_2 = 1.73215e+06 : || R_i ||_2 = ( 1.00171e-06 , 1.73215e+06 )
1 SNES Function norm 1.732147071753e+06
> On Apr 20, 2017, at 2:38 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Run with -snes_monitor also and send the output
>> On Apr 20, 2017, at 2:30 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
>> Hi,
>> I have a time-dependent multiphysics problem that I am trying to solve using pc_fieldsplit. I have defined a nested matrix for the jacobian with the diagonal block matrices explicitly created and the off-diagonal blocks defined using shell matrices, so that the matrix vector product is defined. The nonlinear system of equations at each time-step is solved using an snes construct.
>> I have been facing some convergence issues, so I have reduced the problem scope to ensure that the code converges to a single discipline solution when the off-diagonal couplings are ignored.
>> Here, I have provided a constant forcing function to discipline two, which is a linear problem, so that I expect convergence in a single iteration.
>> The linear solver, defined using pc_fieldsplit seems to be converging without problems. The nonlinear solver convergence in a single time-step with FNORM in the first time step.
>> The second time-step onwards, the nonlinear solver does not converge in a single step, and is terminating due to SNORM_RELATIVE. I am not sure why this is happening.
>> What is intriguing is that the solution at the end of the n^th time-step is n times the solution after the first time step. In other words, snes at each time-step is taking the same step as was used in the first time-step.
>> Not sure sure why this is happening. I would appreciate any advice.
>> Regards,
>> Manav
>> Time step: 0 : t = 0.000
>> Following is the output of snesview:
>> SNES Object: 1 MPI processes
>> type: newtonls
>> maximum iterations=50, maximum function evaluations=10000
>> tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>> total number of linear solver iterations=1
>> total number of function evaluations=2
>> norm schedule ALWAYS
>> SNESLineSearch Object: 1 MPI processes
>> type: basic
>> maxstep=1.000000e+08, minlambda=1.000000e-12
>> tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
>> maximum iterations=1
>> KSP Object: 1 MPI processes
>> type: gmres
>> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>> GMRES: happy breakdown tolerance 1e-30
>> maximum iterations=10000, initial guess is zero
>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>> left preconditioning
>> using PRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI processes
>> type: fieldsplit
>> FieldSplit with SYMMETRIC_MULTIPLICATIVE composition: total splits = 2
>> Solver info for each split is in the following KSP objects:
>> Split number 0 Defined by IS
>> KSP Object: (fieldsplit_0_) 1 MPI processes
>> type: preonly
>> using NONE norm type for convergence test
>> PC Object: (fieldsplit_0_) 1 MPI processes
>> type: ilu
>> ILU: out-of-place factorization
>> 0 levels of fill
>> tolerance for zero pivot 2.22045e-14
>> matrix ordering: natural
>> factor fill ratio given 1., needed 1.
>> Factored matrix follows:
>> Mat Object: 1 MPI processes
>> type: seqaij
>> rows=108, cols=108
>> package used to perform factorization: petsc
>> total: nonzeros=2800, allocated nonzeros=2800
>> total number of mallocs used during MatSetValues calls =0
>> using I-node routines: found 27 nodes, limit used is 5
>> linear system matrix = precond matrix:
>> Mat Object: (fieldsplit_0_) 1 MPI processes
>> type: seqaij
>> rows=108, cols=108
>> Split number 1 Defined by IS
>> KSP Object: (fieldsplit_1_) 1 MPI processes
>> type: preonly
>> PC Object: (fieldsplit_1_) 1 MPI processes
>> type: lu
>> matrix ordering: nd
>> factor fill ratio given 5., needed 1.15385
>> type: seqaij
>> rows=30, cols=30
>> total: nonzeros=540, allocated nonzeros=540
>> using I-node routines: found 9 nodes, limit used is 5
>> Mat Object: (fieldsplit_1_) 1 MPI processes
>> type: seqaij
>> rows=30, cols=30
>> total: nonzeros=468, allocated nonzeros=468
>> using I-node routines: found 10 nodes, limit used is 5
>> type: nest
>> rows=138, cols=138
>> Matrix object:
>> type=nest, rows=2, cols=2
>> MatNest structure:
>> (0,0) : prefix="fieldsplit_0_", type=seqaij, rows=108, cols=108
>> (0,1) : type=shell, rows=108, cols=30
>> (1,0) : type=shell, rows=30, cols=108
>> (1,1) : prefix="fieldsplit_1_", type=seqaij, rows=30, cols=30
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170420/8603d833/attachment-0001.html>
