[petsc-users] Solve KSP in parallel.
Manuel Valera mvalera at mail.sdsu.edu
Fri Sep 30 21:13:53 CDT 2016
Hi Barry and all,
I was successful on creating the parallel version to solve my big system,
it is scaling accordingly, but i noticed the error norm increasing too, i
don't know if this is because the output is duplicated or if its really
increasing. Is this expected ?
Thanks
On Tue, Sep 27, 2016 at 4:07 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Yes, always use the binary file
> > On Sep 27, 2016, at 3:13 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > Barry, thanks for your insight,
> > This standalone script must be translated into a much bigger model,
> which uses AIJ matrices to define the laplacian in the form of the 3 usual
> arrays, the ascii files in the script take the place of the arrays which
> are passed to the solving routine in the model.
> > So, can i use the approach you mention to create the MPIAIJ from the
> petsc binary file ? would this be a better solution than reading the three
> arrays directly? In the model, even the smallest matrix is 10^5x10^5
> elements
> > Thanks.
> > On Tue, Sep 27, 2016 at 12:53 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> >   Are you loading a matrix from an ASCII file? If so don't do that. You
> should write a simple sequential PETSc program that reads in the ASCII file
> and saves the matrix as a PETSc binary file with MatView(). Then write your
> parallel code that reads in the binary file with MatLoad() and solves the
> system. You can read in the right hand side from ASCII and save it in the
> binary file also. Trying to read an ASCII file in parallel and set it into
> a PETSc parallel matrix is just a totally thankless task that is
> unnecessary.
> >    Barry
> > > On Sep 26, 2016, at 6:40 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > > Ok, last output was from simulated multicores, in an actual cluster
> the errors are of the kind:
> > > [valera at cinci CSRMatrix]$ petsc -n 2 ./solvelinearmgPETSc
> > >  TrivSoln loaded, size:            4 /           4
> > >  RHS loaded, size:            4 /           4
> > > [0]PETSC ERROR: --------------------- Error Message
> > > [0]PETSC ERROR: Argument out of range
> > > [0]PETSC ERROR: Comm must be of size 1
> > > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/
> documentation/faq.html for trouble shooting.
> > > [0]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
> > > [0]PETSC ERROR: ./solvelinearmgPETSc
>                                                   P on a
> arch-linux2-c-debug named cinci by valera Mon Sep 26 16:39:02 2016
> > > [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
> > > [1]PETSC ERROR: Argument out of range
> > > [1]PETSC ERROR: Comm must be of size 1
> > > [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/
> > > [1]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
> > > [1]PETSC ERROR: ./solvelinearmgPETSc
>                                                   P on a
> > > [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-fblaslapack=1 --download-mpich
> > > [1]PETSC ERROR: #1 MatCreate_SeqAIJ() line 3958 in
> /home/valera/petsc-3.7.2/src/mat/impls/aij/seq/aij.c
> > > [1]PETSC ERROR: #2 MatSetType() line 94 in
> /home/valera/petsc-3.7.2/src/mat/interface/matreg.c
> > > [1]PETSC ERROR: #3 MatCreateSeqAIJWithArrays() line 4300 in
> > >  local size:           2
> > >  local size:           2
> > > Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> > > [0]PETSC ERROR: #1 MatCreate_SeqAIJ() line 3958 in
> > > [0]PETSC ERROR: #2 MatSetType() line 94 in
> > > [0]PETSC ERROR: #3 MatCreateSeqAIJWithArrays() line 4300 in
> > > [1]PETSC ERROR: [0]PETSC ERROR: Nonconforming object sizes
> > > [0]PETSC ERROR: Sum of local lengths 8 does not equal global length 4,
> my local length 4
> > >   likely a call to VecSetSizes() or MatSetSizes() is wrong.
> > > See http://www.mcs.anl.gov/petsc/documentation/faq.html#split
> > > [1]PETSC ERROR: Sum of local lengths 8 does not equal global length 4,
> my local length 4
>                                                   P on a
>                                                   P on a
> > > [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> > > [0]PETSC ERROR: #4 PetscSplitOwnership() line 93 in
> /home/valera/petsc-3.7.2/src/sys/utils/psplit.c
> > > [1]PETSC ERROR: #4 PetscSplitOwnership() line 93 in
> > > [0]PETSC ERROR: #5 PetscLayoutSetUp() line 143 in
> /home/valera/petsc-3.7.2/src/vec/is/utils/pmap.c
> > > [0]PETSC ERROR: #6 MatMPIAIJSetPreallocation_MPIAIJ() line 2768 in
> /home/valera/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c
> > > [1]PETSC ERROR: #5 PetscLayoutSetUp() line 143 in
> > > [1]PETSC ERROR: [0]PETSC ERROR: #7 MatMPIAIJSetPreallocation() line
> 3505 in /home/valera/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c
> > > [1]PETSC ERROR: [0]PETSC ERROR: #8 MatSetUp_MPIAIJ() line 2153 in
> > > #7 MatMPIAIJSetPreallocation() line 3505 in
> > > [1]PETSC ERROR: #8 MatSetUp_MPIAIJ() line 2153 in
> > > [0]PETSC ERROR: #9 MatSetUp() line 739 in /home/valera/petsc-3.7.2/src/
> mat/interface/matrix.c
> > > [1]PETSC ERROR: #9 MatSetUp() line 739 in /home/valera/petsc-3.7.2/src/
> > > [0]PETSC ERROR: Object is in wrong state
> > > [0]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
> argument 1 "mat" before MatSetNearNullSpace()
>                                                   P on a
> > > [1]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
> > > [1]PETSC ERROR: [0]PETSC ERROR: Configure options --with-cc=gcc
> --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=1 --download-mpich
> > > [0]PETSC ERROR: #10 MatSetNearNullSpace() line 8195 in
> /home/valera/petsc-3.7.2/src/mat/interface/matrix.c
> > > See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> shooting.
>                                                   P on a
> > > [1]PETSC ERROR: #10 MatSetNearNullSpace() line 8195 in
> argument 1 "mat" before MatAssemblyBegin()
> > > [0]PETSC ERROR: [1]PETSC ERROR: Object is in wrong state
>                                                   P on a
>                                                   P on a
> > > [1]PETSC ERROR: #11 MatAssemblyBegin() line 5093 in
> > > [0]PETSC ERROR: ------------------------------
> > > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> > > [1]PETSC ERROR: ------------------------------
> > > [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > > [1]PETSC ERROR: [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> > > [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> documentation/faq.html#valgrind
> > > [1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> > > [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS X to find memory corruption errors
> > > or try http://valgrind.org on GNU/linux and Apple Mac OS X to find
> > > [0]PETSC ERROR: likely location of problem given in stack below
> > > [0]PETSC ERROR: ---------------------  Stack Frames
> > > [1]PETSC ERROR: likely location of problem given in stack below
> > > [1]PETSC ERROR: ---------------------  Stack Frames
> > > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > > [0]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> > > [0]PETSC ERROR: [1]PETSC ERROR: Note: The EXACT line numbers in the
> stack are not available,
> > > [1]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> > >       is given.
> > > [0]PETSC ERROR: [0] MatAssemblyEnd line 5185
> > > [0]PETSC ERROR: [1]PETSC ERROR:       is given.
> > > [1]PETSC ERROR: [1] MatAssemblyEnd line 5185
> > > [0] MatAssemblyBegin line 5090 /home/valera/petsc-3.7.2/src/
> > > [0]PETSC ERROR: [0] MatSetNearNullSpace line 8191
> > > [0]PETSC ERROR: [1]PETSC ERROR: [1] MatAssemblyBegin line 5090
> > > [1]PETSC ERROR: [0] PetscSplitOwnership line 80
> > > [0]PETSC ERROR: [0] PetscLayoutSetUp line 129
> > > [0]PETSC ERROR: [0] MatMPIAIJSetPreallocation_MPIAIJ line 2767
> > > [1] MatSetNearNullSpace line 8191 /home/valera/petsc-3.7.2/src/
> > > [1]PETSC ERROR: [1] PetscSplitOwnership line 80
> > > [1]PETSC ERROR: [0]PETSC ERROR: [0] MatMPIAIJSetPreallocation line
> 3502 /home/valera/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c
> > > [0]PETSC ERROR: [0] MatSetUp_MPIAIJ line 2152
> > > [1] PetscLayoutSetUp line 129 /home/valera/petsc-3.7.2/src/
> vec/is/utils/pmap.c
> > > [1]PETSC ERROR: [1] MatMPIAIJSetPreallocation_MPIAIJ line 2767
> > > [0]PETSC ERROR: [0] MatSetUp line 727 /home/valera/petsc-3.7.2/src/
> > > [0]PETSC ERROR: [0] MatCreate_SeqAIJ line 3956
> > > [1]PETSC ERROR: [1] MatMPIAIJSetPreallocation line 3502
> > > [1]PETSC ERROR: [1] MatSetUp_MPIAIJ line 2152
> > > [0]PETSC ERROR: [0] MatSetType line 44 /home/valera/petsc-3.7.2/src/
> > > [0]PETSC ERROR: [0] MatCreateSeqAIJWithArrays line 4295
> > > [1]PETSC ERROR: [1] MatSetUp line 727 /home/valera/petsc-3.7.2/src/
> > > [1]PETSC ERROR: [1] MatCreate_SeqAIJ line 3956
> > > [0]PETSC ERROR: Signal received
> > > [1]PETSC ERROR: [1] MatSetType line 44 /home/valera/petsc-3.7.2/src/
> > > [1]PETSC ERROR: [1] MatCreateSeqAIJWithArrays line 4295
>                                                   P on a
> > > [1]PETSC ERROR: #12 User provided function() line 0 in  unknown file
>                                                   P on a
> > > application called MPI_Abort(comm=0x84000004, 59) - process 0
> > > [cli_0]: aborting job:
> > > application called MPI_Abort(comm=0x84000002, 59) - process 1
> > > [cli_1]: aborting job:
> > > =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> > > =   PID 10266 RUNNING AT cinci
> > > =   EXIT CODE: 59
> > > =   CLEANING UP REMAINING PROCESSES
> > > =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> > > On Mon, Sep 26, 2016 at 3:51 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > > Ok, i created a tiny testcase just for this,
> > > The output from n# calls are as follows:
> > > n1:
> > > Mat Object: 1 MPI processes
> > >   type: mpiaij
> > > row 0: (0, 1.)  (1, 2.)  (2, 4.)  (3, 3.)
> > > row 1: (0, 2.)  (1, 1.)  (2, 3.)  (3, 4.)
> > > row 2: (0, 4.)  (1, 3.)  (2, 1.)  (3, 2.)
> > > row 3: (0, 3.)  (1, 4.)  (2, 2.)  (3, 1.)
> > > n2:
> > > Mat Object: 2 MPI processes
> > >   type: mpiaij
> > > row 2: (0, 1.)  (1, 2.)  (2, 4.)  (3, 3.)
> > > row 3: (0, 2.)  (1, 1.)  (2, 3.)  (3, 4.)
> > > n4:
> > > Mat Object: 4 MPI processes
> > >   type: mpiaij
> > > row 1: (0, 1.)  (1, 2.)  (2, 4.)  (3, 3.)
> > > row 3: (0, 1.)  (1, 2.)  (2, 4.)  (3, 3.)
> > > It really gets messed, no idea what's happening.
> > > On Mon, Sep 26, 2016 at 3:12 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > On Sep 26, 2016, at 5:07 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > > > Ok i was using a big matrix before, from a smaller testcase i got
> the output and effectively, it looks like is not well read at all, results
> are attached for DRAW viewer, output is too big to use STDOUT even in the
> small testcase. n# is the number of processors requested.
> > >    You need to construct a very small test case so you can determine
> why the values do not end up where you expect them. There is no way around
> it.
> > > > is there a way to create the matrix in one node and the distribute
> it as needed on the rest ? maybe that would work.
> > >    No the is not scalable. You become limited by the memory of the one
> node.
> > > > Thanks
> > > > On Mon, Sep 26, 2016 at 2:40 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > >     How large is the matrix? It will take a very long time if the
> matrix is large. Debug with a very small matrix.
> > > >   Barry
> > > > > On Sep 26, 2016, at 4:34 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > > > > Indeed there is something wrong with that call, it hangs out
> indefinitely showing only:
> > > > >   type: mpiaij
> > > > > It draws my attention that this program works for 1 processor but
> not more, but it doesnt show anything for that viewer in either case.
> > > > > Thanks for the insight on the redundant calls, this is not very
> clear on documentation, which calls are included in others.
> > > > > On Mon, Sep 26, 2016 at 2:02 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > >    The call to MatCreateMPIAIJWithArrays() is likely interpreting
> the values you pass in different than you expect.
> > > > >     Put a call to MatView(Ap,PETSC_VIEWER_STDOUT_WORLD,ierr)
> after the MatCreateMPIAIJWithArray() to see what PETSc thinks the matrix is.
> > > > > > On Sep 26, 2016, at 3:42 PM, Manuel Valera <
> mvalera at mail.sdsu.edu> wrote:
> > > > > > Hello,
> > > > > > I'm working on solve a linear system in parallel, following ex12
> of the ksp tutorial i don't see major complication on doing so, so for a
> working linear system solver with PCJACOBI and KSPGCR i did only the
> following changes:
> > > > > >    call MatCreate(PETSC_COMM_WORLD,Ap,ierr)
> > > > > > !  call MatSetType(Ap,MATSEQAIJ,ierr)
> > > > > >   call MatSetType(Ap,MATMPIAIJ,ierr) !paralellization
> > > > > >   call MatSetSizes(Ap,PETSC_DECIDE,PETSC_DECIDE,nbdp,nbdp,ierr);
> > > > > > !  call MatSeqAIJSetPreallocationCSR(Ap,iapi,japi,app,ierr)
> > > > > >   call MatSetFromOptions(Ap,ierr)
> > > > >     Note that none of the lines above are needed (or do anything)
> because the MatCreateMPIAIJWithArrays() creates the matrix from scratch
> itself.
> > > > >    Barry
> > > > > > !  call MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD,nbdp,nbdp,
> iapi,japi,app,Ap,ierr)
> > > > > >  call MatCreateMPIAIJWithArrays(PETSC_COMM_WORLD,floor(real(
> nbdp)/sizel),PETSC_DECIDE,nbdp,nbdp,iapi,japi,app,Ap,ierr)
> > > > > > I grayed out the changes from sequential implementation.
> > > > > > So, it does not complain at runtime until it reaches KSPSolve(),
> with the following error:
> > > > > > [1]PETSC ERROR: Matrix is missing diagonal entry 0
> > > > > > [1]PETSC ERROR: Petsc Release Version 3.7.3, unknown
>                                                         � � on a
> arch-linux2-c-debug named valera-HP-xw4600-Workstation by valera Mon Sep 26
> 13:35:15 2016
> --with-fc=gfortran --download-fblaslapack=1 --download-mpich=1
> --download-ml=1
> > > > > > [1]PETSC ERROR: #1 MatILUFactorSymbolic_SeqAIJ() line 1733 in
> /home/valera/v5PETSc/petsc/petsc/src/mat/impls/aij/seq/aijfact.c
> > > > > > [1]PETSC ERROR: #2 MatILUFactorSymbolic() line 6579 in
> /home/valera/v5PETSc/petsc/petsc/src/mat/interface/matrix.c
> > > > > > [1]PETSC ERROR: #3 PCSetUp_ILU() line 212 in
> /home/valera/v5PETSc/petsc/petsc/src/ksp/pc/impls/factor/ilu/ilu.c
> > > > > > [1]PETSC ERROR: #4 PCSetUp() line 968 in
> /home/valera/v5PETSc/petsc/petsc/src/ksp/pc/interface/precon.c
> > > > > > [1]PETSC ERROR: #5 KSPSetUp() line 390 in
> /home/valera/v5PETSc/petsc/petsc/src/ksp/ksp/interface/itfunc.c
> > > > > > [1]PETSC ERROR: #6 PCSetUpOnBlocks_BJacobi_Singleblock() line
> 650 in /home/valera/v5PETSc/petsc/petsc/src/ksp/pc/impls/bjacobi/bjacobi.c
> > > > > > [1]PETSC ERROR: #7 PCSetUpOnBlocks() line 1001 in
> > > > > > [1]PETSC ERROR: #8 KSPSetUpOnBlocks() line 220 in
> > > > > > [1]PETSC ERROR: #9 KSPSolve() line 600 in
> > > > > > At line 333 of file solvelinearmgPETSc.f90
> > > > > > Fortran runtime error: Array bound mismatch for dimension 1 of
> array 'sol' (213120/106560)
> > > > > > This code works for -n 1 cores, but it gives this error when
> using more than one core.
> > > > > > What am i missing?
> > > > > > Regards,
> > > > > > Manuel.
> > > > > > <solvelinearmgPETSc.f90>
> > > > <n4.png><n2.png><n1.png>
> > > <rhss.txt><solvelinearmgPETSc.f90><as.txt><ias.txt><jas.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160930/b18418b4/attachment-0001.html>
