[petsc-users] MATELEMENTAL strange behaviour
Bernard Knaepen
bknaepen at ulb.ac.be
Fri Sep 30 14:20:25 CDT 2016
Hi Hong,
I tested the fix and it works perfectly.
Thanks for this rapid feedback.
Best regards,
Bernard.
> On 29 Sep 2016, at 17:57, Hong <hzhang at mcs.anl.gov <mailto:hzhang at mcs.anl.gov>> wrote:
> Bernard,
> The bug is fixed in branch hzhang/fix-elementalSetOption.
> https://bitbucket.org/petsc/petsc/commits/891a05710665f381fc66132810d0b09973b0e049 <https://bitbucket.org/petsc/petsc/commits/891a05710665f381fc66132810d0b09973b0e049>
> It will be merged to petsc-release after night tests.
> Thanks for reporting it!
> Hong
> On Wed, Sep 28, 2016 at 8:04 PM, Hong <hzhang at mcs.anl.gov <mailto:hzhang at mcs.anl.gov>> wrote:
> Bernard:
> With your code, I reproduced error and found that the default
> MAT_ROW_ORIENTED for MatSetValues() is changed to MAT_COLUMN_ORIENTED. This is a bug in our library. I'll fix it.
> You can add
> MatSetOption(C,MAT_ROW_ORIENTED,PETSC_TRUE);
> before 2nd call of matrixC(C,t).
> Thanks for reporting the bug.
> Hong
> Hello,
> Here is a trimmed down piece of code that illustrates a strange behaviour that I am desperately trying to understand.
> The problem is that I would expect successive calls to MatView(C,…) to display the same numbers. However, the numbers displayed are different, even though the content of the matrix C should be the same.
> Any help to resolve this would be appreciated.
> Cheers,
> Bernard.
> Code:
> static char help[] = "Elemental test\n\n";
> /*T
> T*/
> #include <petscmat.h>
> PetscScalar pi=3.141592653589793;
> /* Prototypes */
> PetscErrorCode matrixC(Mat C, PetscScalar t);
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc, char **args){
> Mat C;
> PetscInt N = 8;
> PetscScalar t=0.1, dt=0.0001;
> PetscErrorCode ierr;
> /* parameters */
> ierr = PetscInitialize(&argc, &args, (char*) 0, help) ;CHKERRQ(ierr);
> ierr = MatCreate(PETSC_COMM_WORLD, &C); CHKERRQ(ierr);
> ierr = MatSetSizes(C, PETSC_DECIDE, PETSC_DECIDE, N, N); CHKERRQ(ierr);
> ierr = MatSetType(C, MATELEMENTAL); CHKERRQ(ierr);
> ierr = MatSetFromOptions(C); CHKERRQ(ierr);
> ierr = MatSetUp(C); CHKERRQ(ierr);
> ierr=matrixC(C,t);
> ierr = MatView(C,PETSC_VIEWER_STDOUT_WORLD);
> ierr=matrixC(C,t);
> ierr = MatDestroy(&C);CHKERRQ(ierr);
> ierr = PetscFinalize();
> return ierr;
> /* Matrix C*/
> PetscErrorCode matrixC(Mat C, PetscScalar t){
> IS isrows,iscols;
> const PetscInt *rows,*cols;
> PetscScalar *v;
> PetscInt i,j,nrows,ncols;
> PetscInt n,m;
> /* Set local matrix entries */
> ierr = MatGetOwnershipIS(C,&isrows,&iscols);CHKERRQ(ierr);
> ierr = ISGetLocalSize(isrows,&nrows);CHKERRQ(ierr);
> ierr = ISGetIndices(isrows,&rows);CHKERRQ(ierr);
> ierr = ISGetLocalSize(iscols,&ncols);CHKERRQ(ierr);
> ierr = ISGetIndices(iscols,&cols);CHKERRQ(ierr);
> ierr = PetscMalloc1(nrows*ncols,&v);CHKERRQ(ierr);
> for (i=0; i<nrows; i++) {
> n=rows[i];
> for (j=0; j<ncols; j++) {
> m=cols[j];
> v[i*ncols+j] = -0.5*(exp(-(m+n+1.5)*(m+n+1.5)*pi*pi*t)-exp(-(m-n+0.5)*(m-n+0.5)*pi*pi*t));
> ierr = MatSetValues(C,nrows,rows,ncols,cols,v,INSERT_VALUES);CHKERRQ(ierr);
> ierr = MatAssemblyBegin(C,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatAssemblyEnd(C,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = ISRestoreIndices(isrows,&rows);CHKERRQ(ierr);
> ierr = ISRestoreIndices(iscols,&cols);CHKERRQ(ierr);
> ierr = ISDestroy(&isrows);CHKERRQ(ierr);
> ierr = ISDestroy(&iscols);CHKERRQ(ierr);
> ierr = PetscFree(v);CHKERRQ(ierr);
> PetscFunctionReturn(0);
> Output:
> mpirun -n 2 ./elemental
> Mat Object: 2 MPI processes
> type: elemental
> Elemental matrix (cyclic ordering)
> 0.336403 2.8059e-06 0.0532215 1.04511e-09 0.00104438
> 0.00104718 0.390672 0.0542687 0.0542687 0.390672
> 0.389625 0.00104718 0.390669 2.80695e-06 0.0542687
> 2.80695e-06 0.390672 0.00104718 0.390672 0.0542687
> 0.0542659 0.0542687 0.390672 0.00104718 0.390672
> Elemental matrix (explicit ordering)
> type: mpidense
> 3.3640319378153799e-01 5.3221486768492490e-02 1.0443777750910219e-03 2.8059034408741489e-06 1.0451056906250189e-09
> 3.8962468055003047e-01 3.9066905832512150e-01 5.4268670447024388e-02 1.0471847236375868e-03 2.8069486006233780e-06
> 5.4265864543583515e-02 3.9067186422856237e-01 3.9067186527366804e-01 5.4268671492184138e-02 1.0471847236916457e-03
> 1.0471836785318962e-03 5.4268671492130077e-02 3.9067186527372211e-01 3.9067186527372211e-01 5.4268671492184138e-02
> 2.8069485465647739e-06 1.0471847236916453e-03 5.4268671492184138e-02 3.9067186527372211e-01 3.9067186527372211e-01
> type: elemental
> 0.336403 2.8059e-06 0.390672 2.80695e-06 0.00104718
> 0.0532215 1.04511e-09 0.389625 0.390672 0.0542687
> 0.00104438 0.390672 0.390669 0.390672 0.0542659
> 0.00104718 0.0542687 0.0542687 0.0542687 0.390672
> 0.0542687 0.00104718 2.80695e-06 0.00104718 0.390672
> type: mpidense
> 3.3640319378153799e-01 3.9067186527372211e-01 1.0471847236916453e-03 2.8059034408741489e-06 2.8069486006233780e-06
> 1.0443777750910219e-03 3.9066905832512150e-01 5.4265864543583515e-02 3.9067186527372211e-01 3.9067186527372211e-01
> 5.4268671492130077e-02 2.8069485465647739e-06 3.9067186527366804e-01 1.0471847236375868e-03 1.0471847236916457e-03
> 5.3221486768492490e-02 3.8962468055003047e-01 5.4268671492184138e-02 1.0451056906250189e-09 3.9067186527372211e-01
> 1.0471836785318962e-03 5.4268670447024388e-02 3.9067186422856237e-01 5.4268671492184138e-02 5.4268671492184138e-02
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160930/975bfb85/attachment.html>
