[petsc-users] Solve KSP in parallel.
Manuel Valera
mvalera at mail.sdsu.edu
Tue Sep 27 15:13:28 CDT 2016
Barry, thanks for your insight,
This standalone script must be translated into a much bigger model, which
uses AIJ matrices to define the laplacian in the form of the 3 usual
arrays, the ascii files in the script take the place of the arrays which
are passed to the solving routine in the model.
So, can i use the approach you mention to create the MPIAIJ from the petsc
binary file ? would this be a better solution than reading the three arrays
directly? In the model, even the smallest matrix is 10^5x10^5 elements
Thanks.
On Tue, Sep 27, 2016 at 12:53 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Are you loading a matrix from an ASCII file? If so don't do that. You
> should write a simple sequential PETSc program that reads in the ASCII file
> and saves the matrix as a PETSc binary file with MatView(). Then write your
> parallel code that reads in the binary file with MatLoad() and solves the
> system. You can read in the right hand side from ASCII and save it in the
> binary file also. Trying to read an ASCII file in parallel and set it into
> a PETSc parallel matrix is just a totally thankless task that is
> unnecessary.
> Barry
> > On Sep 26, 2016, at 6:40 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > Ok, last output was from simulated multicores, in an actual cluster the
> errors are of the kind:
> > [valera at cinci CSRMatrix]$ petsc -n 2 ./solvelinearmgPETSc
> > TrivSoln loaded, size: 4 / 4
> > RHS loaded, size: 4 / 4
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Argument out of range
> > [0]PETSC ERROR: Comm must be of size 1
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
> > [0]PETSC ERROR: ./solvelinearmgPETSc
> P on a arch-linux2-c-debug
> named cinci by valera Mon Sep 26 16:39:02 2016
> > [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
> > [1]PETSC ERROR: Argument out of range
> > [1]PETSC ERROR: Comm must be of size 1
> > [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> > [1]PETSC ERROR: Petsc Release Version 3.7.2, Jun, 05, 2016
> > [1]PETSC ERROR: ./solvelinearmgPETSc
> > [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> --with-fc=gfortran --download-fblaslapack=1 --download-mpich
> > [1]PETSC ERROR: #1 MatCreate_SeqAIJ() line 3958 in
> /home/valera/petsc-3.7.2/src/mat/impls/aij/seq/aij.c
> > [1]PETSC ERROR: #2 MatSetType() line 94 in /home/valera/petsc-3.7.2/src/
> mat/interface/matreg.c
> > [1]PETSC ERROR: #3 MatCreateSeqAIJWithArrays() line 4300 in
> > local size: 2
> > local size: 2
> > Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> > [0]PETSC ERROR: #1 MatCreate_SeqAIJ() line 3958 in
> > [0]PETSC ERROR: #2 MatSetType() line 94 in /home/valera/petsc-3.7.2/src/
> > [0]PETSC ERROR: #3 MatCreateSeqAIJWithArrays() line 4300 in
> > [1]PETSC ERROR: [0]PETSC ERROR: Nonconforming object sizes
> > [0]PETSC ERROR: Sum of local lengths 8 does not equal global length 4,
> my local length 4
> > likely a call to VecSetSizes() or MatSetSizes() is wrong.
> > See http://www.mcs.anl.gov/petsc/documentation/faq.html#split
> > [1]PETSC ERROR: Sum of local lengths 8 does not equal global length 4,
> my local length 4
> > [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
> > [0]PETSC ERROR: #4 PetscSplitOwnership() line 93 in
> /home/valera/petsc-3.7.2/src/sys/utils/psplit.c
> > [1]PETSC ERROR: #4 PetscSplitOwnership() line 93 in
> > [0]PETSC ERROR: #5 PetscLayoutSetUp() line 143 in
> /home/valera/petsc-3.7.2/src/vec/is/utils/pmap.c
> > [0]PETSC ERROR: #6 MatMPIAIJSetPreallocation_MPIAIJ() line 2768 in
> /home/valera/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c
> > [1]PETSC ERROR: #5 PetscLayoutSetUp() line 143 in
> > [1]PETSC ERROR: [0]PETSC ERROR: #7 MatMPIAIJSetPreallocation() line 3505
> in /home/valera/petsc-3.7.2/src/mat/impls/aij/mpi/mpiaij.c
> > [1]PETSC ERROR: [0]PETSC ERROR: #8 MatSetUp_MPIAIJ() line 2153 in
> > #7 MatMPIAIJSetPreallocation() line 3505 in /home/valera/petsc-3.7.2/src/
> > [1]PETSC ERROR: #8 MatSetUp_MPIAIJ() line 2153 in
> > [0]PETSC ERROR: #9 MatSetUp() line 739 in /home/valera/petsc-3.7.2/src/
> mat/interface/matrix.c
> > [1]PETSC ERROR: #9 MatSetUp() line 739 in /home/valera/petsc-3.7.2/src/
> > [0]PETSC ERROR: Object is in wrong state
> > [0]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
> argument 1 "mat" before MatSetNearNullSpace()
> > [1]PETSC ERROR: Must call MatXXXSetPreallocation() or MatSetUp() on
> > [1]PETSC ERROR: [0]PETSC ERROR: Configure options --with-cc=gcc
> --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=1 --download-mpich
> > [0]PETSC ERROR: #10 MatSetNearNullSpace() line 8195 in
> /home/valera/petsc-3.7.2/src/mat/interface/matrix.c
> > See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> shooting.
> > [1]PETSC ERROR: #10 MatSetNearNullSpace() line 8195 in
> argument 1 "mat" before MatAssemblyBegin()
> > [0]PETSC ERROR: [1]PETSC ERROR: Object is in wrong state
> > [1]PETSC ERROR: #11 MatAssemblyBegin() line 5093 in
> > [0]PETSC ERROR: ------------------------------
> > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> > [1]PETSC ERROR: ------------------------------
> > [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > [1]PETSC ERROR: [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> > [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> documentation/faq.html#valgrind
> > [1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> > [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS X to find memory corruption errors
> > or try http://valgrind.org on GNU/linux and Apple Mac OS X to find
> > [0]PETSC ERROR: likely location of problem given in stack below
> > [0]PETSC ERROR: --------------------- Stack Frames
> > [1]PETSC ERROR: likely location of problem given in stack below
> > [1]PETSC ERROR: --------------------- Stack Frames
> > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > [0]PETSC ERROR: INSTEAD the line number of the start of the
> function
> > [0]PETSC ERROR: [1]PETSC ERROR: Note: The EXACT line numbers in the
> stack are not available,
> > [1]PETSC ERROR: INSTEAD the line number of the start of the
> function
> > is given.
> > [0]PETSC ERROR: [0] MatAssemblyEnd line 5185
> > [0]PETSC ERROR: [1]PETSC ERROR: is given.
> > [1]PETSC ERROR: [1] MatAssemblyEnd line 5185
> > [0] MatAssemblyBegin line 5090 /home/valera/petsc-3.7.2/src/
> > [0]PETSC ERROR: [0] MatSetNearNullSpace line 8191
> > [0]PETSC ERROR: [1]PETSC ERROR: [1] MatAssemblyBegin line 5090
> > [1]PETSC ERROR: [0] PetscSplitOwnership line 80
> > [0]PETSC ERROR: [0] PetscLayoutSetUp line 129
> > [0]PETSC ERROR: [0] MatMPIAIJSetPreallocation_MPIAIJ line 2767
> > [1] MatSetNearNullSpace line 8191 /home/valera/petsc-3.7.2/src/
> > [1]PETSC ERROR: [1] PetscSplitOwnership line 80
> > [1]PETSC ERROR: [0]PETSC ERROR: [0] MatMPIAIJSetPreallocation line 3502
> > [0]PETSC ERROR: [0] MatSetUp_MPIAIJ line 2152
> > [1] PetscLayoutSetUp line 129 /home/valera/petsc-3.7.2/src/
> vec/is/utils/pmap.c
> > [1]PETSC ERROR: [1] MatMPIAIJSetPreallocation_MPIAIJ line 2767
> > [0]PETSC ERROR: [0] MatSetUp line 727 /home/valera/petsc-3.7.2/src/
> > [0]PETSC ERROR: [0] MatCreate_SeqAIJ line 3956
> > [1]PETSC ERROR: [1] MatMPIAIJSetPreallocation line 3502
> > [1]PETSC ERROR: [1] MatSetUp_MPIAIJ line 2152
> > [0]PETSC ERROR: [0] MatSetType line 44 /home/valera/petsc-3.7.2/src/
> > [0]PETSC ERROR: [0] MatCreateSeqAIJWithArrays line 4295
> > [1]PETSC ERROR: [1] MatSetUp line 727 /home/valera/petsc-3.7.2/src/
> > [1]PETSC ERROR: [1] MatCreate_SeqAIJ line 3956
> > [0]PETSC ERROR: Signal received
> > [1]PETSC ERROR: [1] MatSetType line 44 /home/valera/petsc-3.7.2/src/
> > [1]PETSC ERROR: [1] MatCreateSeqAIJWithArrays line 4295
> > [1]PETSC ERROR: #12 User provided function() line 0 in unknown file
> > application called MPI_Abort(comm=0x84000004, 59) - process 0
> > [cli_0]: aborting job:
> > application called MPI_Abort(comm=0x84000002, 59) - process 1
> > [cli_1]: aborting job:
> > = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> > = PID 10266 RUNNING AT cinci
> > = EXIT CODE: 59
> > = CLEANING UP REMAINING PROCESSES
> > = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> > On Mon, Sep 26, 2016 at 3:51 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > Ok, i created a tiny testcase just for this,
> > The output from n# calls are as follows:
> > n1:
> > Mat Object: 1 MPI processes
> > type: mpiaij
> > row 0: (0, 1.) (1, 2.) (2, 4.) (3, 3.)
> > row 1: (0, 2.) (1, 1.) (2, 3.) (3, 4.)
> > row 2: (0, 4.) (1, 3.) (2, 1.) (3, 2.)
> > row 3: (0, 3.) (1, 4.) (2, 2.) (3, 1.)
> > n2:
> > Mat Object: 2 MPI processes
> > type: mpiaij
> > row 2: (0, 1.) (1, 2.) (2, 4.) (3, 3.)
> > row 3: (0, 2.) (1, 1.) (2, 3.) (3, 4.)
> > n4:
> > Mat Object: 4 MPI processes
> > type: mpiaij
> > row 1: (0, 1.) (1, 2.) (2, 4.) (3, 3.)
> > row 3: (0, 1.) (1, 2.) (2, 4.) (3, 3.)
> > It really gets messed, no idea what's happening.
> > On Mon, Sep 26, 2016 at 3:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > > On Sep 26, 2016, at 5:07 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > > Ok i was using a big matrix before, from a smaller testcase i got the
> output and effectively, it looks like is not well read at all, results are
> attached for DRAW viewer, output is too big to use STDOUT even in the small
> testcase. n# is the number of processors requested.
> > You need to construct a very small test case so you can determine why
> the values do not end up where you expect them. There is no way around it.
> > > is there a way to create the matrix in one node and the distribute it
> as needed on the rest ? maybe that would work.
> > No the is not scalable. You become limited by the memory of the one
> node.
> > > Thanks
> > > On Mon, Sep 26, 2016 at 2:40 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > How large is the matrix? It will take a very long time if the
> matrix is large. Debug with a very small matrix.
> > > Barry
> > > > On Sep 26, 2016, at 4:34 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > > > Indeed there is something wrong with that call, it hangs out
> indefinitely showing only:
> > > > type: mpiaij
> > > > It draws my attention that this program works for 1 processor but
> not more, but it doesnt show anything for that viewer in either case.
> > > > Thanks for the insight on the redundant calls, this is not very
> clear on documentation, which calls are included in others.
> > > > On Mon, Sep 26, 2016 at 2:02 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > The call to MatCreateMPIAIJWithArrays() is likely interpreting
> the values you pass in different than you expect.
> > > > Put a call to MatView(Ap,PETSC_VIEWER_STDOUT_WORLD,ierr) after
> the MatCreateMPIAIJWithArray() to see what PETSc thinks the matrix is.
> > > > > On Sep 26, 2016, at 3:42 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > > > > Hello,
> > > > > I'm working on solve a linear system in parallel, following ex12
> of the ksp tutorial i don't see major complication on doing so, so for a
> working linear system solver with PCJACOBI and KSPGCR i did only the
> following changes:
> > > > > call MatCreate(PETSC_COMM_WORLD,Ap,ierr)
> > > > > ! call MatSetType(Ap,MATSEQAIJ,ierr)
> > > > > call MatSetType(Ap,MATMPIAIJ,ierr) !paralellization
> > > > > call MatSetSizes(Ap,PETSC_DECIDE,PETSC_DECIDE,nbdp,nbdp,ierr);
> > > > > ! call MatSeqAIJSetPreallocationCSR(Ap,iapi,japi,app,ierr)
> > > > > call MatSetFromOptions(Ap,ierr)
> > > > Note that none of the lines above are needed (or do anything)
> because the MatCreateMPIAIJWithArrays() creates the matrix from scratch
> itself.
> > > > Barry
> > > > > ! call MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD,nbdp,nbdp,
> iapi,japi,app,Ap,ierr)
> > > > > call MatCreateMPIAIJWithArrays(PETSC_COMM_WORLD,floor(real(
> nbdp)/sizel),PETSC_DECIDE,nbdp,nbdp,iapi,japi,app,Ap,ierr)
> > > > > I grayed out the changes from sequential implementation.
> > > > > So, it does not complain at runtime until it reaches KSPSolve(),
> with the following error:
> > > > > [1]PETSC ERROR: Matrix is missing diagonal entry 0
> documentation/faq.html for trouble shooting.
> > > > > [1]PETSC ERROR: Petsc Release Version 3.7.3, unknown
> � � on a
> arch-linux2-c-debug named valera-HP-xw4600-Workstation by valera Mon Sep 26
> 13:35:15 2016
> --with-fc=gfortran --download-fblaslapack=1 --download-mpich=1
> --download-ml=1
> > > > > [1]PETSC ERROR: #1 MatILUFactorSymbolic_SeqAIJ() line 1733 in
> /home/valera/v5PETSc/petsc/petsc/src/mat/impls/aij/seq/aijfact.c
> > > > > [1]PETSC ERROR: #2 MatILUFactorSymbolic() line 6579 in
> /home/valera/v5PETSc/petsc/petsc/src/mat/interface/matrix.c
> > > > > [1]PETSC ERROR: #3 PCSetUp_ILU() line 212 in
> /home/valera/v5PETSc/petsc/petsc/src/ksp/pc/impls/factor/ilu/ilu.c
> > > > > [1]PETSC ERROR: #4 PCSetUp() line 968 in
> /home/valera/v5PETSc/petsc/petsc/src/ksp/pc/interface/precon.c
> > > > > [1]PETSC ERROR: #5 KSPSetUp() line 390 in
> /home/valera/v5PETSc/petsc/petsc/src/ksp/ksp/interface/itfunc.c
> > > > > [1]PETSC ERROR: #6 PCSetUpOnBlocks_BJacobi_Singleblock() line 650
> in /home/valera/v5PETSc/petsc/petsc/src/ksp/pc/impls/bjacobi/bjacobi.c
> > > > > [1]PETSC ERROR: #7 PCSetUpOnBlocks() line 1001 in
> > > > > [1]PETSC ERROR: #8 KSPSetUpOnBlocks() line 220 in
> > > > > [1]PETSC ERROR: #9 KSPSolve() line 600 in
> > > > > At line 333 of file solvelinearmgPETSc.f90
> > > > > Fortran runtime error: Array bound mismatch for dimension 1 of
> array 'sol' (213120/106560)
> > > > > This code works for -n 1 cores, but it gives this error when using
> more than one core.
> > > > > What am i missing?
> > > > > Regards,
> > > > > Manuel.
> > > > > <solvelinearmgPETSc.f90>
> > > <n4.png><n2.png><n1.png>
> > <rhss.txt><solvelinearmgPETSc.f90><as.txt><ias.txt><jas.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160927/5d473d12/attachment-0001.html>
