[petsc-users] Solve KSP in parallel.
Barry Smith
bsmith at mcs.anl.gov
Mon Sep 26 16:02:14 CDT 2016
The call to MatCreateMPIAIJWithArrays() is likely interpreting the values you pass in different than you expect.
Put a call to MatView(Ap,PETSC_VIEWER_STDOUT_WORLD,ierr) after the MatCreateMPIAIJWithArray() to see what PETSc thinks the matrix is.
> On Sep 26, 2016, at 3:42 PM, Manuel Valera <mvalera at mail.sdsu.edu> wrote:
> Hello,
> I'm working on solve a linear system in parallel, following ex12 of the ksp tutorial i don't see major complication on doing so, so for a working linear system solver with PCJACOBI and KSPGCR i did only the following changes:
> call MatCreate(PETSC_COMM_WORLD,Ap,ierr)
> ! call MatSetType(Ap,MATSEQAIJ,ierr)
> call MatSetType(Ap,MATMPIAIJ,ierr) !paralellization
> call MatSetSizes(Ap,PETSC_DECIDE,PETSC_DECIDE,nbdp,nbdp,ierr);
> ! call MatSeqAIJSetPreallocationCSR(Ap,iapi,japi,app,ierr)
> call MatSetFromOptions(Ap,ierr)
Note that none of the lines above are needed (or do anything) because the MatCreateMPIAIJWithArrays() creates the matrix from scratch itself.
Barry
> ! call MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD,nbdp,nbdp,iapi,japi,app,Ap,ierr)
> call MatCreateMPIAIJWithArrays(PETSC_COMM_WORLD,floor(real(nbdp)/sizel),PETSC_DECIDE,nbdp,nbdp,iapi,japi,app,Ap,ierr)
> I grayed out the changes from sequential implementation.
> So, it does not complain at runtime until it reaches KSPSolve(), with the following error:
> [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [1]PETSC ERROR: Object is in wrong state
> [1]PETSC ERROR: Matrix is missing diagonal entry 0
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.7.3, unknown
> [1]PETSC ERROR: ./solvelinearmgPETSc � � on a arch-linux2-c-debug named valera-HP-xw4600-Workstation by valera Mon Sep 26 13:35:15 2016
> [1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-fblaslapack=1 --download-mpich=1 --download-ml=1
> [1]PETSC ERROR: #1 MatILUFactorSymbolic_SeqAIJ() line 1733 in /home/valera/v5PETSc/petsc/petsc/src/mat/impls/aij/seq/aijfact.c
> [1]PETSC ERROR: #2 MatILUFactorSymbolic() line 6579 in /home/valera/v5PETSc/petsc/petsc/src/mat/interface/matrix.c
> [1]PETSC ERROR: #3 PCSetUp_ILU() line 212 in /home/valera/v5PETSc/petsc/petsc/src/ksp/pc/impls/factor/ilu/ilu.c
> [1]PETSC ERROR: #4 PCSetUp() line 968 in /home/valera/v5PETSc/petsc/petsc/src/ksp/pc/interface/precon.c
> [1]PETSC ERROR: #5 KSPSetUp() line 390 in /home/valera/v5PETSc/petsc/petsc/src/ksp/ksp/interface/itfunc.c
> [1]PETSC ERROR: #6 PCSetUpOnBlocks_BJacobi_Singleblock() line 650 in /home/valera/v5PETSc/petsc/petsc/src/ksp/pc/impls/bjacobi/bjacobi.c
> [1]PETSC ERROR: #7 PCSetUpOnBlocks() line 1001 in /home/valera/v5PETSc/petsc/petsc/src/ksp/pc/interface/precon.c
> [1]PETSC ERROR: #8 KSPSetUpOnBlocks() line 220 in /home/valera/v5PETSc/petsc/petsc/src/ksp/ksp/interface/itfunc.c
> [1]PETSC ERROR: #9 KSPSolve() line 600 in /home/valera/v5PETSc/petsc/petsc/src/ksp/ksp/interface/itfunc.c
> At line 333 of file solvelinearmgPETSc.f90
> Fortran runtime error: Array bound mismatch for dimension 1 of array 'sol' (213120/106560)
> This code works for -n 1 cores, but it gives this error when using more than one core.
> What am i missing?
> Regards,
> Manuel.
> <solvelinearmgPETSc.f90>
