[petsc-users] Loading Laplacian as Module
Manuel Valera mvalera at mail.sdsu.edu
Fri Sep 23 14:07:26 CDT 2016
Barry, that was awesome, all the valgrind error dissappeared after using
the mpiexec from petsc folder, the more you know...
Anyway this is my output from valgrind running with those options:
 Last Update:  9/23/2016    12: 5:12
 ucmsSeamount Entering MAIN loop.
 RHS loaded, size:       213120 /      213120
 CSRMAt loaded, sizes:      213120 x      213120
   8.32709217     s
 solveP pass:           1
 CSRMAt loaded, sizes:      213120 x           0
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Wrong type of object: Parameter # 1
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.3, unknown
[0]PETSC ERROR: ./ucmsSeamount
                                             �J� on a arch-linux2-c-debug
named valera-HP-xw4600-Workstation by valera Fri Sep 23 12:05:03 2016
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --download-fblaslapack=1 --download-mpich=1
--download-ml=1
[0]PETSC ERROR: #1 MatGetSize() line 6295 in
/home/valera/v5PETSc/petsc/petsc/src/mat/interface/matrix.c
[0]PETSC ERROR: Wrong type of object: Parameter # 2
trouble shooting.
--download-ml=1
[0]PETSC ERROR: #2 KSPSetOperators() line 531 in
/home/valera/v5PETSc/petsc/petsc/src/ksp/ksp/interface/itcreate.c
[0]PETSC ERROR: Nonconforming object sizes
[0]PETSC ERROR: Preconditioner number of local rows -1 does not equal
resulting vector number of rows 213120
trouble shooting.
--download-ml=1
[0]PETSC ERROR: #3 PCApply() line 474 in
/home/valera/v5PETSc/petsc/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: Mat object's type is not set: Argument # 1
trouble shooting.
--download-ml=1
[0]PETSC ERROR: #4 MatGetFactorAvailable() line 4286 in
[0]PETSC ERROR: #5 PCGetDefaultType_Private() line 28 in
[0]PETSC ERROR: #6 PCSetFromOptions() line 159 in
/home/valera/v5PETSc/petsc/petsc/src/ksp/pc/interface/pcset.c
[0]PETSC ERROR: #7 KSPSetFromOptions() line 400 in
/home/valera/v5PETSc/petsc/petsc/src/ksp/ksp/interface/itcl.c
application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
[cli_0]: aborting job:
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   PID 6490 RUNNING AT valera-HP-xw4600-Workstation
=   EXIT CODE: 73
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
==6488==
==6488== HEAP SUMMARY:
==6488==     in use at exit: 131,120 bytes in 2 blocks
==6488==   total heap usage: 1,224 allocs, 1,222 frees, 249,285 bytes
allocated
==6488==
==6488== LEAK SUMMARY:
==6488==    definitely lost: 0 bytes in 0 blocks
==6488==    indirectly lost: 0 bytes in 0 blocks
==6488==      possibly lost: 0 bytes in 0 blocks
==6488==    still reachable: 131,120 bytes in 2 blocks
==6488==         suppressed: 0 bytes in 0 blocks
==6488== Rerun with --leak-check=full to see details of leaked memory
==6488==
==6488== For counts of detected and suppressed errors, rerun with: -v
==6488== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 0 from 0)
On Fri, Sep 23, 2016 at 11:15 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Sep 23, 2016, at 1:09 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > Thanks Barry, for the quick reply,
> > I tried doing that once recently, not for this problem though, but it
> looks like the model i'm working on isn't optimized at all for memory
> leaks, and valgrind stopped with thousands of errors before reaching this
> part of the execution.
>    Some MPI implementations by default produce many meaningless valgrind
> messages. So make sure you ./configure PETSc with --download-mpich this
> version will not produce any meaningless valgrind messages about MPI.
>    You are not concerned with "memory leaks" in this exercise, only with
> using uninitialized memory or overwriting memory you should not overwrite.
> So you want valgrind arguments like -q --tool=memcheck  --num-callers=20
> --track-origins=yes     you do not need --leak-check=yes
>    So run with valgrind and email use the output and we may have
> suggestions on the cause.
>    Barry
> > Is there maybe an alternative approach ? or it would be better to just
> get the model in better shape already ?
> > Thanks
> > On Fri, Sep 23, 2016 at 10:53 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> >   Run with valgrind to find the exact location of the first memory
> corruption. http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > > On Sep 23, 2016, at 12:47 PM, Manuel Valera <mvalera at mail.sdsu.edu>
> wrote:
> > > Hello all,
> > > I'm trying to load my laplacian matrix into a fortran module, and i
> have implemented it and it works for the first iteration of laplacian
> solver, but when starts the second step the laplacian matrix object becomes
> corrupts and looks like it loses one of it's dimensions.
> > > Can you help me understand whats happening?
> > > The modules are attached, the error i get is the following, i bolded
> the lines where i detected corruption:
> > >    8.39198399     s
> > >  solveP pass:           1      !Iteration number
> documentation/faq.html for trouble shooting.
>                                                   �J� on a
> arch-linux2-c-debug named valera-HP-xw4600-Workstation by valera Fri Sep 23
> 10:27:21 2016
> --download-ml=1
>                                                   �J� on a
> 10:27:21 2016
> --download-ml=1
>                                                   �J� on a
> 10:27:21 2016
> --download-ml=1
> > > [0]PETSC ERROR: #3 PCApply() line 474 in /home/valera/v5PETSc/petsc/
>                                                   �J� on a
> 10:27:21 2016
> --download-ml=1
> > > [unset]: aborting job:
> > > <LoadPetscMatrix.f90><SolvePetscLinear.f90>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160923/3addac72/attachment-0001.html>
