[petsc-users] Loading Laplacian as Module
Manuel Valera mvalera at mail.sdsu.edu
Fri Sep 23 12:47:21 CDT 2016
Hello all,
I'm trying to load my laplacian matrix into a fortran module, and i have
implemented it and it works for the first iteration of laplacian solver,
but when starts the second step the laplacian matrix object becomes
corrupts and looks like it loses one of it's dimensions.
Can you help me understand whats happening?
The modules are attached, the error i get is the following, i bolded the
lines where i detected corruption:
 ucmsSeamount Entering MAIN loop.
 RHS loaded, size:       213120 /      213120
 *CSRMAt loaded, sizes:      213120 x      213120*
   8.39198399     s
 solveP pass:           1      !Iteration number
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Wrong type of object: Parameter # 1
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.3, unknown
[0]PETSC ERROR: ./ucmsSeamount
                                             �J� on a arch-linux2-c-debug
named valera-HP-xw4600-Workstation by valera Fri Sep 23 10:27:21 2016
[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --download-fblaslapack=1 --download-mpich=1
--download-ml=1
[0]PETSC ERROR: #1 MatGetSize() line 6295 in
/home/valera/v5PETSc/petsc/petsc/src/mat/interface/matrix.c
* CSRMAt loaded, sizes:      213120 x           0*
[0]PETSC ERROR: Wrong type of object: Parameter # 2
trouble shooting.
--download-ml=1
[0]PETSC ERROR: #2 KSPSetOperators() line 531 in
/home/valera/v5PETSc/petsc/petsc/src/ksp/ksp/interface/itcreate.c
[0]PETSC ERROR: Nonconforming object sizes
[0]PETSC ERROR: Preconditioner number of local rows -1 does not equal
resulting vector number of rows 213120
trouble shooting.
--download-ml=1
[0]PETSC ERROR: #3 PCApply() line 474 in
/home/valera/v5PETSc/petsc/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: Mat object's type is not set: Argument # 1
trouble shooting.
--download-ml=1
[0]PETSC ERROR: #4 MatGetFactorAvailable() line 4286 in
[0]PETSC ERROR: #5 PCGetDefaultType_Private() line 28 in
[0]PETSC ERROR: #6 PCSetFromOptions() line 159 in
/home/valera/v5PETSc/petsc/petsc/src/ksp/pc/interface/pcset.c
[0]PETSC ERROR: #7 KSPSetFromOptions() line 400 in
/home/valera/v5PETSc/petsc/petsc/src/ksp/ksp/interface/itcl.c
application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
[unset]: aborting job:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160923/ce25eedd/attachment.html>
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160923/ce25eedd/attachment.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160923/ce25eedd/attachment-0001.bin>
