[petsc-users] Issue updating MUMPS ictnl after failed solve
Hong hzhang at mcs.anl.gov
Tue Sep 20 13:24:03 CDT 2016
David:
I'll patch petsc-maint (v3.7), then merge it to petsc-master.
It might take 1-2 days for regression tests.
Hong
On Tue, Sep 20, 2016 at 2:01 PM, Hong <hzhang at mcs.anl.gov> wrote:
>> David :
>> This is a bug in PETSc. A change
>> $ git diff ../../../pc/impls/factor/cholesky/cholesky.c
>> diff --git a/src/ksp/pc/impls/factor/cholesky/cholesky.c
>> b/src/ksp/pc/impls/factor/cholesky/cholesky.c
>> index 953d551..cc28369 100644
>> --- a/src/ksp/pc/impls/factor/cholesky/cholesky.c
>> +++ b/src/ksp/pc/impls/factor/cholesky/cholesky.c
>> @@ -141,9 +141,7 @@ static PetscErrorCode PCSetUp_Cholesky(PC pc)
>>      ierr = MatCholeskyFactorNumeric(((PC_Factor*)dir)->fact,pc->pmat,&(
>> (PC_Factor*)dir)->info);CHKERRQ(ierr);
>>      ierr = MatFactorGetError(((PC_Factor*)dir)->fact,&err);CHKERRQ(ierr
>> -    if (err) { /* FactorNumeric() fails */
>> -      pc->failedreason = (PCFailedReason)err;
>> +    pc->failedreason = (PCFailedReason)err;
>> fixed the problem. I'll fix this problem in petsc-release, including
>> other routines.
>> Thanks for reporting the bug and sending matrix.dat. Let us know whenever
>> you encounter problem using PETSc.
> OK, great, thanks for the fix.
> Will this fix be included in the next patch release of 3.7?
> Thanks,
> David
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160920/692477c0/attachment.html>
