[petsc-users] Issue updating MUMPS ictnl after failed solve
Hong
hzhang at mcs.anl.gov
Tue Sep 20 13:01:52 CDT 2016
David :
This is a bug in PETSc. A change
$ git diff ../../../pc/impls/factor/cholesky/cholesky.c
diff --git a/src/ksp/pc/impls/factor/cholesky/cholesky.c
b/src/ksp/pc/impls/factor/cholesky/cholesky.c
index 953d551..cc28369 100644
--- a/src/ksp/pc/impls/factor/cholesky/cholesky.c
+++ b/src/ksp/pc/impls/factor/cholesky/cholesky.c
@@ -141,9 +141,7 @@ static PetscErrorCode PCSetUp_Cholesky(PC pc)
ierr =
MatCholeskyFactorNumeric(((PC_Factor*)dir)->fact,pc->pmat,&((PC_Factor*)dir)->info);CHKERRQ(ierr);
ierr = MatFactorGetError(((PC_Factor*)dir)->fact,&err);CHKERRQ(ierr);
- if (err) { /* FactorNumeric() fails */
- pc->failedreason = (PCFailedReason)err;
+ pc->failedreason = (PCFailedReason)err;
fixed the problem. I'll fix this problem in petsc-release, including other
routines.
Thanks for reporting the bug and sending matrix.dat. Let us know whenever
you encounter problem using PETSc.
Hong
On Mon, Sep 19, 2016 at 11:04 PM, Hong <hzhang at mcs.anl.gov> wrote:
>> David :
>> I did following:
>> PC pc;
>> Mat F;
>> ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>> ierr = PCReset(pc);CHKERRQ(ierr);
>> ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
>> ierr = PCSetType(pc,PCCHOLESKY);CHKERRQ(ierr);
>> ierr = PCFactorSetMatSolverPackage(pc
>> ,MATSOLVERMUMPS);CHKERRQ(ierr);
>> ierr = PCFactorSetUpMatSolverPackage(pc);CHKERRQ(ierr);
>> ierr = PCFactorGetMatrix(pc,&F);CHKERRQ(ierr);
>> ierr = MatMumpsSetIcntl(F,14,30);CHKERRQ(ierr);
>> ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
>> Then it resolves the matrix equation with ICNTL(14)=30.
>> Attached is modified petsc/src/ksp/ksp/examples/tutorials/ex10.c.
>> Using in with your matrix.dat, I get
>> mpiexec -n 4 ./ex10 -f0 matrix.dat -rhs 0 -ksp_reason
>> Number of iterations = 0
>> KSPConvergedReason: -11
>> Reset PC with ICNTL(14)=30 ...
>> KSPConvergedReason: 2
> Hong,
> Thanks very much for your test code. I get the same output as you when I
> run "mpiexec -n 4 ./ex10 -f0 matrix.dat -rhs 0 -ksp_reason".
> However, I used KSPPREONLY in my original test code, and if I
> add KSPSetType(ksp,KSPPREONLY) in your modified exc10.c after the line
> KSPCreate(PETSC_COMM_WORLD,&ksp) then I get the following output:
> mpiexec -np 4 ./mumps_test-opt -f0 matrix.dat -rhs 0 -ksp_reason
> So it seems like the icntl data is not being updated when we use PREONLY.
> Do you know how to fix this?
> Thanks,
> David
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160920/b0aed163/attachment.html>
