[petsc-users] Issue updating MUMPS ictnl after failed solve
Hong
hzhang at mcs.anl.gov
Mon Sep 19 22:04:22 CDT 2016
David :
I did following:
PC pc;
Mat F;
ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
ierr = PCReset(pc);CHKERRQ(ierr);
ierr = KSPSetOperators(ksp,A,A);CHKERRQ(ierr);
ierr = PCSetType(pc,PCCHOLESKY);CHKERRQ(ierr);
ierr = PCFactorSetMatSolverPackage(pc,MATSOLVERMUMPS);CHKERRQ(ierr);
ierr = PCFactorSetUpMatSolverPackage(pc);CHKERRQ(ierr);
ierr = PCFactorGetMatrix(pc,&F);CHKERRQ(ierr);
ierr = MatMumpsSetIcntl(F,14,30);CHKERRQ(ierr);
ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
Then it resolves the matrix equation with ICNTL(14)=30.
Attached is modified petsc/src/ksp/ksp/examples/tutorials/ex10.c.
Using in with your matrix.dat, I get
mpiexec -n 4 ./ex10 -f0 matrix.dat -rhs 0 -ksp_reason
Number of iterations = 0
KSPConvergedReason: -11
Reset PC with ICNTL(14)=30 ...
KSPConvergedReason: 2
Hong
On Mon, Sep 19, 2016 at 9:45 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
>> Placing PCReset(PC pc) before the second kspsolve might works.
>> Fande Kong,
>> On Mon, Sep 19, 2016 at 7:38 PM, murat keçeli <keceli at gmail.com> wrote:
>>> Another guess: maybe you also need KSPSetUp(ksp); before the second
>>> KSPSolve(ksp,b,x);.
>>> Murat Keceli
> Thanks for the suggestions. I just tried these, and they didn't work
> either unfortunately.
> David
>>> On Mon, Sep 19, 2016 at 8:33 PM, David Knezevic <
>>> david.knezevic at akselos.com> wrote:
>>>> On Mon, Sep 19, 2016 at 7:26 PM, Dave May <dave.mayhem23 at gmail.com>
>>>> wrote:
>>>>> On 19 September 2016 at 21:05, David Knezevic <
>>>>>> When I use MUMPS via PETSc, one issue is that it can sometimes fail
>>>>>> with MUMPS error -9, which means that MUMPS didn't allocate a big enough
>>>>>> workspace. This can typically be fixed by increasing MUMPS icntl 14, e.g.
>>>>>> via the command line option -mat_mumps_icntl_14.
>>>>>> However, instead of having to run several times with different
>>>>>> command line options, I'd like to be able to automatically increment icntl
>>>>>> 14 value in a loop until the solve succeeds.
>>>>>> I have a saved matrix which fails when I use it for a solve with
>>>>>> MUMPS with 4 MPI processes and the default ictnl values, so I'm using this
>>>>>> to check that I can achieve the automatic icntl 14 update, as described
>>>>>> above. (The matrix is 14MB so I haven't attached it here, but I'd be happy
>>>>>> to send it to anyone else who wants to try this test case out.)
>>>>>> I've pasted some test code below which provides a simple test of this
>>>>>> idea using two solves. The first solve uses the default value of icntl 14,
>>>>>> which fails, and then we update icntl 14 to 30 and solve again. The second
>>>>>> solve should succeed since icntl 14 of 30 is sufficient for MUMPS to
>>>>>> succeed in this case, but for some reason the second solve still fails.
>>>>>> Below I've also pasted the output from -ksp_view, and you can see
>>>>>> that ictnl 14 is being updated correctly (see the ICNTL(14) lines in the
>>>>>> output), so it's not clear to me why the second solve fails. It seems like
>>>>>> MUMPS is ignoring the update to the ictnl value?
>>>>> I believe this parameter is utilized during the numerical
>>>>> factorization phase.
>>>>> In your code, the operator hasn't changed, however you haven't
>>>>> signalled to the KSP that you want to re-perform the numerical
>>>>> factorization.
>>>>> You can do this by calling KSPSetOperators() before your second solve.
>>>>> I think if you do this (please try it), the factorization will be
>>>>> performed again and the new value of icntl will have an effect.
>>>>> Note this is a wild stab in the dark - I haven't dug through the
>>>>> petsc-mumps code in detail...
>>>> That sounds like a plausible guess to me, but unfortunately it didn't
>>>> work. I added KSPSetOperators(ksp,A,A); before the second solve and I
>>>> got the same behavior as before.
>>>> Thanks,
>>>> David
>>>>>> Test code:
>>>>>> Mat A;
>>>>>> MatCreate(PETSC_COMM_WORLD,&A);
>>>>>> MatSetType(A,MATMPIAIJ);
>>>>>> PetscViewer petsc_viewer;
>>>>>> PetscViewerBinaryOpen( PETSC_COMM_WORLD,
>>>>>> "matrix.dat",
>>>>>> FILE_MODE_READ,
>>>>>> &petsc_viewer);
>>>>>> MatLoad(A, petsc_viewer);
>>>>>> PetscViewerDestroy(&petsc_viewer);
>>>>>> PetscInt m, n;
>>>>>> MatGetSize(A, &m, &n);
>>>>>> Vec x;
>>>>>> VecCreate(PETSC_COMM_WORLD,&x);
>>>>>> VecSetSizes(x,PETSC_DECIDE,m);
>>>>>> VecSetFromOptions(x);
>>>>>> VecSet(x,1.0);
>>>>>> Vec b;
>>>>>> VecDuplicate(x,&b);
>>>>>> KSP ksp;
>>>>>> PC pc;
>>>>>> KSPCreate(PETSC_COMM_WORLD,&ksp);
>>>>>> KSPSetType(ksp,KSPPREONLY);
>>>>>> KSPGetPC(ksp,&pc);
>>>>>> KSPSetFromOptions(ksp);
>>>>>> KSPSetUp(ksp);
>>>>>> KSPSolve(ksp,b,x);
>>>>>> KSPConvergedReason reason;
>>>>>> KSPGetConvergedReason(ksp, &reason);
>>>>>> std::cout << "converged reason: " << reason << std::endl;
>>>>>> Mat F;
>>>>>> KSPSolve(ksp,b,x);
>>>>>> -ksp_view output (ICNTL(14) changes from 20 to 30, but we get
>>>>>> "converged reason: -11" for both solves)
>>>>>> KSP Object: 4 MPI processes
>>>>>> type: preonly
>>>>>> maximum iterations=10000, initial guess is zero
>>>>>> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>>>>>> left preconditioning
>>>>>> using NONE norm type for convergence test
>>>>>> PC Object: 4 MPI processes
>>>>>> type: cholesky
>>>>>> Cholesky: out-of-place factorization
>>>>>> tolerance for zero pivot 2.22045e-14
>>>>>> matrix ordering: natural
>>>>>> factor fill ratio given 0., needed 0.
>>>>>> Factored matrix follows:
>>>>>> Mat Object: 4 MPI processes
>>>>>> type: mpiaij
>>>>>> rows=22878, cols=22878
>>>>>> package used to perform factorization: mumps
>>>>>> total: nonzeros=3361617, allocated nonzeros=3361617
>>>>>> total number of mallocs used during MatSetValues calls =0
>>>>>> MUMPS run parameters:
>>>>>> SYM (matrix type): 2
>>>>>> PAR (host participation): 1
>>>>>> ICNTL(1) (output for error): 6
>>>>>> ICNTL(2) (output of diagnostic msg): 0
>>>>>> ICNTL(3) (output for global info): 0
>>>>>> ICNTL(4) (level of printing): 0
>>>>>> ICNTL(5) (input mat struct): 0
>>>>>> ICNTL(6) (matrix prescaling): 7
>>>>>> ICNTL(7) (sequentia matrix ordering):7
>>>>>> ICNTL(8) (scalling strategy): 77
>>>>>> ICNTL(10) (max num of refinements): 0
>>>>>> ICNTL(11) (error analysis): 0
>>>>>> ICNTL(12) (efficiency control):
>>>>>> 0
>>>>>> ICNTL(13) (efficiency control):
>>>>>> 0
>>>>>> ICNTL(14) (percentage of estimated workspace increase):
>>>>>> 20
>>>>>> ICNTL(18) (input mat struct):
>>>>>> 3
>>>>>> ICNTL(19) (Shur complement info):
>>>>>> 0
>>>>>> ICNTL(20) (rhs sparse pattern):
>>>>>> 0
>>>>>> ICNTL(21) (solution struct):
>>>>>> 1
>>>>>> ICNTL(22) (in-core/out-of-core facility):
>>>>>> 0
>>>>>> ICNTL(23) (max size of memory can be allocated
>>>>>> locally):0
>>>>>> ICNTL(24) (detection of null pivot rows):
>>>>>> 0
>>>>>> ICNTL(25) (computation of a null space basis):
>>>>>> 0
>>>>>> ICNTL(26) (Schur options for rhs or solution):
>>>>>> 0
>>>>>> ICNTL(27) (experimental parameter):
>>>>>> -24
>>>>>> ICNTL(28) (use parallel or sequential ordering):
>>>>>> 1
>>>>>> ICNTL(29) (parallel ordering):
>>>>>> 0
>>>>>> ICNTL(30) (user-specified set of entries in inv(A)):
>>>>>> 0
>>>>>> ICNTL(31) (factors is discarded in the solve phase):
>>>>>> 0
>>>>>> ICNTL(33) (compute determinant):
>>>>>> 0
>>>>>> CNTL(1) (relative pivoting threshold): 0.01
>>>>>> CNTL(2) (stopping criterion of refinement): 1.49012e-08
>>>>>> CNTL(3) (absolute pivoting threshold): 0.
>>>>>> CNTL(4) (value of static pivoting): -1.
>>>>>> CNTL(5) (fixation for null pivots): 0.
>>>>>> RINFO(1) (local estimated flops for the elimination
>>>>>> after analysis):
>>>>>> [0] 1.84947e+08
>>>>>> [1] 2.42065e+08
>>>>>> [2] 2.53044e+08
>>>>>> [3] 2.18441e+08
>>>>>> RINFO(2) (local estimated flops for the assembly after
>>>>>> factorization):
>>>>>> [0] 945938.
>>>>>> [1] 906795.
>>>>>> [2] 897815.
>>>>>> [3] 998840.
>>>>>> RINFO(3) (local estimated flops for the elimination
>>>>>> after factorization):
>>>>>> [0] 1.59835e+08
>>>>>> [1] 1.50867e+08
>>>>>> [2] 2.27932e+08
>>>>>> [3] 1.52037e+08
>>>>>> INFO(15) (estimated size of (in MB) MUMPS internal data
>>>>>> for running numerical factorization):
>>>>>> [0] 36
>>>>>> [1] 37
>>>>>> [2] 38
>>>>>> [3] 39
>>>>>> INFO(16) (size of (in MB) MUMPS internal data used
>>>>>> during numerical factorization):
>>>>>> [0] 36
>>>>>> [1] 37
>>>>>> [2] 38
>>>>>> [3] 39
>>>>>> INFO(23) (num of pivots eliminated on this processor
>>>>>> [0] 6450
>>>>>> [1] 5442
>>>>>> [2] 4386
>>>>>> [3] 5526
>>>>>> RINFOG(1) (global estimated flops for the elimination
>>>>>> after analysis): 8.98497e+08
>>>>>> RINFOG(2) (global estimated flops for the assembly
>>>>>> after factorization): 3.74939e+06
>>>>>> RINFOG(3) (global estimated flops for the elimination
>>>>>> after factorization): 6.9067e+08
>>>>>> (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
>>>>>> (0.,0.)*(2^0)
>>>>>> INFOG(3) (estimated real workspace for factors on all
>>>>>> processors after analysis): 4082184
>>>>>> INFOG(4) (estimated integer workspace for factors on
>>>>>> all processors after analysis): 231846
>>>>>> INFOG(5) (estimated maximum front size in the complete
>>>>>> tree): 678
>>>>>> INFOG(6) (number of nodes in the complete tree): 1380
>>>>>> INFOG(7) (ordering option effectively use after
>>>>>> analysis): 5
>>>>>> INFOG(8) (structural symmetry in percent of the
>>>>>> permuted matrix after analysis): 100
>>>>>> INFOG(9) (total real/complex workspace to store the
>>>>>> matrix factors after factorization): 3521904
>>>>>> INFOG(10) (total integer space store the matrix factors
>>>>>> after factorization): 229416
>>>>>> INFOG(11) (order of largest frontal matrix after
>>>>>> factorization): 678
>>>>>> INFOG(12) (number of off-diagonal pivots): 0
>>>>>> INFOG(13) (number of delayed pivots after
>>>>>> factorization): 0
>>>>>> INFOG(14) (number of memory compress after
>>>>>> factorization): 0
>>>>>> INFOG(15) (number of steps of iterative refinement
>>>>>> after solution): 0
>>>>>> INFOG(16) (estimated size (in MB) of all MUMPS internal
>>>>>> data for factorization after analysis: value on the most memory consuming
>>>>>> processor): 39
>>>>>> INFOG(17) (estimated size of all MUMPS internal data
>>>>>> for factorization after analysis: sum over all processors): 150
>>>>>> INFOG(18) (size of all MUMPS internal data allocated
>>>>>> during factorization: value on the most memory consuming processor): 39
>>>>>> INFOG(19) (size of all MUMPS internal data allocated
>>>>>> during factorization: sum over all processors): 150
>>>>>> INFOG(20) (estimated number of entries in the factors):
>>>>>> 3361617
>>>>>> INFOG(21) (size in MB of memory effectively used during
>>>>>> factorization - value on the most memory consuming processor): 35
>>>>>> INFOG(22) (size in MB of memory effectively used during
>>>>>> factorization - sum over all processors): 136
>>>>>> INFOG(23) (after analysis: value of ICNTL(6)
>>>>>> effectively used): 0
>>>>>> INFOG(24) (after analysis: value of ICNTL(12)
>>>>>> effectively used): 1
>>>>>> INFOG(25) (after factorization: number of pivots
>>>>>> modified by static pivoting): 0
>>>>>> INFOG(28) (after factorization: number of null pivots
>>>>>> encountered): 0
>>>>>> INFOG(29) (after factorization: effective number of
>>>>>> entries in the factors (sum over all processors)): 2931438
>>>>>> INFOG(30, 31) (after solution: size in Mbytes of memory
>>>>>> used during solution phase): 0, 0
>>>>>> INFOG(32) (after analysis: type of analysis done): 1
>>>>>> INFOG(33) (value used for ICNTL(8)): 7
>>>>>> INFOG(34) (exponent of the determinant if determinant
>>>>>> is requested): 0
>>>>>> linear system matrix = precond matrix:
>>>>>> type: mpiaij
>>>>>> total: nonzeros=1219140, allocated nonzeros=1219140
>>>>>> using I-node (on process 0) routines: found 1889 nodes, limit
>>>>>> used is 5
>>>>>> type: preonly
>>>>>> type: cholesky
>>>>>> type: mpiaij
>>>>>> 0
>>>>>> 0
>>>>>> 30
>>>>>> 3
>>>>>> 0
>>>>>> 0
>>>>>> 1
>>>>>> 0
>>>>>> locally):0
>>>>>> 0
>>>>>> 0
>>>>>> 0
>>>>>> -24
>>>>>> 1
>>>>>> 0
>>>>>> 0
>>>>>> 0
>>>>>> 0
>>>>>> after analysis):
>>>>>> [0] 1.84947e+08
>>>>>> [1] 2.42065e+08
>>>>>> [2] 2.53044e+08
>>>>>> [3] 2.18441e+08
>>>>>> factorization):
>>>>>> [0] 945938.
>>>>>> [1] 906795.
>>>>>> [2] 897815.
>>>>>> [3] 998840.
>>>>>> [0] 1.59835e+08
>>>>>> [1] 1.50867e+08
>>>>>> [2] 2.27932e+08
>>>>>> [3] 1.52037e+08
>>>>>> [0] 36
>>>>>> [1] 37
>>>>>> [2] 38
>>>>>> [3] 39
>>>>>> [0] 36
>>>>>> [1] 37
>>>>>> [2] 38
>>>>>> [3] 39
>>>>>> [0] 6450
>>>>>> [1] 5442
>>>>>> [2] 4386
>>>>>> [3] 5526
>>>>>> (0.,0.)*(2^0)
>>>>>> tree): 678
>>>>>> analysis): 5
>>>>>> factorization): 678
>>>>>> factorization): 0
>>>>>> factorization): 0
>>>>>> after solution): 0
>>>>>> processor): 39
>>>>>> 3361617
>>>>>> encountered): 0
>>>>>> is requested): 0
>>>>>> type: mpiaij
>>>>>> used is 5
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160919/cd41070d/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160919/cd41070d/attachment-0001.obj>
