[petsc-users] Issue updating MUMPS ictnl after failed solve
Hong hzhang at mcs.anl.gov
Mon Sep 19 16:47:31 CDT 2016
David :
I'll check it ...
Hong
When I use MUMPS via PETSc, one issue is that it can sometimes fail with
> MUMPS error -9, which means that MUMPS didn't allocate a big enough
> workspace. This can typically be fixed by increasing MUMPS icntl 14, e.g.
> via the command line option -mat_mumps_icntl_14.
> However, instead of having to run several times with different command
> line options, I'd like to be able to automatically increment icntl 14 value
> in a loop until the solve succeeds.
> I have a saved matrix which fails when I use it for a solve with MUMPS
> with 4 MPI processes and the default ictnl values, so I'm using this to
> check that I can achieve the automatic icntl 14 update, as described above.
> (The matrix is 14MB so I haven't attached it here, but I'd be happy to send
> it to anyone else who wants to try this test case out.)
> I've pasted some test code below which provides a simple test of this idea
> using two solves. The first solve uses the default value of icntl 14, which
> fails, and then we update icntl 14 to 30 and solve again. The second solve
> should succeed since icntl 14 of 30 is sufficient for MUMPS to succeed in
> this case, but for some reason the second solve still fails.
> Below I've also pasted the output from -ksp_view, and you can see that
> ictnl 14 is being updated correctly (see the ICNTL(14) lines in the
> output), so it's not clear to me why the second solve fails. It seems like
> MUMPS is ignoring the update to the ictnl value?
> Thanks,
> David
> Test code:
>   Mat A;
>   MatCreate(PETSC_COMM_WORLD,&A);
>   MatSetType(A,MATMPIAIJ);
>   PetscViewer petsc_viewer;
>   PetscViewerBinaryOpen( PETSC_COMM_WORLD,
>                          "matrix.dat",
>                          FILE_MODE_READ,
>                          &petsc_viewer);
>   MatLoad(A, petsc_viewer);
>   PetscViewerDestroy(&petsc_viewer);
>   PetscInt m, n;
>   MatGetSize(A, &m, &n);
>   Vec x;
>   VecCreate(PETSC_COMM_WORLD,&x);
>   VecSetSizes(x,PETSC_DECIDE,m);
>   VecSetFromOptions(x);
>   VecSet(x,1.0);
>   Vec b;
>   VecDuplicate(x,&b);
>   KSP ksp;
>   PC pc;
>   KSPCreate(PETSC_COMM_WORLD,&ksp);
>   KSPSetOperators(ksp,A,A);
>   KSPSetType(ksp,KSPPREONLY);
>   KSPGetPC(ksp,&pc);
>   PCSetType(pc,PCCHOLESKY);
>   PCFactorSetMatSolverPackage(pc,MATSOLVERMUMPS);
>   PCFactorSetUpMatSolverPackage(pc);
>   KSPSetFromOptions(ksp);
>   KSPSetUp(ksp);
>   KSPSolve(ksp,b,x);
>     KSPConvergedReason reason;
>     KSPGetConvergedReason(ksp, &reason);
>     std::cout << "converged reason: " << reason << std::endl;
>   Mat F;
>   PCFactorGetMatrix(pc,&F);
>   MatMumpsSetIcntl(F,14,30);
>   KSPSolve(ksp,b,x);
> -ksp_view output (ICNTL(14) changes from 20 to 30, but we get "converged
> reason: -11" for both solves)
> KSP Object: 4 MPI processes
>   type: preonly
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>   left preconditioning
>   using NONE norm type for convergence test
> PC Object: 4 MPI processes
>   type: cholesky
>     Cholesky: out-of-place factorization
>     tolerance for zero pivot 2.22045e-14
>     matrix ordering: natural
>     factor fill ratio given 0., needed 0.
>       Factored matrix follows:
>         Mat Object:         4 MPI processes
>           type: mpiaij
>           rows=22878, cols=22878
>           package used to perform factorization: mumps
>           total: nonzeros=3361617, allocated nonzeros=3361617
>           total number of mallocs used during MatSetValues calls =0
>             MUMPS run parameters:
>               SYM (matrix type):                   2
>               PAR (host participation):            1
>               ICNTL(1) (output for error):         6
>               ICNTL(2) (output of diagnostic msg): 0
>               ICNTL(3) (output for global info):   0
>               ICNTL(4) (level of printing):        0
>               ICNTL(5) (input mat struct):         0
>               ICNTL(6) (matrix prescaling):        7
>               ICNTL(7) (sequentia matrix ordering):7
>               ICNTL(8) (scalling strategy):        77
>               ICNTL(10) (max num of refinements):  0
>               ICNTL(11) (error analysis):          0
>               ICNTL(12) (efficiency control):                         0
>               ICNTL(13) (efficiency control):                         0
>               ICNTL(14) (percentage of estimated workspace increase): 20
>               ICNTL(18) (input mat struct):                           3
>               ICNTL(19) (Shur complement info):                       0
>               ICNTL(20) (rhs sparse pattern):                         0
>               ICNTL(21) (solution struct):                            1
>               ICNTL(22) (in-core/out-of-core facility):               0
>               ICNTL(23) (max size of memory can be allocated locally):0
>               ICNTL(24) (detection of null pivot rows):               0
>               ICNTL(25) (computation of a null space basis):          0
>               ICNTL(26) (Schur options for rhs or solution):          0
>               ICNTL(27) (experimental parameter):                     -24
>               ICNTL(28) (use parallel or sequential ordering):        1
>               ICNTL(29) (parallel ordering):                          0
>               ICNTL(30) (user-specified set of entries in inv(A)):    0
>               ICNTL(31) (factors is discarded in the solve phase):    0
>               ICNTL(33) (compute determinant):                        0
>               CNTL(1) (relative pivoting threshold):      0.01
>               CNTL(2) (stopping criterion of refinement): 1.49012e-08
>               CNTL(3) (absolute pivoting threshold):      0.
>               CNTL(4) (value of static pivoting):         -1.
>               CNTL(5) (fixation for null pivots):         0.
>               RINFO(1) (local estimated flops for the elimination after
> analysis):
>                 [0] 1.84947e+08
>                 [1] 2.42065e+08
>                 [2] 2.53044e+08
>                 [3] 2.18441e+08
>               RINFO(2) (local estimated flops for the assembly after
> factorization):
>                 [0]  945938.
>                 [1]  906795.
>                 [2]  897815.
>                 [3]  998840.
>               RINFO(3) (local estimated flops for the elimination after
> factorization):
>                 [0]  1.59835e+08
>                 [1]  1.50867e+08
>                 [2]  2.27932e+08
>                 [3]  1.52037e+08
>               INFO(15) (estimated size of (in MB) MUMPS internal data for
> running numerical factorization):
>               [0] 36
>               [1] 37
>               [2] 38
>               [3] 39
>               INFO(16) (size of (in MB) MUMPS internal data used during
>                 [0] 36
>                 [1] 37
>                 [2] 38
>                 [3] 39
>               INFO(23) (num of pivots eliminated on this processor after
> factorization):
>                 [0] 6450
>                 [1] 5442
>                 [2] 4386
>                 [3] 5526
>               RINFOG(1) (global estimated flops for the elimination after
> analysis): 8.98497e+08
>               RINFOG(2) (global estimated flops for the assembly after
> factorization): 3.74939e+06
>               RINFOG(3) (global estimated flops for the elimination after
> factorization): 6.9067e+08
>               (RINFOG(12) RINFOG(13))*2^INFOG(34) (determinant):
> (0.,0.)*(2^0)
>               INFOG(3) (estimated real workspace for factors on all
> processors after analysis): 4082184
>               INFOG(4) (estimated integer workspace for factors on all
> processors after analysis): 231846
>               INFOG(5) (estimated maximum front size in the complete
> tree): 678
>               INFOG(6) (number of nodes in the complete tree): 1380
>               INFOG(7) (ordering option effectively use after analysis): 5
>               INFOG(8) (structural symmetry in percent of the permuted
> matrix after analysis): 100
>               INFOG(9) (total real/complex workspace to store the matrix
> factors after factorization): 3521904
>               INFOG(10) (total integer space store the matrix factors
> after factorization): 229416
>               INFOG(11) (order of largest frontal matrix after
> factorization): 678
>               INFOG(12) (number of off-diagonal pivots): 0
>               INFOG(13) (number of delayed pivots after factorization): 0
>               INFOG(14) (number of memory compress after factorization): 0
>               INFOG(15) (number of steps of iterative refinement after
> solution): 0
>               INFOG(16) (estimated size (in MB) of all MUMPS internal data
> for factorization after analysis: value on the most memory consuming
> processor): 39
>               INFOG(17) (estimated size of all MUMPS internal data for
> factorization after analysis: sum over all processors): 150
>               INFOG(18) (size of all MUMPS internal data allocated during
> factorization: value on the most memory consuming processor): 39
>               INFOG(19) (size of all MUMPS internal data allocated during
> factorization: sum over all processors): 150
>               INFOG(20) (estimated number of entries in the factors):
> 3361617
>               INFOG(21) (size in MB of memory effectively used during
> factorization - value on the most memory consuming processor): 35
>               INFOG(22) (size in MB of memory effectively used during
> factorization - sum over all processors): 136
>               INFOG(23) (after analysis: value of ICNTL(6) effectively
> used): 0
>               INFOG(24) (after analysis: value of ICNTL(12) effectively
> used): 1
>               INFOG(25) (after factorization: number of pivots modified by
> static pivoting): 0
>               INFOG(28) (after factorization: number of null pivots
> encountered): 0
>               INFOG(29) (after factorization: effective number of entries
> in the factors (sum over all processors)): 2931438
>               INFOG(30, 31) (after solution: size in Mbytes of memory used
> during solution phase): 0, 0
>               INFOG(32) (after analysis: type of analysis done): 1
>               INFOG(33) (value used for ICNTL(8)): 7
>               INFOG(34) (exponent of the determinant if determinant is
> requested): 0
>   linear system matrix = precond matrix:
>     type: mpiaij
>     total: nonzeros=1219140, allocated nonzeros=1219140
>       using I-node (on process 0) routines: found 1889 nodes, limit used
> is 5
> converged reason: -11
>   type: preonly
>   type: cholesky
>           type: mpiaij
>               ICNTL(14) (percentage of estimated workspace increase): 30
> analysis):
>                 [0] 1.84947e+08
>                 [1] 2.42065e+08
>                 [2] 2.53044e+08
>                 [3] 2.18441e+08
> factorization):
>                 [0]  945938.
>                 [1]  906795.
>                 [2]  897815.
>                 [3]  998840.
> factorization):
>                 [0]  1.59835e+08
>                 [1]  1.50867e+08
>                 [2]  2.27932e+08
>                 [3]  1.52037e+08
>               [0] 36
>               [1] 37
>               [2] 38
>               [3] 39
>                 [0] 36
>                 [1] 37
>                 [2] 38
>                 [3] 39
> factorization):
>                 [0] 6450
>                 [1] 5442
>                 [2] 4386
>                 [3] 5526
> (0.,0.)*(2^0)
> tree): 678
> factorization): 678
> solution): 0
> processor): 39
> 3361617
> used): 0
> used): 1
> static pivoting): 0
> encountered): 0
> requested): 0
>     type: mpiaij
> is 5
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160919/eb76320f/attachment-0001.html>
