[petsc-users] How to create a local to global mapping and construct matrix correctly
Ji Zhang
gotofd at gmail.com
Fri Sep 16 19:52:14 CDT 2016
Sorry. What I mean is that, for example, I have a matrix
[a1, a2, a3]
mij = [b1, b2, b3] ,
[c1, c2, c3]
and using 3 cups. Thus, mij in cpu 2 is
mij_2 = [b1, b2, b3] .
The local index of element b1 is (1, 1) and it's global index is (2, 1).
How can I get the global index from the local index, and local index from
global index?
Thanks.
2016-09-17
Best,
Zhang Ji
Beijing Computational Science Research Center
E-mail: gotofd at gmail.com
Wayne
On Sat, Sep 17, 2016 at 2:24 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> "Gives wrong answers" is not very informative. What answer do you
> expect and what answer do you get?
> Note that each process is looping over mSizes?
> for i in range(len(mSizes)):
> for j in range(len(mSizes)):
> Is this what you want? It doesn't seem likely that you want all
> processes to generate all information in the matrix. Each process should be
> doing a subset of the generation.
> Barry
> > On Sep 16, 2016, at 11:03 AM, Ji Zhang <gotofd at gmail.com> wrote:
> > Dear all,
> > I have a number of small 'mpidense' matrices mij, and I want to
> construct them to a big 'mpidense' matrix M like this:
> > [ m11 m12 m13 ]
> > M = | m21 m22 m23 | ,
> > [ m31 m32 m33 ]
> > And a short demo is below. I'm using python, but their grammar are
> similar.
> > import numpy as np
> > from petsc4py import PETSc
> > import sys, petsc4py
> > petsc4py.init(sys.argv)
> > mSizes = (2, 2)
> > mij = []
> > # create sub-matrices mij
> > temp_m = PETSc.Mat().create(comm=PETSc.COMM_WORLD)
> > temp_m.setSizes(((None, mSizes[i]), (None, mSizes[j])))
> > temp_m.setType('mpidense')
> > temp_m.setFromOptions()
> > temp_m.setUp()
> > temp_m[:, :] = np.random.random_sample((mSizes[i], mSizes[j]))
> > temp_m.assemble()
> > temp_m.view()
> > mij.append(temp_m)
> > # Now we have four sub-matrices. I would like to construct them into a
> big matrix M.
> > M = PETSc.Mat().create(comm=PETSc.COMM_WORLD)
> > M.setSizes(((None, np.sum(mSizes)), (None, np.sum(mSizes))))
> > M.setType('mpidense')
> > M.setFromOptions()
> > M.setUp()
> > mLocations = np.insert(np.cumsum(mSizes), 0, 0) # mLocations = [0,
> mSizes]
> > temp_m = mij[i*len(mSizes)+j].getDenseArray()
> > for k in range(temp_m.shape[0]):
> > M.setValues(mLocations[i]+k, np.arange(mLocations[j],
> mLocations[j+1],dtype='int32'), temp_m[k, :])
> > M.assemble()
> > M.view()
> > The code works well in a single cup, but give wrong answer for 2 and
> more cores.
> > Thanks.
> > 2016-09-17
> > Best,
> > Regards,
> > Zhang Ji
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160917/83c0c0b6/attachment.html>
