[petsc-users] Question about memory usage in Multigrid preconditioner
Hengjie Wang hengjiew at uci.edu
Fri Sep 16 12:53:26 CDT 2016
Hi Dave,
I add both options and test it by solving the poisson eqn in  a 1024
cube with 32^3 cores. This test used to give the OOM error. Now it runs
well.
I attach the ksp_view and log_view's output in case you want to know.
I also test my original code with those petsc options by simulating a
decaying turbulence in a 1024 cube. It also works.  I am going to test
the code on a larger scale. If there is any problem then, I will let you
know.
This really helps a lot. Thank you so much.
Frank
On 9/15/2016 3:35 AM, Dave May wrote:
> HI all,
> I the only unexpected memory usage I can see is associated with the
> call to MatPtAP().
> Here is something you can try immediately.
> Run your code with the additional options
>   -matrap 0 -matptap_scalable
> I didn't realize this before, but the default behaviour of MatPtAP in
> parallel is actually to to explicitly form the transpose of P (e.g.
> assemble R = P^T) and then compute R.A.P.
> You don't want to do this. The option -matrap 0 resolves this issue.
> The implementation of P^T.A.P has two variants.
> The scalable implementation (with respect to memory usage) is selected
> via the second option -matptap_scalable.
> Try it out - I see a significant memory reduction using these options
> for particular mesh sizes / partitions.
> I've attached a cleaned up version of the code you sent me.
> There were a number of memory leaks and other issues.
> The main points being
>   * You should call DMDAVecGetArrayF90() before VecAssembly{Begin,End}
>   * You should call PetscFinalize(), otherwise the option -log_summary
> (-log_view) will not display anything once the program has completed.
> Thanks,
>   Dave
> On 15 September 2016 at 08:03, Hengjie Wang <hengjiew at uci.edu
> <mailto:hengjiew at uci.edu>> wrote:
>     Hi Dave,
>     Sorry, I should have put more comment to explain the code.
>     The number of process in each dimension is the same: Px = Py=Pz=P.
>     So is the domain size.
>     So if the you want to run the code for a  512^3 grid points on
>     16^3 cores, you need to set "-N 512 -P 16" in the command line.
>     I add more comments and also fix an error in the attached code. (
>     The error only effects the accuracy of solution but not the memory
>     usage. )
>     Thank you.
>     Frank
>     On 9/14/2016 9:05 PM, Dave May wrote:
>>     On Thursday, 15 September 2016, Dave May <dave.mayhem23 at gmail.com
>>     <mailto:dave.mayhem23 at gmail.com>> wrote:
>>         On Thursday, 15 September 2016, frank <hengjiew at uci.edu> wrote:
>>             Hi,
>>             I write a simple code to re-produce the error. I hope
>>             this can help to diagnose the problem.
>>             The code just solves a 3d poisson equation.
>>         Why is the stencil width a runtime parameter?? And why is the
>>         default value 2? For 7-pnt FD Laplace, you only need
>>         a stencil width of 1.
>>         Was this choice made to mimic something in the
>>         real application code?
>>     Please ignore - I misunderstood your usage of the param set by -P
>>             I run the code on a 1024^3 mesh. The process partition is
>>             32 * 32 * 32. That's when I re-produce the OOM error.
>>             Each core has about 2G memory.
>>             I also run the code on a 512^3 mesh with 16 * 16 * 16
>>             processes. The ksp solver works fine.
>>             I attached the code, ksp_view_pre's output and my petsc
>>             option file.
>>             Thank you.
>>             Frank
>>             On 09/09/2016 06:38 PM, Hengjie Wang wrote:
>>>             Hi Barry,
>>>             I checked. On the supercomputer, I had the option
>>>             "-ksp_view_pre" but it is not in file I sent you. I am
>>>             sorry for the confusion.
>>>             Regards,
>>>             Frank
>>>             On Friday, September 9, 2016, Barry Smith
>>>             <bsmith at mcs.anl.gov> wrote:
>>>                 > On Sep 9, 2016, at 3:11 PM, frank
>>>                 > Hi Barry,
>>>                 > I think the first KSP view output is from
>>>                 -ksp_view_pre. Before I submitted the test, I was
>>>                 not sure whether there would be OOM error or not. So
>>>                 I added both -ksp_view_pre and -ksp_view.
>>>                   But the options file you sent specifically does
>>>                 NOT list the -ksp_view_pre so how could it be from that?
>>>                    Sorry to be pedantic but I've spent too much time
>>>                 in the past trying to debug from incorrect
>>>                 information and want to make sure that the
>>>                 information I have is correct before thinking.
>>>                 Please recheck exactly what happened. Rerun with the
>>>                 exact input file you emailed if that is needed.
>>>                    Barry
>>>                 > Frank
>>>                 > On 09/09/2016 12:38 PM, Barry Smith wrote:
>>>                 >>   Why does ksp_view2.txt have two KSP views in it
>>>                 while ksp_view1.txt has only one KSPView in it? Did
>>>                 you run two different solves in the 2 case but not
>>>                 the one?
>>>                 >>   Barry
>>>                 >>> On Sep 9, 2016, at 10:56 AM, frank
>>>                 >>> Hi,
>>>                 >>> I want to continue digging into the memory
>>>                 problem here.
>>>                 >>> I did find a work around in the past, which is
>>>                 to use less cores per node so that each core has 8G
>>>                 memory. However this is deficient and expensive. I
>>>                 hope to locate the place that uses the most memory.
>>>                 >>> Here is a brief summary of the tests I did in past:
>>>                 >>>> Test1:   Mesh 1536*128*384  |  Process Mesh 48*4*12
>>>                 >>> Maximum (over computational time) process
>>>                 memory:        total 7.0727e+08
>>>                 >>> Current process memory:                  total
>>>                 7.0727e+08
>>>                 >>> Maximum (over computational time) space
>>>                 PetscMalloc()ed:  total 6.3908e+11
>>>                 >>> Current space PetscMalloc()ed:
>>>                         total 1.8275e+09
>>>                 >>>> Test2:    Mesh 1536*128*384  |  Process Mesh
>>>                 96*8*24
>>>                 memory:        total 5.9431e+09
>>>                 5.9431e+09
>>>                 PetscMalloc()ed:  total 5.3202e+12
>>>                          total 5.4844e+09
>>>                 >>>> Test3:    Mesh 3072*256*768  |  Process Mesh
>>>                 96*8*24
>>>                 >>>     OOM( Out Of Memory ) killer of the
>>>                 supercomputer terminated the job during "KSPSolve".
>>>                 >>> I attached the output of ksp_view( the third
>>>                 test's output is from ksp_view_pre ), memory_view
>>>                 and also the petsc options.
>>>                 >>> In all the tests, each core can access about 2G
>>>                 memory. In test3, there are 4223139840 non-zeros in
>>>                 the matrix. This will consume about 1.74M, using
>>>                 double precision. Considering some extra memory used
>>>                 to store integer index, 2G memory should still be
>>>                 way enough.
>>>                 >>> Is there a way to find out which part of
>>>                 KSPSolve uses the most memory?
>>>                 >>> Thank you so much.
>>>                 >>> BTW, there are 4 options remains unused and I
>>>                 don't understand why they are omitted:
>>>                 >>> -mg_coarse_telescope_mg_coarse_ksp_type value:
>>>                 preonly
>>>                 >>> -mg_coarse_telescope_mg_coarse_pc_type value:
>>>                 bjacobi
>>>                 >>> -mg_coarse_telescope_mg_levels_ksp_max_it value: 1
>>>                 >>> -mg_coarse_telescope_mg_levels_ksp_type value:
>>>                 richardson
>>>                 >>> Regards,
>>>                 >>> Frank
>>>                 >>> On 07/13/2016 05:47 PM, Dave May wrote:
>>>                 >>>> On 14 July 2016 at 01:07, frank
>>>                 >>>> Hi Dave,
>>>                 >>>> Sorry for the late reply.
>>>                 >>>> Thank you so much for your detailed reply.
>>>                 >>>> I have a question about the estimation of the
>>>                 memory usage. There are 4223139840 allocated
>>>                 non-zeros and 18432 MPI processes. Double precision
>>>                 is used. So the memory per process is:
>>>                 >>>>   4223139840 * 8bytes / 18432 / 1024 / 1024 =
>>>                 1.74M ?
>>>                 >>>> Did I do sth wrong here? Because this seems too
>>>                 small.
>>>                 >>>> No - I totally f***ed it up. You are correct.
>>>                 That'll teach me for fumbling around with my iphone
>>>                 calculator and not using my brain. (Note that to
>>>                 convert to MB just divide by 1e6, not 1024^2 -
>>>                 although I apparently cannot convert between units
>>>                 correctly....)
>>>                 >>>> From the PETSc objects associated with the
>>>                 solver, It looks like it _should_ run with 2GB per
>>>                 MPI rank. Sorry for my mistake. Possibilities are:
>>>                 somewhere in your usage of PETSc you've introduced a
>>>                 memory leak; PETSc is doing a huge over allocation
>>>                 (e.g. as per our discussion of MatPtAP); or in your
>>>                 application code there are other objects you have
>>>                 forgotten to log the memory for.
>>>                 >>>> I am running this job on Bluewater
>>>                 >>>> I am using the 7 points FD stencil in 3D.
>>>                 >>>> I thought so on both counts.
>>>                 >>>> I apologize that I made a stupid mistake in
>>>                 computing the memory per core. My settings render
>>>                 each core can access only 2G memory on average
>>>                 instead of 8G which I mentioned in previous email. I
>>>                 re-run the job with 8G memory per core on average
>>>                 and there is no "Out Of Memory" error. I would do
>>>                 more test to see if there is still some memory issue.
>>>                 >>>> Ok. I'd still like to know where the memory was
>>>                 being used since my estimates were off.
>>>                 >>>> Thanks,
>>>                 >>>>   Dave
>>>                 >>>> Regards,
>>>                 >>>> Frank
>>>                 >>>> On 07/11/2016 01:18 PM, Dave May wrote:
>>>                 >>>>> Hi Frank,
>>>                 >>>>> On 11 July 2016 at 19:14, frank
>>>                 >>>>> Hi Dave,
>>>                 >>>>> I re-run the test using bjacobi as the
>>>                 preconditioner on the coarse mesh of telescope. The
>>>                 Grid is 3072*256*768 and process mesh is 96*8*24.
>>>                 The petsc option file is attached.
>>>                 >>>>> I still got the "Out Of Memory" error. The
>>>                 error occurred before the linear solver finished one
>>>                 step. So I don't have the full info from ksp_view.
>>>                 The info from ksp_view_pre is attached.
>>>                 >>>>> Okay - that is essentially useless (sorry)
>>>                 >>>>> It seems to me that the error occurred when
>>>                 the decomposition was going to be changed.
>>>                 >>>>> Based on what information?
>>>                 >>>>> Running with -info would give us more clues,
>>>                 but will create a ton of output.
>>>                 >>>>> Please try running the case which failed with
>>>                 -info
>>>                 >>>>>  I had another test with a grid of
>>>                 1536*128*384 and the same process mesh as above.
>>>                 There was no error. The ksp_view info is attached
>>>                 for comparison.
>>>                 >>>>> Thank you.
>>>                 >>>>> [3] Here is my crude estimate of your memory
>>>                 usage.
>>>                 >>>>> I'll target the biggest memory hogs only to
>>>                 get an order of magnitude estimate
>>>                 >>>>> * The Fine grid operator contains 4223139840
>>>                 non-zeros --> 1.8 GB per MPI rank assuming double
>>>                 precision.
>>>                 >>>>> The indices for the AIJ could amount to
>>>                 another 0.3 GB (assuming 32 bit integers)
>>>                 >>>>> * You use 5 levels of coarsening, so the other
>>>                 operators should represent (collectively)
>>>                 >>>>> 2.1 / 8 + 2.1/8^2 + 2.1/8^3 + 2.1/8^4  ~ 300
>>>                 MB per MPI rank on the communicator with 18432 ranks.
>>>                 >>>>> The coarse grid should consume ~ 0.5 MB per
>>>                 >>>>> * You use a reduction factor of 64, making the
>>>                 new communicator with 288 MPI ranks.
>>>                 >>>>> PCTelescope will first gather a temporary
>>>                 matrix associated with your coarse level operator
>>>                 assuming a comm size of 288 living on the comm with
>>>                 size 18432.
>>>                 >>>>> This matrix will require approximately 0.5 *
>>>                 64 = 32 MB per core on the 288 ranks.
>>>                 >>>>> This matrix is then used to form a new MPIAIJ
>>>                 matrix on the subcomm, thus require another 32 MB
>>>                 per rank.
>>>                 >>>>> The temporary matrix is now destroyed.
>>>                 >>>>> * Because a DMDA is detected, a permutation
>>>                 matrix is assembled.
>>>                 >>>>> This requires 2 doubles per point in the DMDA.
>>>                 >>>>> Your coarse DMDA contains 92 x 16 x 48 points.
>>>                 >>>>> Thus the permutation matrix will require < 1
>>>                 MB per MPI rank on the sub-comm.
>>>                 >>>>> * Lastly, the matrix is permuted. This uses
>>>                 MatPtAP(), but the resulting operator will have the
>>>                 same memory footprint as the unpermuted matrix (32
>>>                 MB). At any stage in PCTelescope, only 2 operators
>>>                 of size 32 MB are held in memory when the DMDA is
>>>                 provided.
>>>                 >>>>> From my rough estimates, the worst case memory
>>>                 foot print for any given core, given your options is
>>>                 approximately
>>>                 >>>>> 2100 MB + 300 MB + 32 MB + 32 MB + 1 MB  = 2465 MB
>>>                 >>>>> This is way below 8 GB.
>>>                 >>>>> Note this estimate completely ignores:
>>>                 >>>>> (1) the memory required for the restriction
>>>                 operator,
>>>                 >>>>> (2) the potential growth in the number of
>>>                 non-zeros per row due to Galerkin coarsening (I
>>>                 wished -ksp_view_pre reported the output from
>>>                 MatView so we could see the number of non-zeros
>>>                 required by the coarse level operators)
>>>                 >>>>> (3) all temporary vectors required by the CG
>>>                 solver, and those required by the smoothers.
>>>                 >>>>> (4) internal memory allocated by MatPtAP
>>>                 >>>>> (5) memory associated with IS's used within
>>>                 PCTelescope
>>>                 >>>>> So either I am completely off in my estimates,
>>>                 or you have not carefully estimated the memory usage
>>>                 of your application code. Hopefully others might
>>>                 examine/correct my rough estimates
>>>                 >>>>> Since I don't have your code I cannot access
>>>                 the latter.
>>>                 >>>>> Since I don't have access to the same machine
>>>                 you are running on, I think we need to take a step back.
>>>                 >>>>> [1] What machine are you running on? Send me a
>>>                 URL if its available
>>>                 >>>>> [2] What discretization are you using? (I am
>>>                 guessing a scalar 7 point FD stencil)
>>>                 >>>>> If it's a 7 point FD stencil, we should be
>>>                 able to examine the memory usage of your solver
>>>                 configuration using a standard, light weight
>>>                 existing PETSc example, run on your machine at the
>>>                 same scale.
>>>                 >>>>> This would hopefully enable us to correctly
>>>                 evaluate the actual memory usage required by the
>>>                 solver configuration you are using.
>>>                 >>>>> Thanks,
>>>                 >>>>>   Dave
>>>                 >>>>> Frank
>>>                 >>>>> On 07/08/2016 10:38 PM, Dave May wrote:
>>>                 >>>>>> On Saturday, 9 July 2016, frank
>>>                 >>>>>> Hi Barry and Dave,
>>>                 >>>>>> Thank both of you for the advice.
>>>                 >>>>>> @Barry
>>>                 >>>>>> I made a mistake in the file names in last
>>>                 email. I attached the correct files this time.
>>>                 >>>>>> For all the three tests, 'Telescope' is used
>>>                 as the coarse preconditioner.
>>>                 >>>>>> == Test1:  Grid: 1536*128*384,   Process
>>>                 Mesh: 48*4*12
>>>                 >>>>>> Part of the memory usage:  Vector   125 124
>>>                 3971904     0.
>>>                 >>>>>> Matrix   101 101      9462372     0
>>>                 >>>>>> == Test2: Grid: 1536*128*384,   Process Mesh:
>>>                 96*8*24
>>>                 681672     0.
>>>                 >>>>>> Matrix   101 101      1462180     0.
>>>                 >>>>>> In theory, the memory usage in Test1 should
>>>                 be 8 times of Test2. In my case, it is about 6 times.
>>>                 >>>>>> == Test3: Grid: 3072*256*768,   Process Mesh:
>>>                 96*8*24. Sub-domain per process: 32*32*32
>>>                 >>>>>> Here I get the out of memory error.
>>>                 >>>>>> I tried to use -mg_coarse jacobi. In this
>>>                 way, I don't need to set -mg_coarse_ksp_type and
>>>                 -mg_coarse_pc_type explicitly, right?
>>>                 >>>>>> The linear solver didn't work in this case.
>>>                 Petsc output some errors.
>>>                 >>>>>> @Dave
>>>                 >>>>>> In test3, I use only one instance of
>>>                 'Telescope'. On the coarse mesh of 'Telescope', I
>>>                 used LU as the preconditioner instead of SVD.
>>>                 >>>>>> If my set the levels correctly, then on the
>>>                 last coarse mesh of MG where it calls 'Telescope',
>>>                 the sub-domain per process is 2*2*2.
>>>                 >>>>>> On the last coarse mesh of 'Telescope', there
>>>                 is only one grid point per process.
>>>                 >>>>>> I still got the OOM error. The detailed petsc
>>>                 >>>>>> Do you understand the expected memory usage
>>>                 for the particular parallel LU implementation you
>>>                 are using? I don't (seriously). Replace LU with
>>>                 bjacobi and re-run this test. My point about solver
>>>                 debugging is still valid.
>>>                 >>>>>> And please send the result of KSPView so we
>>>                 can see what is actually used in the computations
>>>                 >>>>>> Thanks
>>>                 >>>>>>   Dave
>>>                 >>>>>> Thank you so much.
>>>                 >>>>>> Frank
>>>                 >>>>>> On 07/06/2016 02:51 PM, Barry Smith wrote:
>>>                 >>>>>> On Jul 6, 2016, at 4:19 PM, frank
>>>                 >>>>>> Hi Barry,
>>>                 >>>>>> Thank you for you advice.
>>>                 >>>>>> I tried three test. In the 1st test, the grid
>>>                 is 3072*256*768 and the process mesh is 96*8*24.
>>>                 >>>>>> The linear solver is 'cg' the preconditioner
>>>                 is 'mg' and 'telescope' is used as the
>>>                 preconditioner at the coarse mesh.
>>>                 >>>>>> The system gives me the "Out of Memory" error
>>>                 before the linear system is completely solved.
>>>                 >>>>>> The info from '-ksp_view_pre' is attached. I
>>>                 seems to me that the error occurs when it reaches
>>>                 the coarse mesh.
>>>                 >>>>>> The 2nd test uses a grid of 1536*128*384 and
>>>                 process mesh is 96*8*24. The 3rd  test uses the same
>>>                 grid but a different process mesh 48*4*12.
>>>                 >>>>>>     Are you sure this is right? The total
>>>                 matrix and vector memory usage goes from 2nd test
>>>                 >>>>>>   Vector   384            383 8,193,712     0.
>>>                 >>>>>>   Matrix   103            103  11,508,688     0.
>>>                 >>>>>> to 3rd test
>>>                 >>>>>>  Vector   384            383 1,590,520     0.
>>>                 >>>>>>   Matrix   103            103 3,508,664     0.
>>>                 >>>>>> that is the memory usage got smaller but if
>>>                 you have only 1/8th the processes and the same grid
>>>                 it should have gotten about 8 times bigger. Did you
>>>                 maybe cut the grid by a factor of 8 also? If so that
>>>                 still doesn't explain it because the memory usage
>>>                 changed by a factor of 5 something for the vectors
>>>                 and 3 something for the matrices.
>>>                 >>>>>> The linear solver and petsc options in 2nd
>>>                 and 3rd tests are the same in 1st test. The linear
>>>                 solver works fine in both test.
>>>                 >>>>>> I attached the memory usage of the 2nd and
>>>                 3rd tests. The memory info is from the option
>>>                 '-log_summary'. I tried to use '-momery_info' as you
>>>                 suggested, but in my case petsc treated it as an
>>>                 unused option. It output nothing about the memory.
>>>                 Do I need to add sth to my code so I can use
>>>                 '-memory_info'?
>>>                 >>>>>>     Sorry, my mistake the option is -memory_view
>>>                 >>>>>>    Can you run the one case with -memory_view
>>>                 and -mg_coarse jacobi -ksp_max_it 1 (just so it
>>>                 doesn't iterate forever) to see how much memory is
>>>                 used without the telescope? Also run case 2 the same
>>>                 way.
>>>                 >>>>>>    Barry
>>>                 >>>>>> In both tests the memory usage is not large.
>>>                 >>>>>> It seems to me that it might be the
>>>                 'telescope' preconditioner that allocated a lot of
>>>                 memory and caused the error in the 1st test.
>>>                 >>>>>> Is there is a way to show how much memory it
>>>                 allocated?
>>>                 >>>>>> Frank
>>>                 >>>>>> On 07/05/2016 03:37 PM, Barry Smith wrote:
>>>                 >>>>>>    Frank,
>>>                 >>>>>>      You can run with -ksp_view_pre to have
>>>                 it "view" the KSP before the solve so hopefully it
>>>                 gets that far.
>>>                 >>>>>>       Please run the problem that does fit
>>>                 with -memory_info when the problem completes it will
>>>                 show the "high water mark" for PETSc allocated
>>>                 memory and total memory used. We first want to look
>>>                 at these numbers to see if it is using more memory
>>>                 than you expect. You could also run with say half
>>>                 the grid spacing to see how the memory usage scaled
>>>                 with the increase in grid points. Make the runs also
>>>                 with -log_view and send all the output from these
>>>                 options.
>>>                 >>>>>>     Barry
>>>                 >>>>>> On Jul 5, 2016, at 5:23 PM, frank
>>>                 >>>>>> Hi,
>>>                 >>>>>> I am using the CG ksp solver and Multigrid
>>>                 preconditioner  to solve a linear system in parallel.
>>>                 >>>>>> I chose to use the 'Telescope' as the
>>>                 preconditioner on the coarse mesh for its good
>>>                 performance.
>>>                 >>>>>> The petsc options file is attached.
>>>                 >>>>>> The domain is a 3d box.
>>>                 >>>>>> It works well when the grid is  1536*128*384
>>>                 and the process mesh is 96*8*24. When I double the
>>>                 size of grid and                                keep
>>>                 the same process mesh and petsc options, I get an
>>>                 "out of memory" error from the super-cluster I am using.
>>>                 >>>>>> Each process has access to at least 8G
>>>                 memory, which should be more than enough for my
>>>                 application. I am sure that all the other parts of
>>>                 my code( except the linear solver ) do not use much
>>>                 memory. So I doubt if there is something wrong with
>>>                 the linear solver.
>>>                 >>>>>> The error occurs before the linear system is
>>>                 completely solved so I don't have the info from ksp
>>>                 view. I am not able to re-produce the error with a
>>>                 smaller problem either.
>>>                 >>>>>> In addition, I tried to use the block jacobi
>>>                 as the preconditioner with the same grid and same
>>>                 decomposition. The linear solver runs extremely slow
>>>                 but there is no memory error.
>>>                 >>>>>> How can I diagnose what exactly cause the error?
>>>                 >>>>>> Thank you so much.
>>>                 >>>>>> Frank
>>>                 >>>>>> <petsc_options.txt>
>>>                 <ksp_view_pre.txt><memory_test2.txt><memory_test3.txt><petsc_options.txt>
>>>                 <ksp_view1.txt><ksp_view2.txt><ksp_view3.txt><memory1.txt><memory2.txt><petsc_options1.txt><petsc_options2.txt><petsc_options3.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160916/abb0082c/attachment-0001.html>
KSP Object: 32768 MPI processes
  type: cg
  maximum iterations=10000
  tolerances:  relative=1e-07, absolute=1e-50, divergence=10000.
  left preconditioning
  using nonzero initial guess
  using UNPRECONDITIONED norm type for convergence test
PC Object: 32768 MPI processes
  type: mg
    MG: type is MULTIPLICATIVE, levels=5 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object: (mg_coarse_) 32768 MPI processes
      type: preonly
      maximum iterations=10000, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
      using NONE norm type for convergence test
    PC Object: (mg_coarse_) 32768 MPI processes
      type: telescope
        Telescope: parent comm size reduction factor = 64
        Telescope: comm_size = 32768 , subcomm_size = 512
        Telescope: subcomm type: interlaced
          Telescope: DMDA detected
        DMDA Object:    (mg_coarse_telescope_repart_)    512 MPI processes
          M 64 N 64 P 64 m 8 n 8 p 8 dof 1 overlap 1
        KSP Object: (mg_coarse_telescope_) 512 MPI processes
          type: preonly
        PC Object: (mg_coarse_telescope_) 512 MPI processes
          type: mg
            MG: type is MULTIPLICATIVE, levels=3 cycles=v
            KSP Object: (mg_coarse_telescope_mg_coarse_) 512 MPI processes
              type: preonly
            PC Object: (mg_coarse_telescope_mg_coarse_) 512 MPI processes
              type: redundant
                Redundant preconditioner: First (color=0) of 512 PCs follows
              linear system matrix = precond matrix:
              Mat Object: 512 MPI processes
                type: mpiaij
                rows=4096, cols=4096
                total: nonzeros=110592, allocated nonzeros=110592
                total number of mallocs used during MatSetValues calls =0
                  using I-node (on process 0) routines: found 2 nodes, limit used is 5
          Down solver (pre-smoother) on level 1 -------------------------------
            KSP Object: (mg_coarse_telescope_mg_levels_1_) 512 MPI processes
              type: richardson
                Richardson: damping factor=1.
            PC Object: (mg_coarse_telescope_mg_levels_1_) 512 MPI processes
              type: sor
                SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.
                type: mpiaij
                rows=32768, cols=32768
                total: nonzeros=884736, allocated nonzeros=884736
                  not using I-node (on process 0) routines
          Up solver (post-smoother) same as down solver (pre-smoother)
          Down solver (pre-smoother) on level 2 -------------------------------
            KSP Object: (mg_coarse_telescope_mg_levels_2_) 512 MPI processes
              type: richardson
            PC Object: (mg_coarse_telescope_mg_levels_2_) 512 MPI processes
              type: sor
                type: mpiaij
                rows=262144, cols=262144
                total: nonzeros=7077888, allocated nonzeros=7077888
            type: mpiaij
                      KSP Object:       (mg_coarse_telescope_mg_coarse_redundant_)       1 MPI processes
                        type: preonly
                      PC Object:       (mg_coarse_telescope_mg_coarse_redundant_)       1 MPI processes
                        type: bjacobi
                          block Jacobi: number of blocks = 1
                          Local solve is same for all blocks, in the following KSP and PC objects:
                          KSP Object:       (mg_coarse_telescope_mg_coarse_redundant_sub_)       1 MPI processes
                            type: preonly
                          PC Object:       (mg_coarse_telescope_mg_coarse_redundant_sub_)       1 MPI processes
                            type: ilu
                              ILU: out-of-place factorization
                              0 levels of fill
                              tolerance for zero pivot 2.22045e-14
                              matrix ordering: natural
                              factor fill ratio given 1., needed 1.
                                Factored matrix follows:
                                  Mat Object:       1 MPI processes
                                    type: seqaij
                                    package used to perform factorization: petsc
                                      not using I-node routines
                              type: seqaij
                          type: seqaij
      Mat Object: 32768 MPI processes
        type: mpiaij
    KSP Object: (mg_levels_1_) 32768 MPI processes
      type: richardson
    PC Object: (mg_levels_1_) 32768 MPI processes
      type: sor
        type: mpiaij
        rows=2097152, cols=2097152
        total: nonzeros=56623104, allocated nonzeros=56623104
    KSP Object: (mg_levels_2_) 32768 MPI processes
      type: richardson
    PC Object: (mg_levels_2_) 32768 MPI processes
      type: sor
        type: mpiaij
        rows=16777216, cols=16777216
        total: nonzeros=452984832, allocated nonzeros=452984832
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object: (mg_levels_3_) 32768 MPI processes
      type: richardson
    PC Object: (mg_levels_3_) 32768 MPI processes
      type: sor
        type: mpiaij
        rows=134217728, cols=134217728
        total: nonzeros=3623878656, allocated nonzeros=3623878656
  Down solver (pre-smoother) on level 4 -------------------------------
    KSP Object: (mg_levels_4_) 32768 MPI processes
      type: richardson
    PC Object: (mg_levels_4_) 32768 MPI processes
      type: sor
        type: mpiaij
        rows=1073741824, cols=1073741824
        total: nonzeros=7516192768, allocated nonzeros=7516192768
          has attached null space
    type: mpiaij
32768 processors, by hengjie Fri Sep 16 04:29:10 2016
Using Petsc Development GIT revision: v3.7.3-1056-geeb1ceb  GIT Date: 2016-08-02 10:00:58 -0500
                         Max       Max/Min        Avg      Total
Time (sec):           3.595e+01      1.00092   3.595e+01
Objects:              4.240e+02      1.61217   2.655e+02
Flops:                7.348e+07      1.09866   6.699e+07  2.195e+12
Flops/sec:            2.044e+06      1.09875   1.863e+06  6.106e+10
Memory:               1.110e+09      1.00000              3.636e+13
MPI Messages:         5.004e+04     11.27696   4.668e+03  1.530e+08
MPI Message Lengths:  4.805e+06      1.27794   8.088e+02  1.237e+11
MPI Reductions:       2.296e+03      1.48994
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 3.5947e+01 100.0%  2.1951e+12 100.0%  1.530e+08 100.0%  8.088e+02      100.0%  1.551e+03  67.5%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
      #                          WARNING!!!                    #
      #   This code was compiled with a debugging option,      #
      #   To get timing results run ./configure                #
      #   using --with-debugging=no, the performance will      #
      #   be generally two or three times faster.              #
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecTDot               30 1.0 1.9905e-01 1.4 1.97e+06 1.0 0.0e+00 0.0e+00 6.0e+01  1  3  0  0  3   1  3  0  0  4 323650
VecNorm               16 1.0 3.9425e-01 3.5 1.05e+06 1.0 0.0e+00 0.0e+00 3.2e+01  1  2  0  0  1   1  2  0  0  2 87152
VecScale              75 1.7 2.3286e-02 2.0 4.52e+04 1.3 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 50363
VecCopy               17 1.0 3.8621e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               442 1.7 9.8095e-03 2.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               60 1.0 3.5868e-02 1.3 3.93e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  6  0  0  0   0  6  0  0  0 3592294
VecAYPX              119 1.3 1.7319e-02 1.3 1.98e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0 3728684
VecAssemblyBegin       1 1.0 1.0757e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         1 1.0 2.7490e-04 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin      471 1.5 5.8588e-02 3.4 0.00e+00 0.0 1.2e+08 8.1e+02 0.0e+00  0  0 81 81  0   0  0 81 81  0     0
VecScatterEnd        471 1.5 1.2934e+00 6.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
MatMult              135 1.3 2.8880e-01 1.4 2.33e+07 1.0 5.0e+07 1.7e+03 0.0e+00  1 34 32 66  0   1 34 32 66  0 2597254
MatMultAdd            90 1.5 1.1149e-01 2.9 3.85e+06 1.0 1.4e+07 3.2e+02 0.0e+00  0  6  9  4  0   0  6  9  4  0 1114404
MatMultTranspose     111 1.4 3.0435e-01 1.3 4.11e+06 1.0 1.7e+07 2.8e+02 8.0e+01  1  6 11  4  3   1  6 11  4  5 435479
MatSolve              15 0.0 2.0206e-02 0.0 3.26e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 82513
MatSOR               180 1.5 9.9816e-01 1.3 2.32e+07 1.0 3.9e+07 2.4e+02 1.2e+00  2 33 25  8  0   2 33 25  8  0 727846
MatLUFactorNum         1 0.0 2.4225e-02 0.0 1.60e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 33762
MatILUFactorSym        1 0.0 2.5048e-03 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatConvert             1 0.0 7.5793e-04 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatResidual           90 1.5 3.7126e-01 1.2 1.11e+07 1.0 4.2e+07 8.0e+02 6.0e+01  1 16 27 27  3   1 16 27 27  4 942007
MatAssemblyBegin      33 1.4 7.2762e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 4.8e+01  2  0  0  0  2   2  0  0  0  3     0
MatAssemblyEnd        33 1.4 1.4643e+00 1.1 0.00e+00 0.0 1.1e+07 1.2e+02 2.5e+02  4  0  7  1 11   4  0  7  1 16     0
MatGetRowIJ            1 0.0 1.5974e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice       2 2.0 3.4627e-01 3.7 0.00e+00 0.0 1.6e+05 5.4e+02 6.1e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         1 0.0 1.9929e-03 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatView               13 2.2 1.0639e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.2e+01  0  0  0  0  1   0  0  0  0  1     0
MatPtAP                7 1.4 5.2281e+00 1.0 5.25e+06 1.0 2.4e+07 8.8e+02 2.1e+02 14  8 15 17  9  14  8 15 17 14 31939
MatPtAPSymbolic        7 1.4 4.0818e+00 1.0 0.00e+00 0.0 1.4e+07 1.1e+03 7.5e+01 11  0  9 12  3  11  0  9 12  5     0
MatPtAPNumeric         7 1.4 1.1755e+00 1.0 5.25e+06 1.0 9.6e+06 5.7e+02 1.4e+02  3  8  6  4  6   3  8  6  4  9 142046
MatRedundantMat        1 0.0 1.3647e-02 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 7.8e-02  0  0  0  0  0   0  0  0  0  0     0
MatMPIConcateSeq       1 0.0 2.7197e-01 0.0 0.00e+00 0.0 2.7e+04 4.0e+01 6.1e-01  0  0  0  0  0   0  0  0  0  0     0
MatGetLocalMat         7 1.4 1.3259e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetBrAoCol          7 1.4 6.9566e-02 2.8 0.00e+00 0.0 1.1e+07 1.1e+03 0.0e+00  0  0  7 10  0   0  0  7 10  0     0
MatGetSymTrans        14 1.4 2.2139e-02 5.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
DMCoarsen              6 1.5 3.3237e-01 1.1 0.00e+00 0.0 1.6e+06 1.7e+02 2.1e+02  1  0  1  0  9   1  0  1  0 13     0
DMCreateInterp         6 1.5 7.6958e-01 1.1 2.57e+05 1.0 2.8e+06 1.6e+02 2.0e+02  2  0  2  0  9   2  0  2  0 13 10763
KSPSetUp              12 2.0 1.1138e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 3.5e+01  0  0  0  0  2   0  0  0  0  2     0
KSPSolve               1 1.0 1.2628e+01 1.0 7.35e+07 1.1 1.5e+08 8.0e+02 1.4e+03 35100 99 99 59  35100 99 99 87 173826
PCSetUp                3 3.0 9.2140e+00 1.1 7.10e+06 1.3 2.9e+07 7.4e+02 7.9e+02 23  8 19 18 34  23  8 19 18 51 19110
PCSetUpOnBlocks       15 0.0 2.8822e-02 0.0 1.60e+06 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 28377
PCApply               15 1.0 3.5384e+00 1.0 5.58e+07 1.1 1.2e+08 6.3e+02 3.7e+02 10 74 79 62 16  10 74 79 62 24 457052
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector   197            197      4396000     0.
      Vector Scatter    27             27       333392     0.
              Matrix    66             66     14132608     0.
   Matrix Null Space     1              1          592     0.
    Distributed Mesh     8              8        40832     0.
Star Forest Bipartite Graph    16             16        13568     0.
     Discrete System     8              8         7008     0.
           Index Set    60             60       341672     0.
   IS L to G Mapping     8              8       195776     0.
       Krylov Solver    12             12        14760     0.
     DMKSP interface     6              6         3888     0.
      Preconditioner    12             12        11928     0.
              Viewer     3              2         1664     0.
Average time to get PetscTime(): 9.53674e-08
Average time for MPI_Barrier(): 0.000146198
Average time for zero size MPI_Send(): 3.66852e-06
