[petsc-users] Question about memory usage in Multigrid preconditioner
Dave May dave.mayhem23 at gmail.com
Thu Sep 15 05:35:47 CDT 2016
HI all,
I the only unexpected memory usage I can see is associated with the call to
MatPtAP().
Here is something you can try immediately.
Run your code with the additional options
  -matrap 0 -matptap_scalable
I didn't realize this before, but the default behaviour of MatPtAP in
parallel is actually to to explicitly form the transpose of P (e.g.
assemble R = P^T) and then compute R.A.P.
You don't want to do this. The option -matrap 0 resolves this issue.
The implementation of P^T.A.P has two variants.
The scalable implementation (with respect to memory usage) is selected via
the second option -matptap_scalable.
Try it out - I see a significant memory reduction using these options for
particular mesh sizes / partitions.
I've attached a cleaned up version of the code you sent me.
There were a number of memory leaks and other issues.
The main points being
  * You should call DMDAVecGetArrayF90() before VecAssembly{Begin,End}
  * You should call PetscFinalize(), otherwise the option -log_summary
(-log_view) will not display anything once the program has completed.
  Dave
On 15 September 2016 at 08:03, Hengjie Wang <hengjiew at uci.edu> wrote:
> Hi Dave,
> Sorry, I should have put more comment to explain the code.
> The number of process in each dimension is the same: Px = Py=Pz=P. So is
> the domain size.
> So if the you want to run the code for a  512^3 grid points on 16^3 cores,
> you need to set "-N 512 -P 16" in the command line.
> I add more comments and also fix an error in the attached code. ( The
> error only effects the accuracy of solution but not the memory usage. )
> Thank you.
> Frank
> On 9/14/2016 9:05 PM, Dave May wrote:
> On Thursday, 15 September 2016, Dave May <dave.mayhem23 at gmail.com> wrote:
>> On Thursday, 15 September 2016, frank <hengjiew at uci.edu> wrote:
>>> Hi,
>>> I write a simple code to re-produce the error. I hope this can help to
>>> diagnose the problem.
>>> The code just solves a 3d poisson equation.
>> Why is the stencil width a runtime parameter?? And why is the default
>> value 2? For 7-pnt FD Laplace, you only need a stencil width of 1.
>> Was this choice made to mimic something in the real application code?
> Please ignore - I misunderstood your usage of the param set by -P
>>> I run the code on a 1024^3 mesh. The process partition is 32 * 32 * 32.
>>> That's when I re-produce the OOM error. Each core has about 2G memory.
>>> I also run the code on a 512^3 mesh with 16 * 16 * 16 processes. The ksp
>>> solver works fine.
>>> I attached the code, ksp_view_pre's output and my petsc option file.
>>> Thank you.
>>> Frank
>>> On 09/09/2016 06:38 PM, Hengjie Wang wrote:
>>> Hi Barry,
>>> I checked. On the supercomputer, I had the option "-ksp_view_pre" but it
>>> is not in file I sent you. I am sorry for the confusion.
>>> Regards,
>>> Frank
>>> On Friday, September 9, 2016, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> > On Sep 9, 2016, at 3:11 PM, frank <hengjiew at uci.edu> wrote:
>>>> > Hi Barry,
>>>> > I think the first KSP view output is from -ksp_view_pre. Before I
>>>> submitted the test, I was not sure whether there would be OOM error or not.
>>>> So I added both -ksp_view_pre and -ksp_view.
>>>>   But the options file you sent specifically does NOT list the
>>>> -ksp_view_pre so how could it be from that?
>>>>    Sorry to be pedantic but I've spent too much time in the past trying
>>>> to debug from incorrect information and want to make sure that the
>>>> information I have is correct before thinking. Please recheck exactly what
>>>> happened. Rerun with the exact input file you emailed if that is needed.
>>>>    Barry
>>>> > Frank
>>>> > On 09/09/2016 12:38 PM, Barry Smith wrote:
>>>> >>   Why does ksp_view2.txt have two KSP views in it while
>>>> ksp_view1.txt has only one KSPView in it? Did you run two different solves
>>>> in the 2 case but not the one?
>>>> >>   Barry
>>>> >>> On Sep 9, 2016, at 10:56 AM, frank <hengjiew at uci.edu> wrote:
>>>> >>> Hi,
>>>> >>> I want to continue digging into the memory problem here.
>>>> >>> I did find a work around in the past, which is to use less cores
>>>> per node so that each core has 8G memory. However this is deficient and
>>>> expensive. I hope to locate the place that uses the most memory.
>>>> >>> Here is a brief summary of the tests I did in past:
>>>> >>>> Test1:   Mesh 1536*128*384  |  Process Mesh 48*4*12
>>>> >>> Maximum (over computational time) process memory:           total
>>>> 7.0727e+08
>>>> >>> Current process memory:
>>>>              total 7.0727e+08
>>>> >>> Maximum (over computational time) space PetscMalloc()ed:  total
>>>> 6.3908e+11
>>>> >>> Current space PetscMalloc()ed:
>>>>           total 1.8275e+09
>>>> >>>> Test2:    Mesh 1536*128*384  |  Process Mesh 96*8*24
>>>> 5.9431e+09
>>>>              total 5.9431e+09
>>>> 5.3202e+12
>>>>            total 5.4844e+09
>>>> >>>> Test3:    Mesh 3072*256*768  |  Process Mesh 96*8*24
>>>> >>>     OOM( Out Of Memory ) killer of the supercomputer terminated the
>>>> job during "KSPSolve".
>>>> >>> I attached the output of ksp_view( the third test's output is from
>>>> ksp_view_pre ), memory_view and also the petsc options.
>>>> >>> In all the tests, each core can access about 2G memory. In test3,
>>>> there are 4223139840 non-zeros in the matrix. This will consume about
>>>> 1.74M, using double precision. Considering some extra memory used to store
>>>> integer index, 2G memory should still be way enough.
>>>> >>> Is there a way to find out which part of KSPSolve uses the most
>>>> memory?
>>>> >>> Thank you so much.
>>>> >>> BTW, there are 4 options remains unused and I don't understand why
>>>> they are omitted:
>>>> >>> -mg_coarse_telescope_mg_coarse_ksp_type value: preonly
>>>> >>> -mg_coarse_telescope_mg_coarse_pc_type value: bjacobi
>>>> >>> -mg_coarse_telescope_mg_levels_ksp_max_it value: 1
>>>> >>> -mg_coarse_telescope_mg_levels_ksp_type value: richardson
>>>> >>> Regards,
>>>> >>> Frank
>>>> >>> On 07/13/2016 05:47 PM, Dave May wrote:
>>>> >>>> On 14 July 2016 at 01:07, frank <hengjiew at uci.edu> wrote:
>>>> >>>> Hi Dave,
>>>> >>>> Sorry for the late reply.
>>>> >>>> Thank you so much for your detailed reply.
>>>> >>>> I have a question about the estimation of the memory usage. There
>>>> are 4223139840 allocated non-zeros and 18432 MPI processes. Double
>>>> precision is used. So the memory per process is:
>>>> >>>>   4223139840 * 8bytes / 18432 / 1024 / 1024 = 1.74M ?
>>>> >>>> Did I do sth wrong here? Because this seems too small.
>>>> >>>> No - I totally f***ed it up. You are correct. That'll teach me for
>>>> fumbling around with my iphone calculator and not using my brain. (Note
>>>> that to convert to MB just divide by 1e6, not 1024^2 - although I
>>>> apparently cannot convert between units correctly....)
>>>> >>>> From the PETSc objects associated with the solver, It looks like
>>>> it _should_ run with 2GB per MPI rank. Sorry for my mistake. Possibilities
>>>> are: somewhere in your usage of PETSc you've introduced a memory leak;
>>>> PETSc is doing a huge over allocation (e.g. as per our discussion of
>>>> MatPtAP); or in your application code there are other objects you have
>>>> forgotten to log the memory for.
>>>> >>>> I am running this job on Bluewater
>>>> >>>> I am using the 7 points FD stencil in 3D.
>>>> >>>> I thought so on both counts.
>>>> >>>> I apologize that I made a stupid mistake in computing the memory
>>>> per core. My settings render each core can access only 2G memory on average
>>>> instead of 8G which I mentioned in previous email. I re-run the job with 8G
>>>> memory per core on average and there is no "Out Of Memory" error. I would
>>>> do more test to see if there is still some memory issue.
>>>> >>>> Ok. I'd still like to know where the memory was being used since
>>>> my estimates were off.
>>>> >>>> Thanks,
>>>> >>>>   Dave
>>>> >>>> Regards,
>>>> >>>> Frank
>>>> >>>> On 07/11/2016 01:18 PM, Dave May wrote:
>>>> >>>>> Hi Frank,
>>>> >>>>> On 11 July 2016 at 19:14, frank <hengjiew at uci.edu> wrote:
>>>> >>>>> Hi Dave,
>>>> >>>>> I re-run the test using bjacobi as the preconditioner on the
>>>> coarse mesh of telescope. The Grid is 3072*256*768 and process mesh is
>>>> 96*8*24. The petsc option file is attached.
>>>> >>>>> I still got the "Out Of Memory" error. The error occurred before
>>>> the linear solver finished one step. So I don't have the full info from
>>>> ksp_view. The info from ksp_view_pre is attached.
>>>> >>>>> Okay - that is essentially useless (sorry)
>>>> >>>>> It seems to me that the error occurred when the decomposition was
>>>> going to be changed.
>>>> >>>>> Based on what information?
>>>> >>>>> Running with -info would give us more clues, but will create a
>>>> ton of output.
>>>> >>>>> Please try running the case which failed with -info
>>>> >>>>>  I had another test with a grid of 1536*128*384 and the same
>>>> process mesh as above. There was no error. The ksp_view info is attached
>>>> for comparison.
>>>> >>>>> Thank you.
>>>> >>>>> [3] Here is my crude estimate of your memory usage.
>>>> >>>>> I'll target the biggest memory hogs only to get an order of
>>>> magnitude estimate
>>>> >>>>> * The Fine grid operator contains 4223139840 non-zeros --> 1.8 GB
>>>> per MPI rank assuming double precision.
>>>> >>>>> The indices for the AIJ could amount to another 0.3 GB (assuming
>>>> 32 bit integers)
>>>> >>>>> * You use 5 levels of coarsening, so the other operators should
>>>> represent (collectively)
>>>> >>>>> 2.1 / 8 + 2.1/8^2 + 2.1/8^3 + 2.1/8^4  ~ 300 MB per MPI rank on
>>>> the communicator with 18432 ranks.
>>>> >>>>> The coarse grid should consume ~ 0.5 MB per MPI rank on the
>>>> >>>>> * You use a reduction factor of 64, making the new communicator
>>>> with 288 MPI ranks.
>>>> >>>>> PCTelescope will first gather a temporary matrix associated with
>>>> your coarse level operator assuming a comm size of 288 living on the comm
>>>> with size 18432.
>>>> >>>>> This matrix will require approximately 0.5 * 64 = 32 MB per core
>>>> on the 288 ranks.
>>>> >>>>> This matrix is then used to form a new MPIAIJ matrix on the
>>>> subcomm, thus require another 32 MB per rank.
>>>> >>>>> The temporary matrix is now destroyed.
>>>> >>>>> * Because a DMDA is detected, a permutation matrix is assembled.
>>>> >>>>> This requires 2 doubles per point in the DMDA.
>>>> >>>>> Your coarse DMDA contains 92 x 16 x 48 points.
>>>> >>>>> Thus the permutation matrix will require < 1 MB per MPI rank on
>>>> the sub-comm.
>>>> >>>>> * Lastly, the matrix is permuted. This uses MatPtAP(), but the
>>>> resulting operator will have the same memory footprint as the unpermuted
>>>> matrix (32 MB). At any stage in PCTelescope, only 2 operators of size 32 MB
>>>> are held in memory when the DMDA is provided.
>>>> >>>>> From my rough estimates, the worst case memory foot print for any
>>>> given core, given your options is approximately
>>>> >>>>> 2100 MB + 300 MB + 32 MB + 32 MB + 1 MB  = 2465 MB
>>>> >>>>> This is way below 8 GB.
>>>> >>>>> Note this estimate completely ignores:
>>>> >>>>> (1) the memory required for the restriction operator,
>>>> >>>>> (2) the potential growth in the number of non-zeros per row due
>>>> to Galerkin coarsening (I wished -ksp_view_pre reported the output from
>>>> MatView so we could see the number of non-zeros required by the coarse
>>>> level operators)
>>>> >>>>> (3) all temporary vectors required by the CG solver, and those
>>>> required by the smoothers.
>>>> >>>>> (4) internal memory allocated by MatPtAP
>>>> >>>>> (5) memory associated with IS's used within PCTelescope
>>>> >>>>> So either I am completely off in my estimates, or you have not
>>>> carefully estimated the memory usage of your application code. Hopefully
>>>> others might examine/correct my rough estimates
>>>> >>>>> Since I don't have your code I cannot access the latter.
>>>> >>>>> Since I don't have access to the same machine you are running on,
>>>> I think we need to take a step back.
>>>> >>>>> [1] What machine are you running on? Send me a URL if its
>>>> available
>>>> >>>>> [2] What discretization are you using? (I am guessing a scalar 7
>>>> point FD stencil)
>>>> >>>>> If it's a 7 point FD stencil, we should be able to examine the
>>>> memory usage of your solver configuration using a standard, light weight
>>>> existing PETSc example, run on your machine at the same scale.
>>>> >>>>> This would hopefully enable us to correctly evaluate the actual
>>>> memory usage required by the solver configuration you are using.
>>>> >>>>> Thanks,
>>>> >>>>>   Dave
>>>> >>>>> Frank
>>>> >>>>> On 07/08/2016 10:38 PM, Dave May wrote:
>>>> >>>>>> On Saturday, 9 July 2016, frank <hengjiew at uci.edu> wrote:
>>>> >>>>>> Hi Barry and Dave,
>>>> >>>>>> Thank both of you for the advice.
>>>> >>>>>> @Barry
>>>> >>>>>> I made a mistake in the file names in last email. I attached the
>>>> correct files this time.
>>>> >>>>>> For all the three tests, 'Telescope' is used as the coarse
>>>> preconditioner.
>>>> >>>>>> == Test1:   Grid: 1536*128*384,   Process Mesh: 48*4*12
>>>> >>>>>> Part of the memory usage:  Vector   125            124 3971904
>>>>    0.
>>>> >>>>>>                                              Matrix   101 101
>>>>   9462372     0
>>>> >>>>>> == Test2: Grid: 1536*128*384,   Process Mesh: 96*8*24
>>>> >>>>>> Part of the memory usage:  Vector   125            124 681672
>>>>  0.
>>>> >>>>>>                                              Matrix   101 101
>>>>   1462180     0.
>>>> >>>>>> In theory, the memory usage in Test1 should be 8 times of Test2.
>>>> In my case, it is about 6 times.
>>>> >>>>>> == Test3: Grid: 3072*256*768,   Process Mesh: 96*8*24.
>>>> Sub-domain per process: 32*32*32
>>>> >>>>>> Here I get the out of memory error.
>>>> >>>>>> I tried to use -mg_coarse jacobi. In this way, I don't need to
>>>> set -mg_coarse_ksp_type and -mg_coarse_pc_type explicitly, right?
>>>> >>>>>> The linear solver didn't work in this case. Petsc output some
>>>> errors.
>>>> >>>>>> @Dave
>>>> >>>>>> In test3, I use only one instance of 'Telescope'. On the coarse
>>>> mesh of 'Telescope', I used LU as the preconditioner instead of SVD.
>>>> >>>>>> If my set the levels correctly, then on the last coarse mesh of
>>>> MG where it calls 'Telescope', the sub-domain per process is 2*2*2.
>>>> >>>>>> On the last coarse mesh of 'Telescope', there is only one grid
>>>> point per process.
>>>> >>>>>> I still got the OOM error. The detailed petsc option file is
>>>> attached.
>>>> >>>>>> Do you understand the expected memory usage for the particular
>>>> parallel LU implementation you are using? I don't (seriously). Replace LU
>>>> with bjacobi and re-run this test. My point about solver debugging is still
>>>> valid.
>>>> >>>>>> And please send the result of KSPView so we can see what is
>>>> actually used in the computations
>>>> >>>>>> Thanks
>>>> >>>>>>   Dave
>>>> >>>>>> Thank you so much.
>>>> >>>>>> Frank
>>>> >>>>>> On 07/06/2016 02:51 PM, Barry Smith wrote:
>>>> >>>>>> On Jul 6, 2016, at 4:19 PM, frank <hengjiew at uci.edu> wrote:
>>>> >>>>>> Hi Barry,
>>>> >>>>>> Thank you for you advice.
>>>> >>>>>> I tried three test. In the 1st test, the grid is 3072*256*768
>>>> and the process mesh is 96*8*24.
>>>> >>>>>> The linear solver is 'cg' the preconditioner is 'mg' and
>>>> 'telescope' is used as the preconditioner at the coarse mesh.
>>>> >>>>>> The system gives me the "Out of Memory" error before the linear
>>>> system is completely solved.
>>>> >>>>>> The info from '-ksp_view_pre' is attached. I seems to me that
>>>> the error occurs when it reaches the coarse mesh.
>>>> >>>>>> The 2nd test uses a grid of 1536*128*384 and process mesh is
>>>> 96*8*24. The 3rd                                             test uses the
>>>> same grid but a different process mesh 48*4*12.
>>>> >>>>>>     Are you sure this is right? The total matrix and vector
>>>> memory usage goes from 2nd test
>>>> >>>>>>                Vector   384            383      8,193,712     0.
>>>> >>>>>>                Matrix   103            103     11,508,688     0.
>>>> >>>>>> to 3rd test
>>>> >>>>>>               Vector   384            383      1,590,520     0.
>>>> >>>>>>                Matrix   103            103      3,508,664     0.
>>>> >>>>>> that is the memory usage got smaller but if you have only 1/8th
>>>> the processes and the same grid it should have gotten about 8 times bigger.
>>>> Did you maybe cut the grid by a factor of 8 also? If so that still doesn't
>>>> explain it because the memory usage changed by a factor of 5 something for
>>>> the vectors and 3 something for the matrices.
>>>> >>>>>> The linear solver and petsc options in 2nd and 3rd tests are the
>>>> same in 1st test. The linear solver works fine in both test.
>>>> >>>>>> I attached the memory usage of the 2nd and 3rd tests. The memory
>>>> info is from the option '-log_summary'. I tried to use '-momery_info' as
>>>> you suggested, but in my case petsc treated it as an unused option. It
>>>> output nothing about the memory. Do I need to add sth to my code so I can
>>>> use '-memory_info'?
>>>> >>>>>>     Sorry, my mistake the option is -memory_view
>>>> >>>>>>    Can you run the one case with -memory_view and -mg_coarse
>>>> jacobi -ksp_max_it 1 (just so it doesn't iterate forever) to see how much
>>>> memory is used without the telescope? Also run case 2 the same way.
>>>> >>>>>>    Barry
>>>> >>>>>> In both tests the memory usage is not large.
>>>> >>>>>> It seems to me that it might be the 'telescope'  preconditioner
>>>> that allocated a lot of memory and caused the error in the 1st test.
>>>> >>>>>> Is there is a way to show how much memory it allocated?
>>>> >>>>>> Frank
>>>> >>>>>> On 07/05/2016 03:37 PM, Barry Smith wrote:
>>>> >>>>>>    Frank,
>>>> >>>>>>      You can run with -ksp_view_pre to have it "view" the KSP
>>>> before the solve so hopefully it gets that far.
>>>> >>>>>>       Please run the problem that does fit with -memory_info
>>>> when the problem completes it will show the "high water mark" for PETSc
>>>> allocated memory and total memory used. We first want to look at these
>>>> numbers to see if it is using more memory than you expect. You could also
>>>> run with say half the grid spacing to see how the memory usage scaled with
>>>> the increase in grid points. Make the runs also with -log_view and send all
>>>> the output from these options.
>>>> >>>>>>     Barry
>>>> >>>>>> On Jul 5, 2016, at 5:23 PM, frank <hengjiew at uci.edu> wrote:
>>>> >>>>>> Hi,
>>>> >>>>>> I am using the CG ksp solver and Multigrid preconditioner  to
>>>> solve a linear system in parallel.
>>>> >>>>>> I chose to use the 'Telescope' as the preconditioner on the
>>>> coarse mesh for its good performance.
>>>> >>>>>> The petsc options file is attached.
>>>> >>>>>> The domain is a 3d box.
>>>> >>>>>> It works well when the grid is  1536*128*384 and the process
>>>> mesh is 96*8*24. When I double the size of grid and
>>>>                          keep the same process mesh and petsc options, I
>>>> get an "out of memory" error from the super-cluster I am using.
>>>> >>>>>> Each process has access to at least 8G memory, which should be
>>>> more than enough for my application. I am sure that all the other parts of
>>>> my code( except the linear solver ) do not use much memory. So I doubt if
>>>> there is something wrong with the linear solver.
>>>> >>>>>> The error occurs before the linear system is completely solved
>>>> so I don't have the info from ksp view. I am not able to re-produce the
>>>> error with a smaller problem either.
>>>> >>>>>> In addition,  I tried to use the block jacobi as the
>>>> preconditioner with the same grid and same decomposition. The linear solver
>>>> runs extremely slow but there is no memory error.
>>>> >>>>>> How can I diagnose what exactly cause the error?
>>>> >>>>>> Thank you so much.
>>>> >>>>>> Frank
>>>> >>>>>> <petsc_options.txt>
>>>> >>>>>> <ksp_view_pre.txt><memory_test2.txt><memory_test3.txt><petsc
>>>> _options.txt>
>>>> >>> <ksp_view1.txt><ksp_view2.txt><ksp_view3.txt><memory1.txt><m
>>>> emory2.txt><petsc_options1.txt><petsc_options2.txt><petsc_options3.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160915/7e5437c9/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160915/7e5437c9/attachment-0001.obj>
