[petsc-users] Question about memory usage in Multigrid preconditioner
frank
hengjiew at uci.edu
Wed Sep 14 17:24:02 CDT 2016
I write a simple code to re-produce the error. I hope this can help to
diagnose the problem.
The code just solves a 3d poisson equation.
I run the code on a 1024^3 mesh. The process partition is 32 * 32 * 32.
That's when I re-produce the OOM error. Each core has about 2G memory.
I also run the code on a 512^3 mesh with 16 * 16 * 16 processes. The ksp
solver works fine.
I attached the code, ksp_view_pre's output and my petsc option file.
Thank you.
Frank
On 09/09/2016 06:38 PM, Hengjie Wang wrote:
> Hi Barry,
> I checked. On the supercomputer, I had the option "-ksp_view_pre" but
> it is not in file I sent you. I am sorry for the confusion.
> Regards,
> Frank
> On Friday, September 9, 2016, Barry Smith <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
> > On Sep 9, 2016, at 3:11 PM, frank <hengjiew at uci.edu
> <javascript:;>> wrote:
> > Hi Barry,
> > I think the first KSP view output is from -ksp_view_pre. Before
> I submitted the test, I was not sure whether there would be OOM
> error or not. So I added both -ksp_view_pre and -ksp_view.
> But the options file you sent specifically does NOT list the
> -ksp_view_pre so how could it be from that?
> Sorry to be pedantic but I've spent too much time in the past
> trying to debug from incorrect information and want to make sure
> that the information I have is correct before thinking. Please
> recheck exactly what happened. Rerun with the exact input file you
> emailed if that is needed.
> Barry
> > Frank
> > On 09/09/2016 12:38 PM, Barry Smith wrote:
> >> Why does ksp_view2.txt have two KSP views in it while
> ksp_view1.txt has only one KSPView in it? Did you run two
> different solves in the 2 case but not the one?
> >> Barry
> >>> On Sep 9, 2016, at 10:56 AM, frank <hengjiew at uci.edu
> >>> Hi,
> >>> I want to continue digging into the memory problem here.
> >>> I did find a work around in the past, which is to use less
> cores per node so that each core has 8G memory. However this is
> deficient and expensive. I hope to locate the place that uses the
> most memory.
> >>> Here is a brief summary of the tests I did in past:
> >>>> Test1: Mesh 1536*128*384 | Process Mesh 48*4*12
> >>> Maximum (over computational time) process memory:
> total 7.0727e+08
> >>> Current process memory: total
> 7.0727e+08
> >>> Maximum (over computational time) space PetscMalloc()ed:
> total 6.3908e+11
> >>> Current space PetscMalloc()ed:
> total 1.8275e+09
> >>>> Test2: Mesh 1536*128*384 | Process Mesh 96*8*24
> total 5.9431e+09
> 5.9431e+09
> total 5.3202e+12
> total 5.4844e+09
> >>>> Test3: Mesh 3072*256*768 | Process Mesh 96*8*24
> >>> OOM( Out Of Memory ) killer of the supercomputer
> terminated the job during "KSPSolve".
> >>> I attached the output of ksp_view( the third test's output is
> from ksp_view_pre ), memory_view and also the petsc options.
> >>> In all the tests, each core can access about 2G memory. In
> test3, there are 4223139840 non-zeros in the matrix. This will
> consume about 1.74M, using double precision. Considering some
> extra memory used to store integer index, 2G memory should still
> be way enough.
> >>> Is there a way to find out which part of KSPSolve uses the
> most memory?
> >>> Thank you so much.
> >>> BTW, there are 4 options remains unused and I don't understand
> why they are omitted:
> >>> -mg_coarse_telescope_mg_coarse_ksp_type value: preonly
> >>> -mg_coarse_telescope_mg_coarse_pc_type value: bjacobi
> >>> -mg_coarse_telescope_mg_levels_ksp_max_it value: 1
> >>> -mg_coarse_telescope_mg_levels_ksp_type value: richardson
> >>> Regards,
> >>> Frank
> >>> On 07/13/2016 05:47 PM, Dave May wrote:
> >>>> On 14 July 2016 at 01:07, frank <hengjiew at uci.edu
> >>>> Hi Dave,
> >>>> Sorry for the late reply.
> >>>> Thank you so much for your detailed reply.
> >>>> I have a question about the estimation of the memory usage.
> There are 4223139840 allocated non-zeros and 18432 MPI processes.
> Double precision is used. So the memory per process is:
> >>>> 4223139840 * 8bytes / 18432 / 1024 / 1024 = 1.74M ?
> >>>> Did I do sth wrong here? Because this seems too small.
> >>>> No - I totally f***ed it up. You are correct. That'll teach
> me for fumbling around with my iphone calculator and not using my
> brain. (Note that to convert to MB just divide by 1e6, not 1024^2
> - although I apparently cannot convert between units correctly....)
> >>>> From the PETSc objects associated with the solver, It looks
> like it _should_ run with 2GB per MPI rank. Sorry for my mistake.
> Possibilities are: somewhere in your usage of PETSc you've
> introduced a memory leak; PETSc is doing a huge over allocation
> (e.g. as per our discussion of MatPtAP); or in your application
> code there are other objects you have forgotten to log the memory for.
> >>>> I am running this job on Bluewater
> >>>> I am using the 7 points FD stencil in 3D.
> >>>> I thought so on both counts.
> >>>> I apologize that I made a stupid mistake in computing the
> memory per core. My settings render each core can access only 2G
> memory on average instead of 8G which I mentioned in previous
> email. I re-run the job with 8G memory per core on average and
> there is no "Out Of Memory" error. I would do more test to see if
> there is still some memory issue.
> >>>> Ok. I'd still like to know where the memory was being used
> since my estimates were off.
> >>>> Thanks,
> >>>> Dave
> >>>> Regards,
> >>>> Frank
> >>>> On 07/11/2016 01:18 PM, Dave May wrote:
> >>>>> Hi Frank,
> >>>>> On 11 July 2016 at 19:14, frank <hengjiew at uci.edu
> >>>>> Hi Dave,
> >>>>> I re-run the test using bjacobi as the preconditioner on the
> coarse mesh of telescope. The Grid is 3072*256*768 and process
> mesh is 96*8*24. The petsc option file is attached.
> >>>>> I still got the "Out Of Memory" error. The error occurred
> before the linear solver finished one step. So I don't have the
> full info from ksp_view. The info from ksp_view_pre is attached.
> >>>>> Okay - that is essentially useless (sorry)
> >>>>> It seems to me that the error occurred when the
> decomposition was going to be changed.
> >>>>> Based on what information?
> >>>>> Running with -info would give us more clues, but will create
> a ton of output.
> >>>>> Please try running the case which failed with -info
> >>>>> I had another test with a grid of 1536*128*384 and the same
> process mesh as above. There was no error. The ksp_view info is
> attached for comparison.
> >>>>> Thank you.
> >>>>> [3] Here is my crude estimate of your memory usage.
> >>>>> I'll target the biggest memory hogs only to get an order of
> magnitude estimate
> >>>>> * The Fine grid operator contains 4223139840 non-zeros -->
> 1.8 GB per MPI rank assuming double precision.
> >>>>> The indices for the AIJ could amount to another 0.3 GB
> (assuming 32 bit integers)
> >>>>> * You use 5 levels of coarsening, so the other operators
> should represent (collectively)
> >>>>> 2.1 / 8 + 2.1/8^2 + 2.1/8^3 + 2.1/8^4 ~ 300 MB per MPI rank
> on the communicator with 18432 ranks.
> >>>>> The coarse grid should consume ~ 0.5 MB per MPI rank on the
> >>>>> * You use a reduction factor of 64, making the new
> communicator with 288 MPI ranks.
> >>>>> PCTelescope will first gather a temporary matrix associated
> with your coarse level operator assuming a comm size of 288 living
> on the comm with size 18432.
> >>>>> This matrix will require approximately 0.5 * 64 = 32 MB per
> core on the 288 ranks.
> >>>>> This matrix is then used to form a new MPIAIJ matrix on the
> subcomm, thus require another 32 MB per rank.
> >>>>> The temporary matrix is now destroyed.
> >>>>> * Because a DMDA is detected, a permutation matrix is assembled.
> >>>>> This requires 2 doubles per point in the DMDA.
> >>>>> Your coarse DMDA contains 92 x 16 x 48 points.
> >>>>> Thus the permutation matrix will require < 1 MB per MPI rank
> on the sub-comm.
> >>>>> * Lastly, the matrix is permuted. This uses MatPtAP(), but
> the resulting operator will have the same memory footprint as the
> unpermuted matrix (32 MB). At any stage in PCTelescope, only 2
> operators of size 32 MB are held in memory when the DMDA is provided.
> >>>>> From my rough estimates, the worst case memory foot print
> for any given core, given your options is approximately
> >>>>> 2100 MB + 300 MB + 32 MB + 32 MB + 1 MB = 2465 MB
> >>>>> This is way below 8 GB.
> >>>>> Note this estimate completely ignores:
> >>>>> (1) the memory required for the restriction operator,
> >>>>> (2) the potential growth in the number of non-zeros per row
> due to Galerkin coarsening (I wished -ksp_view_pre reported the
> output from MatView so we could see the number of non-zeros
> required by the coarse level operators)
> >>>>> (3) all temporary vectors required by the CG solver, and
> those required by the smoothers.
> >>>>> (4) internal memory allocated by MatPtAP
> >>>>> (5) memory associated with IS's used within PCTelescope
> >>>>> So either I am completely off in my estimates, or you have
> not carefully estimated the memory usage of your application code.
> Hopefully others might examine/correct my rough estimates
> >>>>> Since I don't have your code I cannot access the latter.
> >>>>> Since I don't have access to the same machine you are
> running on, I think we need to take a step back.
> >>>>> [1] What machine are you running on? Send me a URL if its
> available
> >>>>> [2] What discretization are you using? (I am guessing a
> scalar 7 point FD stencil)
> >>>>> If it's a 7 point FD stencil, we should be able to examine
> the memory usage of your solver configuration using a standard,
> light weight existing PETSc example, run on your machine at the
> same scale.
> >>>>> This would hopefully enable us to correctly evaluate the
> actual memory usage required by the solver configuration you are
> using.
> >>>>> Thanks,
> >>>>> Dave
> >>>>> Frank
> >>>>> On 07/08/2016 10:38 PM, Dave May wrote:
> >>>>>> On Saturday, 9 July 2016, frank <hengjiew at uci.edu
> >>>>>> Hi Barry and Dave,
> >>>>>> Thank both of you for the advice.
> >>>>>> @Barry
> >>>>>> I made a mistake in the file names in last email. I
> attached the correct files this time.
> >>>>>> For all the three tests, 'Telescope' is used as the coarse
> preconditioner.
> >>>>>> == Test1: Grid: 1536*128*384, Process Mesh: 48*4*12
> >>>>>> Part of the memory usage: Vector 125 124
> 3971904 0.
> >>>>>> Matrix 101 101 9462372 0
> >>>>>> == Test2: Grid: 1536*128*384, Process Mesh: 96*8*24
> 681672 0.
> >>>>>> Matrix 101 101 1462180 0.
> >>>>>> In theory, the memory usage in Test1 should be 8 times of
> Test2. In my case, it is about 6 times.
> >>>>>> == Test3: Grid: 3072*256*768, Process Mesh: 96*8*24.
> Sub-domain per process: 32*32*32
> >>>>>> Here I get the out of memory error.
> >>>>>> I tried to use -mg_coarse jacobi. In this way, I don't need
> to set -mg_coarse_ksp_type and -mg_coarse_pc_type explicitly, right?
> >>>>>> The linear solver didn't work in this case. Petsc output
> some errors.
> >>>>>> @Dave
> >>>>>> In test3, I use only one instance of 'Telescope'. On the
> coarse mesh of 'Telescope', I used LU as the preconditioner
> instead of SVD.
> >>>>>> If my set the levels correctly, then on the last coarse
> mesh of MG where it calls 'Telescope', the sub-domain per process
> is 2*2*2.
> >>>>>> On the last coarse mesh of 'Telescope', there is only one
> grid point per process.
> >>>>>> I still got the OOM error. The detailed petsc option file
> is attached.
> >>>>>> Do you understand the expected memory usage for the
> particular parallel LU implementation you are using? I don't
> (seriously). Replace LU with bjacobi and re-run this test. My
> point about solver debugging is still valid.
> >>>>>> And please send the result of KSPView so we can see what is
> actually used in the computations
> >>>>>> Thanks
> >>>>>> Dave
> >>>>>> Thank you so much.
> >>>>>> Frank
> >>>>>> On 07/06/2016 02:51 PM, Barry Smith wrote:
> >>>>>> On Jul 6, 2016, at 4:19 PM, frank <hengjiew at uci.edu
> >>>>>> Hi Barry,
> >>>>>> Thank you for you advice.
> >>>>>> I tried three test. In the 1st test, the grid is
> 3072*256*768 and the process mesh is 96*8*24.
> >>>>>> The linear solver is 'cg' the preconditioner is 'mg' and
> 'telescope' is used as the preconditioner at the coarse mesh.
> >>>>>> The system gives me the "Out of Memory" error before the
> linear system is completely solved.
> >>>>>> The info from '-ksp_view_pre' is attached. I seems to me
> that the error occurs when it reaches the coarse mesh.
> >>>>>> The 2nd test uses a grid of 1536*128*384 and process mesh
> is 96*8*24. The 3rd test uses the
> same grid but a different process mesh 48*4*12.
> >>>>>> Are you sure this is right? The total matrix and vector
> memory usage goes from 2nd test
> >>>>>> Vector 384 383 8,193,712 0.
> >>>>>> Matrix 103 103 11,508,688 0.
> >>>>>> to 3rd test
> >>>>>> Vector 384 383 1,590,520 0.
> >>>>>> Matrix 103 103 3,508,664 0.
> >>>>>> that is the memory usage got smaller but if you have only
> 1/8th the processes and the same grid it should have gotten about
> 8 times bigger. Did you maybe cut the grid by a factor of 8 also?
> If so that still doesn't explain it because the memory usage
> changed by a factor of 5 something for the vectors and 3 something
> for the matrices.
> >>>>>> The linear solver and petsc options in 2nd and 3rd tests
> are the same in 1st test. The linear solver works fine in both test.
> >>>>>> I attached the memory usage of the 2nd and 3rd tests. The
> memory info is from the option '-log_summary'. I tried to use
> '-momery_info' as you suggested, but in my case petsc treated it
> as an unused option. It output nothing about the memory. Do I need
> to add sth to my code so I can use '-memory_info'?
> >>>>>> Sorry, my mistake the option is -memory_view
> >>>>>> Can you run the one case with -memory_view and
> -mg_coarse jacobi -ksp_max_it 1 (just so it doesn't iterate
> forever) to see how much memory is used without the telescope?
> Also run case 2 the same way.
> >>>>>> Barry
> >>>>>> In both tests the memory usage is not large.
> >>>>>> It seems to me that it might be the 'telescope'
> preconditioner that allocated a lot of memory and caused the error
> in the 1st test.
> >>>>>> Is there is a way to show how much memory it allocated?
> >>>>>> Frank
> >>>>>> On 07/05/2016 03:37 PM, Barry Smith wrote:
> >>>>>> Frank,
> >>>>>> You can run with -ksp_view_pre to have it "view" the
> KSP before the solve so hopefully it gets that far.
> >>>>>> Please run the problem that does fit with
> -memory_info when the problem completes it will show the "high
> water mark" for PETSc allocated memory and total memory used. We
> first want to look at these numbers to see if it is using more
> memory than you expect. You could also run with say half the grid
> spacing to see how the memory usage scaled with the increase in
> grid points. Make the runs also with -log_view and send all the
> output from these options.
> >>>>>> Barry
> >>>>>> On Jul 5, 2016, at 5:23 PM, frank <hengjiew at uci.edu
> >>>>>> Hi,
> >>>>>> I am using the CG ksp solver and Multigrid preconditioner
> to solve a linear system in parallel.
> >>>>>> I chose to use the 'Telescope' as the preconditioner on the
> coarse mesh for its good performance.
> >>>>>> The petsc options file is attached.
> >>>>>> The domain is a 3d box.
> >>>>>> It works well when the grid is 1536*128*384 and the process
> mesh is 96*8*24. When I double the size of grid and keep
> the same process mesh and petsc options, I get an "out of memory"
> error from the super-cluster I am using.
> >>>>>> Each process has access to at least 8G memory, which should
> be more than enough for my application. I am sure that all the
> other parts of my code( except the linear solver ) do not use much
> memory. So I doubt if there is something wrong with the linear solver.
> >>>>>> The error occurs before the linear system is completely
> solved so I don't have the info from ksp view. I am not able to
> re-produce the error with a smaller problem either.
> >>>>>> In addition, I tried to use the block jacobi as the
> preconditioner with the same grid and same decomposition. The
> linear solver runs extremely slow but there is no memory error.
> >>>>>> How can I diagnose what exactly cause the error?
> >>>>>> Thank you so much.
> >>>>>> Frank
> >>>>>> <petsc_options.txt>
> <ksp_view_pre.txt><memory_test2.txt><memory_test3.txt><petsc_options.txt>
> <ksp_view1.txt><ksp_view2.txt><ksp_view3.txt><memory1.txt><memory2.txt><petsc_options1.txt><petsc_options2.txt><petsc_options3.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160914/485d77ec/attachment-0001.html>
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160914/485d77ec/attachment-0001.bin>
KSP Object: 32768 MPI processes
type: cg
maximum iterations=10000
tolerances: relative=1e-07, absolute=1e-50, divergence=10000.
left preconditioning
using nonzero initial guess
using UNPRECONDITIONED norm type for convergence test
PC Object: 32768 MPI processes
type: mg
PC has not been set up so information may be incomplete
MG: type is MULTIPLICATIVE, levels=5 cycles=v
Cycles per PCApply=1
Using Galerkin computed coarse grid matrices
Coarse grid solver -- level -------------------------------
KSP Object: (mg_coarse_) 32768 MPI processes
type: preonly
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
using DEFAULT norm type for convergence test
PC Object: (mg_coarse_) 32768 MPI processes
type: redundant
Redundant preconditioner: Not yet setup
Down solver (pre-smoother) on level 1 -------------------------------
KSP Object: (mg_levels_1_) 32768 MPI processes
type: chebyshev
Chebyshev: eigenvalue estimates: min = 0., max = 0.
maximum iterations=2, initial guess is zero
using NONE norm type for convergence test
PC Object: (mg_levels_1_) 32768 MPI processes
type: sor
SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.
Up solver (post-smoother) same as down solver (pre-smoother)
Down solver (pre-smoother) on level 2 -------------------------------
KSP Object: (mg_levels_2_) 32768 MPI processes
type: chebyshev
PC Object: (mg_levels_2_) 32768 MPI processes
type: sor
Down solver (pre-smoother) on level 3 -------------------------------
KSP Object: (mg_levels_3_) 32768 MPI processes
type: chebyshev
PC Object: (mg_levels_3_) 32768 MPI processes
type: sor
Down solver (pre-smoother) on level 4 -------------------------------
KSP Object: (mg_levels_4_) 32768 MPI processes
type: chebyshev
PC Object: (mg_levels_4_) 32768 MPI processes
type: sor
linear system matrix = precond matrix:
Mat Object: 32768 MPI processes
type: mpiaij
rows=1073741824, cols=1073741824
total: nonzeros=7516192768, allocated nonzeros=7516192768
total number of mallocs used during MatSetValues calls =0
has attached null space
-ksp_type cg
-ksp_norm_type unpreconditioned
-ksp_lag_norm
-ksp_rtol 1e-7
-ksp_initial_guess_nonzero yes
-ksp_converged_reason
-pc_type mg
-pc_mg_galerkin
-pc_mg_levels 5
-mg_levels_ksp_type richardson
-mg_levels_ksp_max_it 1
-mg_coarse_ksp_type preonly
-mg_coarse_pc_type telescope
-mg_coarse_pc_telescope_reduction_factor 64
-options_left 1
-log_summary
-ksp_view_pre
#setting dmdarepart on subcomm
-mg_coarse_telescope_repart_da_processors_x 8
-mg_coarse_telescope_repart_da_processors_y 8
-mg_coarse_telescope_repart_da_processors_z 8
-mg_coarse_telescope_ksp_type preonly
-mg_coarse_telescope_pc_type mg
-mg_coarse_telescope_pc_mg_galerkin
-mg_coarse_telescope_pc_mg_levels 3
-mg_coarse_telescope_mg_levels_ksp_max_it 1
-mg_coarse_telescope_mg_levels_ksp_type richardson
-mg_coarse_telescope_mg_coarse_ksp_type preonly
-mg_coarse_telescope_mg_coarse_pc_type redundant
-mg_coarse_telescope_mg_coarse_redundant_pc_type bjacobi
