[petsc-users] KSP_CONVERGED_STEP_LENGTH
Harshad Sahasrabudhe hsahasra at purdue.edu
Wed Sep 14 14:12:01 CDT 2016
Actually, I was using TR with MUMPS before I tried GAMG and it was working
pretty well. The reason I want to switch to GAMG is that I have to increase
my system size, and the simulation just takes too long with MUMPS and
doesn't scale well.
On Wed, Sep 14, 2016 at 3:09 PM, Harshad Sahasrabudhe <hsahasra at purdue.edu>
wrote:
> Hi Barry,
> Sorry, I had no idea that Newton TR would have anything to do with the
> linear solver. I was using TR because it is trustworthy and converges every
> time. I tried LS just now with GAMG+GMRES and it converges, so I don't have
> the CONVERGED_STEP_LENGTH problem anymore.
> Thanks for you help!
> Harshad
> On Wed, Sep 14, 2016 at 2:51 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>    Oh, you are using SNESSolve_NEWTONTR !
>>    Now it all makes sense! The trust region methods impose other
>> conditions on the linear solution so it needs to have their own special
>> convergence test. In particular it requires that the solution from the
>> linear solve be inside the trust region (i.e. not too big)
>>    So, any particular reason you use SNESSolve_NEWTONTR instead of the
>> default line search NEWTONLS? In general unless you have a good reason I
>> recommend just using the NEWTONLS.
>>    If you really want to use the TR then the "early" return from the
>> linear solve is expected, it is controlled by the trust region size and is
>> not under user control.
>>    I'm sorry I was so brain dead and did not realize you had be using TR
>> or we could have resolved this much sooner.
>>    Barry
>> > On Sep 14, 2016, at 1:31 PM, Harshad Sahasrabudhe <hsahasra at purdue.edu>
>> wrote:
>> > Thanks. I now put a watchpoint on
>> > watch *( (PetscErrorCode (**)(KSP, PetscInt, PetscReal,
>> KSPConvergedReason *, void *)) &(ksp->converged) )
>> > The function pointer changes in the first iteration of SNES. It changed
>> at the following place:
>> > Old value =
>> >     (PetscErrorCode (*)(KSP, PetscInt, PetscReal, KSPConvergedReason *,
>> void *)) 0x2b54acdd00aa <KSPConvergedDefault(KSP, PetscInt, PetscReal,
>> KSPConvergedReason*, void*)>
>> > New value =
>> void *)) 0x2b54ad436ce8 <.SNES_TR_KSPConverged_Private
>> .SNES_TR_KSPConverged_Private.SNES_TR_KSPConverged_Private(_p_KSP*, int,
>> double, KSPConvergedReason*, void*)>
>> > KSPSetConvergenceTest (ksp=0x22bf090, converge=0x2b54ad436ce8
>> <SNES_TR_KSPConverged_Private(_p_KSP*, int, double, KSPConvergedReason*,
>> void*)>, cctx=0x1c8b3e0,
>> >     destroy=0x2b54ad437210 <SNES_TR_KSPConverged_Destroy(void*)>)
>> >     at /depot/ncn/apps/conte/conte-gcc-petsc35-dbg/libs/petsc/build
>> -real/src/ksp/ksp/interface/itfunc.c:1768
>> > 1767      ksp->converged        = converge;
>> > Here's the backtrace:
>> > #0  KSPSetConvergenceTest (ksp=0x22bf090, converge=0x2b54ad436ce8
>> > #1  0x00002b54ad43865a in SNESSolve_NEWTONTR (snes=0x1d9e490) at
>> -real/src/snes/impls/tr/tr.c:146
>> > #2  0x00002b54acedab57 in SNESSolve (snes=0x1d9e490, b=0x0, x=0x1923420)
>> -real/src/snes/interface/snes.c:3743
>> > #3  0x00002b54abe8b780 in libMesh::PetscNonlinearSolver<double>::solve
>> (this=0x19198c0, jac_in=..., x_in=..., r_in=...) at
>> src/solvers/petsc_nonlinear_solver.C:714
>> > #4  0x00002b54abefa61d in libMesh::NonlinearImplicitSystem::solve
>> (this=0x1910fe0) at src/systems/nonlinear_implicit_system.C:183
>> > #5  0x00002b54a5dcdceb in NonlinearPoisson::execute_solver
>> (this=0x100c500) at NonlinearPoisson.cpp:1191
>> > #6  0x00002b54a5da733c in NonlinearPoisson::do_solve (this=0x100c500)
>> at NonlinearPoisson.cpp:948
>> > #7  0x00002b54a6423785 in Simulation::solve (this=0x100c500) at
>> Simulation.cpp:781
>> > #8  0x00002b54a634826e in Nemo::run_simulations (this=0x63b020) at
>> Nemo.cpp:1313
>> > #9  0x0000000000426d0d in main (argc=6, argv=0x7ffcdb910768) at
>> main.cpp:447
>> > Thanks,
>> > Harshad
>> > On Wed, Sep 14, 2016 at 2:07 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> >   Super strange, it should never have switched to the function
>> >    Fortunately you can use the same technique to track down where the
>> function pointer changes. Just watch ksp->converged to see when the
>> function pointer gets changed and send back the new stack trace.
>> >    Barry
>> > > On Sep 14, 2016, at 12:39 PM, Harshad Sahasrabudhe <
>> hsahasra at purdue.edu> wrote:
>> > > Hi Barry,
>> > > I put a watchpoint on *((KSP_CONVERGED_REASON*) &(
>> ((_p_KSP*)ksp)->reason )) in gdb. The ksp->reason switched between:
>> > > Old value = KSP_CONVERGED_ITERATING
>> > > New value = KSP_CONVERGED_RTOL
>> > > 0x00002b143054bef2 in KSPConvergedDefault (ksp=0x23c3090, n=12,
>> rnorm=5.3617149831259514e-08, reason=0x23c3310, ctx=0x2446210)
>> -real/src/ksp/ksp/interface/iterativ.c:764
>> > > 764           *reason = KSP_CONVERGED_RTOL;
>> > > and
>> > > Old value = KSP_CONVERGED_RTOL
>> > > New value = KSP_CONVERGED_ITERATING
>> > > KSPSetUp (ksp=0x23c3090) at /depot/ncn/apps/conte/conte-gc
>> c-petsc35-dbg/libs/petsc/build-real/src/ksp/ksp/interface/itfunc.c:226
>> > > 226       if (!((PetscObject)ksp)->type_name) {
>> > > However, after iteration 6, it changed to KSP_CONVERGED_STEP_LENGTH
>> > > New value = KSP_CONVERGED_STEP_LENGTH
>> > > SNES_TR_KSPConverged_Private (ksp=0x23c3090, n=1,
>> rnorm=0.097733468578376406, reason=0x23c3310, cctx=0x1d8f3e0)
>> -real/src/snes/impls/tr/tr.c:36
>> > > 36        PetscFunctionReturn(0);
>> > > Any ideas why that function was executed? Backtrace when the program
>> stopped here:
>> > > #0  SNES_TR_KSPConverged_Private (ksp=0x23c3090, n=1,
>> > > #1  0x00002b14305d3fda in KSPGMRESCycle (itcount=0x7ffdcf2d4ffc,
>> ksp=0x23c3090)
>> -real/src/ksp/ksp/impls/gmres/gmres.c:182
>> > > #2  0x00002b14305d4711 in KSPSolve_GMRES (ksp=0x23c3090) at
>> -real/src/ksp/ksp/impls/gmres/gmres.c:235
>> > > #3  0x00002b1430526a8a in KSPSolve (ksp=0x23c3090, b=0x1a916c0,
>> x=0x1d89dc0)
>> -real/src/ksp/ksp/interface/itfunc.c:460
>> > > #4  0x00002b1430bb3905 in SNESSolve_NEWTONTR (snes=0x1ea2490) at
>> -real/src/snes/impls/tr/tr.c:160
>> > > #5  0x00002b1430655b57 in SNESSolve (snes=0x1ea2490, b=0x0,
>> x=0x1a27420)
>> > > #6  0x00002b142f606780 in libMesh::PetscNonlinearSolver<double>::solve
>> (this=0x1a1d8c0, jac_in=..., x_in=..., r_in=...) at
>> > > #7  0x00002b142f67561d in libMesh::NonlinearImplicitSystem::solve
>> (this=0x1a14fe0) at src/systems/nonlinear_implicit_system.C:183
>> > > #8  0x00002b1429548ceb in NonlinearPoisson::execute_solver
>> (this=0x1110500) at NonlinearPoisson.cpp:1191
>> > > #9  0x00002b142952233c in NonlinearPoisson::do_solve (this=0x1110500)
>> > > #10 0x00002b1429b9e785 in Simulation::solve (this=0x1110500) at
>> Simulation.cpp:781
>> > > #11 0x00002b1429ac326e in Nemo::run_simulations (this=0x63b020) at
>> Nemo.cpp:1313
>> > > #12 0x0000000000426d0d in main (argc=6, argv=0x7ffdcf2d7908) at
>> main.cpp:447
>> > > Thanks!
>> > > Harshad
>> > > On Wed, Sep 14, 2016 at 10:10 AM, Harshad Sahasrabudhe <
>> > > I think I found the problem. I configured PETSc with COPTFLAGS=-O3.
>> I'll remove that option and try again.
>> > > Thanks!
>> > > Harshad
>> > > On Wed, Sep 14, 2016 at 10:06 AM, Harshad Sahasrabudhe <
>> > > Hi Barry,
>> > > Thanks for your inputs. I tried to set a watchpoint on
>> ((_p_KSP*)ksp)->reason, but gdb says no symbol _p_KSP in context.
>> Basically, GDB isn't able to find the PETSc source code. I built PETSc with
>> --with-debugging=1 statically and -fPIC, but it seems the libpetsc.a I get
>> doesn't contain debugging symbols (checked using objdump -g). How do I get
>> PETSc library to have debugging info?
>> > > Thanks,
>> > > Harshad
>> > > On Tue, Sep 13, 2016 at 2:47 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> > > > On Sep 13, 2016, at 1:01 PM, Harshad Sahasrabudhe <
>> > > > Hi Barry,
>> > > > I compiled with mpich configured using --enable-g=meminit to get
>> rid of MPI errors in Valgrind. Doing this reduced the number of errors to
>> 2. I have attached the Valgrind output.
>> > >    This isn't helpful but it seems not to be a memory corruption
>> issue :-(
>> > > > I'm using GAMG+GMRES for in each linear iteration of SNES. The
>> linear solver converges with CONVERGED_RTOL for the first 6 iterations and
>> with CONVERGED_STEP_LENGTH after that. I'm still very confused about why
>> this is happening. Any thoughts/ideas?
>> > >    Does this happen on one process? If so I would run in the debugger
>> and track the variable to see everyplace the variable is changed, this
>> would point to exactly what piece of code is changing the variable to this
>> unexpected value.
>> > >    For example with lldb one can use watch
>> http://lldb.llvm.org/tutorial.html to see each time a variable gets
>> changed. Similar thing with gdb.
>> > >    The variable to watch is ksp->reason  Once you get the hang of
>> this it can take just a few minutes to track down the code that is making
>> this unexpected value, though I understand if you haven't done it before it
>> can be intimidating.
>> > >   Barry
>> > > You can do the same thing in parallel (like on two processes) if you
>> need to but it is more cumbersome since you need run multiple debuggers.
>> You can have PETSc start up multiple debuggers with mpiexec -n 2 ./ex
>> -start_in_debugger
>> > > > Thanks,
>> > > > Harshad
>> > > > On Thu, Sep 8, 2016 at 11:26 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> > > >   Install your MPI with --download-mpich as a PETSc ./configure
>> option, this will eliminate all the MPICH valgrind errors. Then send as an
>> attachment the resulting valgrind file.
>> > > >   I do not 100 % trust any code that produces such valgrind errors.
>> > > >    Barry
>> > > > > On Sep 8, 2016, at 10:12 PM, Harshad Sahasrabudhe <
>> > > > > Hi Barry,
>> > > > > Thanks for the reply. My code is in C. I ran with Valgrind and
>> found many "Conditional jump or move depends on uninitialized value(s)",
>> "Invalid read" and "Use of uninitialized value" errors. I think all of them
>> are from the libraries I'm using (LibMesh, Boost, MPI, etc.). I'm not
>> really sure what I'm looking for in the Valgrind output. At the end of the
>> file, I get:
>> > > > > ==40223== More than 10000000 total errors detected.  I'm not
>> reporting any more.
>> > > > > ==40223== Final error counts will be inaccurate.  Go fix your
>> program!
>> > > > > ==40223== Rerun with --error-limit=no to disable this cutoff.
>> Note
>> > > > > ==40223== that errors may occur in your program without prior
>> warning from
>> > > > > ==40223== Valgrind, because errors are no longer being displayed.
>> > > > > Can you give some suggestions on how I should proceed?
>> > > > > Thanks,
>> > > > > Harshad
>> > > > > On Thu, Sep 8, 2016 at 1:59 PM, Barry Smith <bsmith at mcs.anl.gov>
>> wrote:
>> > > > >    This is very odd. CONVERGED_STEP_LENGTH for KSP is very
>> specialized and should never occur with GMRES.
>> > > > >    Can you run with valgrind to make sure there is no memory
>> corruption? http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>> > > > >    Is your code fortran or C?
>> > > > >    Barry
>> > > > > > On Sep 8, 2016, at 10:38 AM, Harshad Sahasrabudhe <
>> > > > > > Hi,
>> > > > > > I'm using GAMG + GMRES for my Poisson problem. The solver
>> converges with KSP_CONVERGED_STEP_LENGTH at a residual of
>> 9.773346857844e-02, which is much higher than what I need (I need a
>> tolerance of at least 1E-8). I am not able to figure out which tolerance I
>> need to set to avoid convergence due to CONVERGED_STEP_LENGTH.
>> > > > > > Any help is appreciated! Output of -ksp_view and -ksp_monitor:
>> > > > > >     0 KSP Residual norm 3.121347818142e+00
>> > > > > >     1 KSP Residual norm 9.773346857844e-02
>> > > > > >   Linear solve converged due to CONVERGED_STEP_LENGTH
>> iterations 1
>> > > > > > KSP Object: 1 MPI processes
>> > > > > >   type: gmres
>> > > > > >     GMRES: restart=30, using Classical (unmodified)
>> Gram-Schmidt Orthogonalization with no iterative refinement
>> > > > > >     GMRES: happy breakdown tolerance 1e-30
>> > > > > >   maximum iterations=10000, initial guess is zero
>> > > > > >   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000
>> > > > > >   left preconditioning
>> > > > > >   using PRECONDITIONED norm type for convergence test
>> > > > > > PC Object: 1 MPI processes
>> > > > > >   type: gamg
>> > > > > >     MG: type is MULTIPLICATIVE, levels=2 cycles=v
>> > > > > >       Cycles per PCApply=1
>> > > > > >       Using Galerkin computed coarse grid matrices
>> > > > > >   Coarse grid solver -- level -------------------------------
>> > > > > >     KSP Object:    (mg_coarse_)     1 MPI processes
>> > > > > >       type: preonly
>> > > > > >       maximum iterations=1, initial guess is zero
>> > > > > >       tolerances:  relative=1e-05, absolute=1e-50,
>> divergence=10000
>> > > > > >       using NONE norm type for convergence test
>> > > > > >     PC Object:    (mg_coarse_)     1 MPI processes
>> > > > > >       type: bjacobi
>> > > > > >         block Jacobi: number of blocks = 1
>> > > > > >         Local solve is same for all blocks, in the following
>> KSP and PC objects:
>> > > > > >         KSP Object:        (mg_coarse_sub_)         1 MPI
>> processes
>> > > > > >           type: preonly
>> divergence=10000
>> > > > > >         PC Object:        (mg_coarse_sub_)         1 MPI
>> processes
>> > > > > >           type: lu
>> > > > > >             LU: out-of-place factorization
>> > > > > >             tolerance for zero pivot 2.22045e-14
>> > > > > >             using diagonal shift on blocks to prevent zero
>> pivot [INBLOCKS]
>> > > > > >             matrix ordering: nd
>> > > > > >             factor fill ratio given 5, needed 1.91048
>> > > > > >               Factored matrix follows:
>> > > > > >                 Mat Object:                 1 MPI processes
>> > > > > >                   type: seqaij
>> > > > > >                   rows=284, cols=284
>> > > > > >                   package used to perform factorization: petsc
>> > > > > >                   total: nonzeros=7726, allocated nonzeros=7726
>> > > > > >                   total number of mallocs used during
>> MatSetValues calls =0
>> > > > > >                     using I-node routines: found 133 nodes,
>> limit used is 5
>> > > > > >           linear system matrix = precond matrix:
>> > > > > >             type: seqaij
>> > > > > >             rows=284, cols=284
>> > > > > >             total: nonzeros=4044, allocated nonzeros=4044
>> > > > > >             total number of mallocs used during MatSetValues
>> calls =0
>> > > > > >               not using I-node routines
>> > > > > >         type: seqaij
>> > > > > >         rows=284, cols=284
>> > > > > >         total number of mallocs used during MatSetValues calls
>> =0
>> > > > > >   Down solver (pre-smoother) on level 1
>> > > > > >     KSP Object:    (mg_levels_1_)     1 MPI processes
>> > > > > >       type: chebyshev
>> > > > > >         Chebyshev: eigenvalue estimates:  min = 0.195339, max =
>> 4.10212
>> > > > > >       maximum iterations=2
>> divergence=10000
>> > > > > >       using nonzero initial guess
>> > > > > >     PC Object:    (mg_levels_1_)     1 MPI processes
>> > > > > >       type: sor
>> > > > > >         SOR: type = local_symmetric, iterations = 1, local
>> iterations = 1, omega = 1
>> > > > > >       Mat Object:      ()       1 MPI processes
>> > > > > >         type: seqaij
>> > > > > >         rows=9036, cols=9036
>> > > > > >         total: nonzeros=192256, allocated nonzeros=192256
>> =0
>> > > > > >   Up solver (post-smoother) same as down solver (pre-smoother)
>> > > > > >     type: seqaij
>> > > > > >     total number of mallocs used during MatSetValues calls =0
>> > > > > > Thanks,
>> > > > > > Harshad
>> > > > <valgrind.log.33199>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160914/a61392e7/attachment-0001.html>
