[petsc-users] KSP_CONVERGED_STEP_LENGTH
Harshad Sahasrabudhe hsahasra at purdue.edu
Wed Sep 14 09:06:25 CDT 2016
Hi Barry,
Thanks for your inputs. I tried to set a watchpoint on
((_p_KSP*)ksp)->reason, but gdb says no symbol _p_KSP in context.
Basically, GDB isn't able to find the PETSc source code. I built PETSc with
--with-debugging=1 statically and -fPIC, but it seems the libpetsc.a I get
doesn't contain debugging symbols (checked using objdump -g). How do I get
PETSc library to have debugging info?
Harshad
On Tue, Sep 13, 2016 at 2:47 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Sep 13, 2016, at 1:01 PM, Harshad Sahasrabudhe <hsahasra at purdue.edu>
> wrote:
> > Hi Barry,
> > I compiled with mpich configured using --enable-g=meminit to get rid of
> MPI errors in Valgrind. Doing this reduced the number of errors to 2. I
> have attached the Valgrind output.
>    This isn't helpful but it seems not to be a memory corruption issue :-(
> > I'm using GAMG+GMRES for in each linear iteration of SNES. The linear
> solver converges with CONVERGED_RTOL for the first 6 iterations and with
> CONVERGED_STEP_LENGTH after that. I'm still very confused about why this is
> happening. Any thoughts/ideas?
>    Does this happen on one process? If so I would run in the debugger and
> track the variable to see everyplace the variable is changed, this would
> point to exactly what piece of code is changing the variable to this
> unexpected value.
>    For example with lldb one can use watch http://lldb.llvm.org/tutorial.
> html to see each time a variable gets changed. Similar thing with gdb.
>    The variable to watch is ksp->reason  Once you get the hang of this it
> can take just a few minutes to track down the code that is making this
> unexpected value, though I understand if you haven't done it before it can
> be intimidating.
>   Barry
> You can do the same thing in parallel (like on two processes) if you need
> to but it is more cumbersome since you need run multiple debuggers. You can
> have PETSc start up multiple debuggers with mpiexec -n 2 ./ex
> -start_in_debugger
> > Thanks,
> > Harshad
> > On Thu, Sep 8, 2016 at 11:26 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Install your MPI with --download-mpich as a PETSc ./configure option,
> this will eliminate all the MPICH valgrind errors. Then send as an
> attachment the resulting valgrind file.
> >   I do not 100 % trust any code that produces such valgrind errors.
> >    Barry
> > > On Sep 8, 2016, at 10:12 PM, Harshad Sahasrabudhe <hsahasra at purdue.edu>
> wrote:
> > > Hi Barry,
> > > Thanks for the reply. My code is in C. I ran with Valgrind and found
> many "Conditional jump or move depends on uninitialized value(s)", "Invalid
> read" and "Use of uninitialized value" errors. I think all of them are from
> the libraries I'm using (LibMesh, Boost, MPI, etc.). I'm not really sure
> what I'm looking for in the Valgrind output. At the end of the file, I get:
> > > ==40223== More than 10000000 total errors detected.  I'm not reporting
> any more.
> > > ==40223== Final error counts will be inaccurate.  Go fix your program!
> > > ==40223== Rerun with --error-limit=no to disable this cutoff.  Note
> > > ==40223== that errors may occur in your program without prior warning
> from
> > > ==40223== Valgrind, because errors are no longer being displayed.
> > > Can you give some suggestions on how I should proceed?
> > > Thanks,
> > > Harshad
> > > On Thu, Sep 8, 2016 at 1:59 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > >    This is very odd. CONVERGED_STEP_LENGTH for KSP is very specialized
> and should never occur with GMRES.
> > >    Can you run with valgrind to make sure there is no memory
> corruption? http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > >    Is your code fortran or C?
> > >    Barry
> > > > On Sep 8, 2016, at 10:38 AM, Harshad Sahasrabudhe <
> hsahasra at purdue.edu> wrote:
> > > > Hi,
> > > > I'm using GAMG + GMRES for my Poisson problem. The solver converges
> with KSP_CONVERGED_STEP_LENGTH at a residual of 9.773346857844e-02, which
> is much higher than what I need (I need a tolerance of at least 1E-8). I am
> not able to figure out which tolerance I need to set to avoid convergence
> due to CONVERGED_STEP_LENGTH.
> > > > Any help is appreciated! Output of -ksp_view and -ksp_monitor:
> > > >     0 KSP Residual norm 3.121347818142e+00
> > > >     1 KSP Residual norm 9.773346857844e-02
> > > >   Linear solve converged due to CONVERGED_STEP_LENGTH iterations 1
> > > > KSP Object: 1 MPI processes
> > > >   type: gmres
> > > >     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> > > >     GMRES: happy breakdown tolerance 1e-30
> > > >   maximum iterations=10000, initial guess is zero
> > > >   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000
> > > >   left preconditioning
> > > >   using PRECONDITIONED norm type for convergence test
> > > > PC Object: 1 MPI processes
> > > >   type: gamg
> > > >     MG: type is MULTIPLICATIVE, levels=2 cycles=v
> > > >       Cycles per PCApply=1
> > > >       Using Galerkin computed coarse grid matrices
> > > >   Coarse grid solver -- level -------------------------------
> > > >     KSP Object:    (mg_coarse_)     1 MPI processes
> > > >       type: preonly
> > > >       maximum iterations=1, initial guess is zero
> > > >       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
> > > >       using NONE norm type for convergence test
> > > >     PC Object:    (mg_coarse_)     1 MPI processes
> > > >       type: bjacobi
> > > >         block Jacobi: number of blocks = 1
> > > >         Local solve is same for all blocks, in the following KSP and
> PC objects:
> > > >         KSP Object:        (mg_coarse_sub_)         1 MPI processes
> > > >           type: preonly
> divergence=10000
> > > >         PC Object:        (mg_coarse_sub_)         1 MPI processes
> > > >           type: lu
> > > >             LU: out-of-place factorization
> > > >             tolerance for zero pivot 2.22045e-14
> > > >             using diagonal shift on blocks to prevent zero pivot
> [INBLOCKS]
> > > >             matrix ordering: nd
> > > >             factor fill ratio given 5, needed 1.91048
> > > >               Factored matrix follows:
> > > >                 Mat Object:                 1 MPI processes
> > > >                   type: seqaij
> > > >                   rows=284, cols=284
> > > >                   package used to perform factorization: petsc
> > > >                   total: nonzeros=7726, allocated nonzeros=7726
> > > >                   total number of mallocs used during MatSetValues
> calls =0
> > > >                     using I-node routines: found 133 nodes, limit
> used is 5
> > > >           linear system matrix = precond matrix:
> > > >             type: seqaij
> > > >             rows=284, cols=284
> > > >             total: nonzeros=4044, allocated nonzeros=4044
> > > >             total number of mallocs used during MatSetValues calls =0
> > > >               not using I-node routines
> > > >         type: seqaij
> > > >         rows=284, cols=284
> > > >   Down solver (pre-smoother) on level 1
> > > >     KSP Object:    (mg_levels_1_)     1 MPI processes
> > > >       type: chebyshev
> > > >         Chebyshev: eigenvalue estimates:  min = 0.195339, max =
> 4.10212
> > > >       maximum iterations=2
> > > >       using nonzero initial guess
> > > >     PC Object:    (mg_levels_1_)     1 MPI processes
> > > >       type: sor
> > > >         SOR: type = local_symmetric, iterations = 1, local
> iterations = 1, omega = 1
> > > >       Mat Object:      ()       1 MPI processes
> > > >         type: seqaij
> > > >         rows=9036, cols=9036
> > > >         total: nonzeros=192256, allocated nonzeros=192256
> > > >   Up solver (post-smoother) same as down solver (pre-smoother)
> > > >     type: seqaij
> > > > Thanks,
> > > > Harshad
> > <valgrind.log.33199>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160914/506d160f/attachment.html>
