[petsc-users] Question about memory usage in Multigrid preconditioner
Barry Smith
bsmith at mcs.anl.gov
Fri Sep 9 14:38:37 CDT 2016
Why does ksp_view2.txt have two KSP views in it while ksp_view1.txt has only one KSPView in it? Did you run two different solves in the 2 case but not the one?
Barry
> On Sep 9, 2016, at 10:56 AM, frank <hengjiew at uci.edu> wrote:
> Hi,
> I want to continue digging into the memory problem here.
> I did find a work around in the past, which is to use less cores per node so that each core has 8G memory. However this is deficient and expensive. I hope to locate the place that uses the most memory.
> Here is a brief summary of the tests I did in past:
> > Test1: Mesh 1536*128*384 | Process Mesh 48*4*12
> Maximum (over computational time) process memory: total 7.0727e+08
> Current process memory: total 7.0727e+08
> Maximum (over computational time) space PetscMalloc()ed: total 6.3908e+11
> Current space PetscMalloc()ed: total 1.8275e+09
> > Test2: Mesh 1536*128*384 | Process Mesh 96*8*24
> Maximum (over computational time) process memory: total 5.9431e+09
> Current process memory: total 5.9431e+09
> Maximum (over computational time) space PetscMalloc()ed: total 5.3202e+12
> Current space PetscMalloc()ed: total 5.4844e+09
> > Test3: Mesh 3072*256*768 | Process Mesh 96*8*24
> OOM( Out Of Memory ) killer of the supercomputer terminated the job during "KSPSolve".
> I attached the output of ksp_view( the third test's output is from ksp_view_pre ), memory_view and also the petsc options.
> In all the tests, each core can access about 2G memory. In test3, there are 4223139840 non-zeros in the matrix. This will consume about 1.74M, using double precision. Considering some extra memory used to store integer index, 2G memory should still be way enough.
> Is there a way to find out which part of KSPSolve uses the most memory?
> Thank you so much.
> BTW, there are 4 options remains unused and I don't understand why they are omitted:
> -mg_coarse_telescope_mg_coarse_ksp_type value: preonly
> -mg_coarse_telescope_mg_coarse_pc_type value: bjacobi
> -mg_coarse_telescope_mg_levels_ksp_max_it value: 1
> -mg_coarse_telescope_mg_levels_ksp_type value: richardson
> Regards,
> Frank
> On 07/13/2016 05:47 PM, Dave May wrote:
>> On 14 July 2016 at 01:07, frank <hengjiew at uci.edu> wrote:
>> Hi Dave,
>> Sorry for the late reply.
>> Thank you so much for your detailed reply.
>> I have a question about the estimation of the memory usage. There are 4223139840 allocated non-zeros and 18432 MPI processes. Double precision is used. So the memory per process is:
>> 4223139840 * 8bytes / 18432 / 1024 / 1024 = 1.74M ?
>> Did I do sth wrong here? Because this seems too small.
>> No - I totally f***ed it up. You are correct. That'll teach me for fumbling around with my iphone calculator and not using my brain. (Note that to convert to MB just divide by 1e6, not 1024^2 - although I apparently cannot convert between units correctly....)
>> From the PETSc objects associated with the solver, It looks like it _should_ run with 2GB per MPI rank. Sorry for my mistake. Possibilities are: somewhere in your usage of PETSc you've introduced a memory leak; PETSc is doing a huge over allocation (e.g. as per our discussion of MatPtAP); or in your application code there are other objects you have forgotten to log the memory for.
>> I am running this job on Bluewater
>> I am using the 7 points FD stencil in 3D.
>> I thought so on both counts.
>> I apologize that I made a stupid mistake in computing the memory per core. My settings render each core can access only 2G memory on average instead of 8G which I mentioned in previous email. I re-run the job with 8G memory per core on average and there is no "Out Of Memory" error. I would do more test to see if there is still some memory issue.
>> Ok. I'd still like to know where the memory was being used since my estimates were off.
>> Thanks,
>> Dave
>> Regards,
>> Frank
>> On 07/11/2016 01:18 PM, Dave May wrote:
>>> Hi Frank,
>>> On 11 July 2016 at 19:14, frank <hengjiew at uci.edu> wrote:
>>> Hi Dave,
>>> I re-run the test using bjacobi as the preconditioner on the coarse mesh of telescope. The Grid is 3072*256*768 and process mesh is 96*8*24. The petsc option file is attached.
>>> I still got the "Out Of Memory" error. The error occurred before the linear solver finished one step. So I don't have the full info from ksp_view. The info from ksp_view_pre is attached.
>>> Okay - that is essentially useless (sorry)
>>> It seems to me that the error occurred when the decomposition was going to be changed.
>>> Based on what information?
>>> Running with -info would give us more clues, but will create a ton of output.
>>> Please try running the case which failed with -info
>>> I had another test with a grid of 1536*128*384 and the same process mesh as above. There was no error. The ksp_view info is attached for comparison.
>>> Thank you.
>>> [3] Here is my crude estimate of your memory usage.
>>> I'll target the biggest memory hogs only to get an order of magnitude estimate
>>> * The Fine grid operator contains 4223139840 non-zeros --> 1.8 GB per MPI rank assuming double precision.
>>> The indices for the AIJ could amount to another 0.3 GB (assuming 32 bit integers)
>>> * You use 5 levels of coarsening, so the other operators should represent (collectively)
>>> 2.1 / 8 + 2.1/8^2 + 2.1/8^3 + 2.1/8^4 ~ 300 MB per MPI rank on the communicator with 18432 ranks.
>>> The coarse grid should consume ~ 0.5 MB per MPI rank on the communicator with 18432 ranks.
>>> * You use a reduction factor of 64, making the new communicator with 288 MPI ranks.
>>> PCTelescope will first gather a temporary matrix associated with your coarse level operator assuming a comm size of 288 living on the comm with size 18432.
>>> This matrix will require approximately 0.5 * 64 = 32 MB per core on the 288 ranks.
>>> This matrix is then used to form a new MPIAIJ matrix on the subcomm, thus require another 32 MB per rank.
>>> The temporary matrix is now destroyed.
>>> * Because a DMDA is detected, a permutation matrix is assembled.
>>> This requires 2 doubles per point in the DMDA.
>>> Your coarse DMDA contains 92 x 16 x 48 points.
>>> Thus the permutation matrix will require < 1 MB per MPI rank on the sub-comm.
>>> * Lastly, the matrix is permuted. This uses MatPtAP(), but the resulting operator will have the same memory footprint as the unpermuted matrix (32 MB). At any stage in PCTelescope, only 2 operators of size 32 MB are held in memory when the DMDA is provided.
>>> From my rough estimates, the worst case memory foot print for any given core, given your options is approximately
>>> 2100 MB + 300 MB + 32 MB + 32 MB + 1 MB = 2465 MB
>>> This is way below 8 GB.
>>> Note this estimate completely ignores:
>>> (1) the memory required for the restriction operator,
>>> (2) the potential growth in the number of non-zeros per row due to Galerkin coarsening (I wished -ksp_view_pre reported the output from MatView so we could see the number of non-zeros required by the coarse level operators)
>>> (3) all temporary vectors required by the CG solver, and those required by the smoothers.
>>> (4) internal memory allocated by MatPtAP
>>> (5) memory associated with IS's used within PCTelescope
>>> So either I am completely off in my estimates, or you have not carefully estimated the memory usage of your application code. Hopefully others might examine/correct my rough estimates
>>> Since I don't have your code I cannot access the latter.
>>> Since I don't have access to the same machine you are running on, I think we need to take a step back.
>>> [1] What machine are you running on? Send me a URL if its available
>>> [2] What discretization are you using? (I am guessing a scalar 7 point FD stencil)
>>> If it's a 7 point FD stencil, we should be able to examine the memory usage of your solver configuration using a standard, light weight existing PETSc example, run on your machine at the same scale.
>>> This would hopefully enable us to correctly evaluate the actual memory usage required by the solver configuration you are using.
>>> Thanks,
>>> Dave
>>> Frank
>>> On 07/08/2016 10:38 PM, Dave May wrote:
>>>> On Saturday, 9 July 2016, frank <hengjiew at uci.edu> wrote:
>>>> Hi Barry and Dave,
>>>> Thank both of you for the advice.
>>>> @Barry
>>>> I made a mistake in the file names in last email. I attached the correct files this time.
>>>> For all the three tests, 'Telescope' is used as the coarse preconditioner.
>>>> == Test1: Grid: 1536*128*384, Process Mesh: 48*4*12
>>>> Part of the memory usage: Vector 125 124 3971904 0.
>>>> Matrix 101 101 9462372 0
>>>> == Test2: Grid: 1536*128*384, Process Mesh: 96*8*24
>>>> Part of the memory usage: Vector 125 124 681672 0.
>>>> Matrix 101 101 1462180 0.
>>>> In theory, the memory usage in Test1 should be 8 times of Test2. In my case, it is about 6 times.
>>>> == Test3: Grid: 3072*256*768, Process Mesh: 96*8*24. Sub-domain per process: 32*32*32
>>>> Here I get the out of memory error.
>>>> I tried to use -mg_coarse jacobi. In this way, I don't need to set -mg_coarse_ksp_type and -mg_coarse_pc_type explicitly, right?
>>>> The linear solver didn't work in this case. Petsc output some errors.
>>>> @Dave
>>>> In test3, I use only one instance of 'Telescope'. On the coarse mesh of 'Telescope', I used LU as the preconditioner instead of SVD.
>>>> If my set the levels correctly, then on the last coarse mesh of MG where it calls 'Telescope', the sub-domain per process is 2*2*2.
>>>> On the last coarse mesh of 'Telescope', there is only one grid point per process.
>>>> I still got the OOM error. The detailed petsc option file is attached.
>>>> Do you understand the expected memory usage for the particular parallel LU implementation you are using? I don't (seriously). Replace LU with bjacobi and re-run this test. My point about solver debugging is still valid.
>>>> And please send the result of KSPView so we can see what is actually used in the computations
>>>> Thanks
>>>> Dave
>>>> Thank you so much.
>>>> Frank
>>>> On 07/06/2016 02:51 PM, Barry Smith wrote:
>>>> On Jul 6, 2016, at 4:19 PM, frank <hengjiew at uci.edu> wrote:
>>>> Hi Barry,
>>>> Thank you for you advice.
>>>> I tried three test. In the 1st test, the grid is 3072*256*768 and the process mesh is 96*8*24.
>>>> The linear solver is 'cg' the preconditioner is 'mg' and 'telescope' is used as the preconditioner at the coarse mesh.
>>>> The system gives me the "Out of Memory" error before the linear system is completely solved.
>>>> The info from '-ksp_view_pre' is attached. I seems to me that the error occurs when it reaches the coarse mesh.
>>>> The 2nd test uses a grid of 1536*128*384 and process mesh is 96*8*24. The 3rd test uses the same grid but a different process mesh 48*4*12.
>>>> Are you sure this is right? The total matrix and vector memory usage goes from 2nd test
>>>> Vector 384 383 8,193,712 0.
>>>> Matrix 103 103 11,508,688 0.
>>>> to 3rd test
>>>> Vector 384 383 1,590,520 0.
>>>> Matrix 103 103 3,508,664 0.
>>>> that is the memory usage got smaller but if you have only 1/8th the processes and the same grid it should have gotten about 8 times bigger. Did you maybe cut the grid by a factor of 8 also? If so that still doesn't explain it because the memory usage changed by a factor of 5 something for the vectors and 3 something for the matrices.
>>>> The linear solver and petsc options in 2nd and 3rd tests are the same in 1st test. The linear solver works fine in both test.
>>>> I attached the memory usage of the 2nd and 3rd tests. The memory info is from the option '-log_summary'. I tried to use '-momery_info' as you suggested, but in my case petsc treated it as an unused option. It output nothing about the memory. Do I need to add sth to my code so I can use '-memory_info'?
>>>> Sorry, my mistake the option is -memory_view
>>>> Can you run the one case with -memory_view and -mg_coarse jacobi -ksp_max_it 1 (just so it doesn't iterate forever) to see how much memory is used without the telescope? Also run case 2 the same way.
>>>> Barry
>>>> In both tests the memory usage is not large.
>>>> It seems to me that it might be the 'telescope' preconditioner that allocated a lot of memory and caused the error in the 1st test.
>>>> Is there is a way to show how much memory it allocated?
>>>> Frank
>>>> On 07/05/2016 03:37 PM, Barry Smith wrote:
>>>> Frank,
>>>> You can run with -ksp_view_pre to have it "view" the KSP before the solve so hopefully it gets that far.
>>>> Please run the problem that does fit with -memory_info when the problem completes it will show the "high water mark" for PETSc allocated memory and total memory used. We first want to look at these numbers to see if it is using more memory than you expect. You could also run with say half the grid spacing to see how the memory usage scaled with the increase in grid points. Make the runs also with -log_view and send all the output from these options.
>>>> Barry
>>>> On Jul 5, 2016, at 5:23 PM, frank <hengjiew at uci.edu> wrote:
>>>> Hi,
>>>> I am using the CG ksp solver and Multigrid preconditioner to solve a linear system in parallel.
>>>> I chose to use the 'Telescope' as the preconditioner on the coarse mesh for its good performance.
>>>> The petsc options file is attached.
>>>> The domain is a 3d box.
>>>> It works well when the grid is 1536*128*384 and the process mesh is 96*8*24. When I double the size of grid and keep the same process mesh and petsc options, I get an "out of memory" error from the super-cluster I am using.
>>>> Each process has access to at least 8G memory, which should be more than enough for my application. I am sure that all the other parts of my code( except the linear solver ) do not use much memory. So I doubt if there is something wrong with the linear solver.
>>>> The error occurs before the linear system is completely solved so I don't have the info from ksp view. I am not able to re-produce the error with a smaller problem either.
>>>> In addition, I tried to use the block jacobi as the preconditioner with the same grid and same decomposition. The linear solver runs extremely slow but there is no memory error.
>>>> How can I diagnose what exactly cause the error?
>>>> Thank you so much.
>>>> Frank
>>>> <petsc_options.txt>
>>>> <ksp_view_pre.txt><memory_test2.txt><memory_test3.txt><petsc_options.txt>
> <ksp_view1.txt><ksp_view2.txt><ksp_view3.txt><memory1.txt><memory2.txt><petsc_options1.txt><petsc_options2.txt><petsc_options3.txt>
