[petsc-users] Diagnosing a difference between "unpreconditioned" and "true" residual norms
Patrick Sanan
patrick.sanan at gmail.com
Fri Sep 9 09:32:06 CDT 2016
I am debugging a linear solver which uses a custom operator and
preconditioner, via MATSHELL and PCSHELL. Convergence seems to be
fine, except that I unexpectedly see a difference between the
"unpreconditioned" and "true" residual norms when I use
-ksp_monitor_true_residual with a right-preconditioned Krylov method
(FGMRES or right-preconditioned GMRES).
0 KSP unpreconditioned resid norm 9.266794204683e+08 true resid norm
9.266794204683e+08 ||r(i)||/||b|| 1.000000000000e+00
1 KSP unpreconditioned resid norm 2.317801431974e+04 true resid norm
2.317826550333e+04 ||r(i)||/||b|| 2.501217248530e-05
2 KSP unpreconditioned resid norm 4.453270507534e+00 true resid norm
2.699824780158e+01 ||r(i)||/||b|| 2.913439880638e-08
3 KSP unpreconditioned resid norm 1.015490793887e-03 true resid norm
2.658635801018e+01 ||r(i)||/||b|| 2.868991953738e-08
4 KSP unpreconditioned resid norm 4.710220776105e-07 true resid norm
2.658631616810e+01 ||r(i)||/||b|| 2.868987438467e-08
KSP Object:(mgk_) 1 MPI processes
type: fgmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-13, absolute=1e-50, divergence=10000.
right preconditioning
using UNPRECONDITIONED norm type for convergence test
PC Object:(mgk_) 1 MPI processes
type: shell
Shell: Custom PC
linear system matrix = precond matrix:
Mat Object: Custom Operator 1 MPI processes
type: shell
rows=256, cols=256
has attached null space
I have dumped the explicit operator and preconditioned operator, and I
can see that the operator and the preconditioned operator each have a
1-dimensional nullspace (a constant-pressure nullspace) which I have
accounted for by constructing a normalized, constant-pressure vector
and supplying it to the operator via a MatNullSpace.
If I disregard the (numerically) zero singular value, the operator has
a condition number of 1.5669e+05 and the preconditioned operator has a
condition number of 1.01 (strong preconditioner).
Has anyone seen this sort of behavior before and if so, is there a
common culprit that I am overlooking? Any ideas of what to test next
to try to isolate the issue?
As I understand it, the unpreconditioned and true residual norms
should be identical in exact arithmetic, so I would suspect that
somehow I've ended up with a "bad Hessenberg matrix" in some way as I
perform this solve (or maybe I have a more subtle bug).
