[petsc-users] beginner's, technical programming manual?
Tonio Herrmann
tonioherrmann at gmail.com
Wed Sep 7 11:38:51 CDT 2016
Thank you, Matt,
the source codes of DMPlexComputeCellGeometryFVM and your other links seem
to be very helpful. I think they answer most of my questions. I might come
back with a few more detailed questions in 1-2 weeks if that is ok with you.
Thanks
Herrmann
On Wed, Sep 7, 2016 at 4:39 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Sep 5, 2016 at 12:52 PM, Tonio Herrmann <tonioherrmann at gmail.com>
> wrote:
>> Hello,
>> I am new to PETSc, and I am struggling to use it for some numerics
>> problems. The mathematical capabilities are well explained in the manual,
>> in several tutorials and examples.
>> But I am stuck at every tiny step, because I cannot find the required
>> functions for all the very basic technical details, like getting the vertex
>> coordinates of a DMPlex, the face areas and cell volumes (if available
>> through PETSc?). Merging two DMPlexes, that share a common boundary, into
>> one. Extracting a boundary of one DMPlex as a new DMPlex. Etc.
> Hi Hermann,
> There is currently no introduction of the kind you want. Everything I have
> written is geared towards solving PDEs because that
> it what I do with most of my time, and it is what I get the most questions
> about. However, there are some resources:
> a) Papers
> http://arxiv.org/abs/0908.4427
> http://arxiv.org/abs/1506.07749
> http://arxiv.org/abs/1508.02470
> http://arxiv.org/abs/1506.06194
> b) Manpages
> For example, you can get the coordinates of a DM using
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/
> DMGetCoordinates.html
> DMGetCoordinatesLocal.html#DMGetCoordinatesLocal
> or compute things like volumes or face areas,
> DMPlexComputeCellGeometryFVM.html
> or extracting the boundary
> DMPlexCreateSubmesh.html
> c) Examples
> There are a lot of examples, like SNES ex12, ex62, ex77 where we use these
> operations to solve PDEs.
> There is no operation for merging two Plex objects, but it would not be
> hard to write, if you marked the common
> boundary in both using a DMLabel. Plex is intended to be transparent
> enough for users to write new operations
> like these.
> Thanks,
> Matt
> Is there any technical introduction that shows how to deal with the data
>> structures on a basic, geometrical and topological level without
>> necessarily discussing the numerics of PDEs and equation systems?
>> Thank you
>> Hermann
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160907/ccccc835/attachment.html>
