[petsc-users] Coloring of -mat_view draw
    Matthew Knepley
    knepley at gmail.com
    Tue Sep  6 05:21:55 CDT 2016
On Tue, Sep 6, 2016 at 2:50 AM, Justin Chang <jychang48 at gmail.com> wrote:
> Thanks all,
> How do you turn off the zero-filling?
-dm_preallocate_only
   Matt
> Justin
> On Monday, September 5, 2016, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Sep 5, 2016 at 4:31 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
>>> On 5 September 2016 at 10:43, Justin Chang <jychang48 at gmail.com> wrote:
>>>> Hi all,
>>>> So i used the following command-line options to view the non-zero
>>>> structure of my assembled matrix:
>>>> -mat_view draw -draw_pause -1
>>>> And I got an image filled with cyan squares and dots. However, if I
>>>> right-click on the image a couple times, I now get cyan, blue, and red
>>>> squares. What do the different colors mean?
>>> Red represents positive numbers.
>>> Blue represents negative numbers.
>>> I believe cyan represents allocated non-zero entries which were never
>>> populated with entries (explicit zeroes). Someone will correct me if I am
>>> wrong here regarding cyan...
>> When DMMatrix() is called, it first preallocates a matrix, then fills it
>> with zeros and assembles. This is the cyan matrix. Then
>> you fillit with nonzeros. This is the second picture with red and blue.
>> There is an option for turning off the zero filling.
>>   Matt
>>> Thanks,
>>>   Dave
>>>> Attached are the images of the two cases:
>>>> Thanks,
>>>> Justin
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160906/2dff33fb/attachment.html>
