[petsc-users] GAMG
Kong, Fande fande.kong at inl.gov
Mon Oct 31 10:29:38 CDT 2016
On Mon, Oct 31, 2016 at 8:44 AM, Jed Brown <jed at jedbrown.org> wrote:
> Jeremy Theler <jeremy at seamplex.com> writes:
> > Hi again
> > I have been wokring on these issues. Long story short: it is about the
> > ordering of the unknown fields in the vector.
> > Long story:
> > The physics is linear elastic problem, you can see it does work with LU
> > over a simple cube (warp the displacements to see it does represent an
> > elastic problem, E=200e3, nu=0.3):
> > https://caeplex.com/demo/results.php?id=5817146bdb561
> > Say my three displacements (unknowns) are u,v,w. I can define the
> > unknown vector as (is this called node-based ordering?)
> > [u1 v1 w1 u2 v2 w2 ... un vn wn]^T
> > Another option is (is this called unknown-based ordering?)
> > [u1 u2 ... un v1 v2 ... vn w1 w2 ... wn]^T
> > With lu/preonly the results are the same, although the stiffnes matrixes
> > for each case are attached as PNGs. And of course, the near-nullspace
> > vectors are different. So PCSetCoordinates() should work with one
> > ordering and not with another one, an issue I did not take into
> > consideration.
> > After understanding Matt's point about the near nullspace (and reading
> > some interesting comments from Jed on scicomp stackexchange) I did built
> > my own vectors (I had to take a look at MatNullSpaceCreateRigidBody()
> > because I found out by running the code the nullspace should be an
> > orthonormal basis, it should say so in the docs).
> Where?
> "vecs   - the vectors that span the null space (excluding the constant
> vector); these vectors must be orthonormal."
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/
> MatNullSpaceCreate.html
> And if you run in debug mode (default), as you always should until you
> are confident that your code is correct, MatNullSpaceCreate tests that
> your vectors are orthonormal.
> > Now, there are some results I do not understand. I tried these six
> > combinations:
> > order      near-nullspace       iterations    norm
> > unknown    explicit             10            1.6e-6
> > unknown    PCSetCoordinates     15            1.7e-7
> > unknown    none                 15            2.4e-7
> > node       explicit             fails with error -11
> > node       PCSetCoordinates     fails with error -11
> > node       none                 13            3.8e-7
> Did you set a block size for the "node-based" orderings?  Are you sure
> the above is labeled correctly?  Anyway, PCSetCoordinates uses
> "node-based" ordering.  Implementation performance will generally be
> better with node-based ordering -- it has better memory streaming and
> cache behavior.
> The AIJ matrix format will also automatically do an "inode" optimization
> to reduce memory bandwidth and enable block smoothing (default
> configuration uses SOR smoothing).  You can use -mat_no_inode to try
> turning that off.
> > Error -11 is
> > PETSc's linear solver did not converge with reason
> > 'DIVERGED_PCSETUP_FAILED' (-11)
> Isn't there an actual error message?
> > Any explanation (for dumbs)?
> > Another thing to take into account: I am setting the dirichlet BCs with
> > MatZeroRows(), but I am not updating the columns to keep symmetry. Can
> > this pose a problem for GAMG?
> Usually minor, but it is better to maintain symmetry.
If the boundary values are not zero, no way to maintain symmetry unless we
reduce the extra part of  the matrix. Not updating the columns is better in
this situation.
Fande,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161031/73e4f9bf/attachment.html>
