[petsc-users] GAMG
Mark Adams
mfadams at lbl.gov
Fri Oct 28 09:04:11 CDT 2016
GAMG's eigen estimator worked but the values are very high. You have very
low number of equations per processor, is this a thin body? Are the
elements badly stretched?
Do this again with these parameters:
-mg_levels_ksp_type chebyshev
-mg_levels_esteig_ksp_type cg
-mg_levels_esteig_ksp_max_it 10
-mg_levels_ksp_chebyshev_esteig 0,.1,0,1.05
-gamg_est_ksp_type cg
On Fri, Oct 28, 2016 at 9:48 AM, Jeremy Theler <jeremy at seamplex.com> wrote:
> On Fri, 2016-10-28 at 09:46 -0400, Mark Adams wrote:
> > Please run with -info and grep on GAMG.
> [0] PCSetUp_GAMG(): level 0) N=120726, n data rows=3, n data cols=6,
> nnz/row (ave)=41, np=1
> [0] PCGAMGFilterGraph(): 99.904% nnz after filtering, with
> threshold 0., 13.7468 nnz ave. (N=40242)
> [0] PCGAMGCoarsen_AGG(): Square Graph on level 1 of 1 to square
> [0] PCGAMGProlongator_AGG(): New grid 1894 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=5.726852e+00
> min=1.330683e-01 PC=jacobi
> [0] PCSetUp_GAMG(): 1) N=11364, n data cols=6, nnz/row (ave)=196, 1
> active pes
> [0] PCGAMGFilterGraph(): 99.9839% nnz after filtering, with
> threshold 0., 32.7656 nnz ave. (N=1894)
> [0] PCGAMGProlongator_AGG(): New grid 155 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.011119e+01
> min=1.832878e-04 PC=jacobi
> [0] PCSetUp_GAMG(): 2) N=930, n data cols=6, nnz/row (ave)=196, 1 active
> pes
> [0] PCGAMGFilterGraph(): 100.% nnz after filtering, with
> threshold 0., 32.7806 nnz ave. (N=155)
> [0] PCGAMGProlongator_AGG(): New grid 9 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=2.116373e+00
> min=6.337173e-03 PC=jacobi
> [0] PCSetUp_GAMG(): 3) N=54, n data cols=6, nnz/row (ave)=34, 1 active
> pes
> threshold 0., 5.66667 nnz ave. (N=9)
> [0] PCGAMGProlongator_AGG(): New grid 2 nodes
> [0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.984549e+00
> min=8.582767e-03 PC=jacobi
> [0] PCSetUp_GAMG(): 4) N=12, n data cols=6, nnz/row (ave)=12, 1 active
> pes
> [0] PCSetUp_GAMG(): 5 levels, grid complexity = 1.48586
> error: PETSc error 77-0 'Eigen estimator failed: DIVERGED_NANORINF at
> iteration 0'
> in /home/gtheler/libs/petsc-3.7.4/src/ksp/ksp/impls/cheby/cheby.c
> KSPSolve_Chebyshev:440
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161028/83bd61fe/attachment.html>
