[petsc-users] A question about ghost cells
Fri Oct 28 08:08:25 CDT 2016
On Fri, Oct 28, 2016 at 8:05 AM, leejearl <leejearl at 126.com> wrote:
> Hi, Matt:
>     Thank you for your help. It is the answer which I expect.
>     But, I have an another equestion. Can I obtain the coordinates of the
> ghost cells:
I am not sure I understand. By default, Plex stores coordinates only for
vertices. Also, ghost cells
do not have a full complement of vertices because they are only used to
define a state on the other
side of a face. Does that make sense?
  Matt
>     Thanks,
> leejearl
> On 2016年10月28日 19:56, Matthew Knepley wrote:
> On Fri, Oct 28, 2016 at 6:32 AM, leejearl <leejearl at 126.com> wrote:
>> Hi, everyone:
>>     I have a distributed DMPlex representing a 2D finite volume mesh. I
>> distributed it using the function "DMPlexDistribute()".
>> Then, I constructed the ghost cells using "DMPlexConstructGhostCells()".
>>    The question is that I want to determine which cell is ghosted. I
>> obtained all the cells using "DMPlexGetHeightStratum()", and
>> how can I kown which cell is ghosted?
> 1) The ghost cells are marked as "hybrid", so you can call
>   ierr  = DMPlexGetHybridBounds(dm, &cEndInterior, NULL, NULL,
> NULL);CHKERRQ(ierr);
>   ierr  = DMPlexGetHeightStratum(dm, 0, NULL, &cEnd);CHKERRQ(ierr);
> and then the ghost cells are [cEndInterior, cEnd).
> 2) There is also a label "ghost" which marks the ghost faces, and ghost
> cells which are non-local
>   Thanks,
>     Matt
>>    Thanks, all the helps are appreciated.
>> leejearl
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161028/8a5616c1/attachment.html>
