[petsc-users] how to run petsc in MPI mode correct?
Ji Zhang gotofd at gmail.com
Thu Oct 27 03:11:11 CDT 2016
Dear all,
I'm using petsc as a solver for my project. However, the solver in parallel
mode creates much more process then my expectation.
The code using python and petsc4py. The machine have 4 cores.
(a).  If I run it directly, petsc uses only 1 process to assemble the
matrix, and creates 4 process to solve the equations,
(b).  If I use comment 'mpirun -n 4', petsc uses 4 process to assemble the
matrix, but creates 16 process to solve the equations,
I have checked my own python code,, the main component associates with
matrix create is as follow:
m = PETSc.Mat().create(comm=PETSc.COMM_WORLD)
m.setSizes(((None, n_vnode[0]*3), (None, n_fnode[0]*3)))
m.setType('dense')
m.setFromOptions()
m.setUp()
m_start, m_end = m.getOwnershipRange()
for i0 in range(m_start, m_end):
    delta_xi = fnodes - vnodes[i0//3]
    temp1 = delta_xi ** 2
    delta_2 = np.square(delta)  # delta_2 = e^2
    delta_r2 = temp1.sum(axis=1) + delta_2  # delta_r2 = r^2+e^2
    delta_r3 = delta_r2 * np.sqrt(delta_r2)  # delta_r3 = (r^2+e^2)^1.5
    temp2 = (delta_r2 + delta_2) / delta_r3  # temp2 = (r^2+2*e^2)/(r^2+e^2)^1.5
    if i0 % 3 == 0:       # x axis
        m[i0, 0::3] = ( temp2 + np.square(delta_xi[:, 0]) / delta_r3 )
/ (8 * np.pi)  # Mxx
        m[i0, 1::3] = delta_xi[:, 0] * delta_xi[:, 1] / delta_r3 / (8
* np.pi)    # Mxy
        m[i0, 2::3] = delta_xi[:, 0] * delta_xi[:, 2] / delta_r3 / (8
* np.pi)    # Mxz
    elif i0 % 3 == 1:     # y axis
        m[i0, 0::3] = delta_xi[:, 0] * delta_xi[:, 1] / delta_r3 / (8
* np.pi)    # Mxy
        m[i0, 1::3] = ( temp2 + np.square(delta_xi[:, 1]) / delta_r3 )
/ (8 * np.pi)  # Myy
        m[i0, 2::3] = delta_xi[:, 1] * delta_xi[:, 2] / delta_r3 / (8
* np.pi)    # Myz
    else:     # z axis
        m[i0, 0::3] = delta_xi[:, 0] * delta_xi[:, 2] / delta_r3 / (8
* np.pi)    # Mxz
        m[i0, 1::3] = delta_xi[:, 1] * delta_xi[:, 2] / delta_r3 / (8
* np.pi)    # Myz
        m[i0, 2::3] = ( temp2 + np.square(delta_xi[:, 2]) / delta_r3 )
/ (8 * np.pi)  # Mzz
m.assemble()
the main component associates to petsc solver is as follow:
ksp = PETSc.KSP()
ksp.create(comm=PETSc.COMM_WORLD)
ksp.setType(solve_method)
ksp.getPC().setType(precondition_method)
ksp.setOperators(self._M_petsc)
ksp.setFromOptions()
ksp.solve(velocity_petsc, force_petsc)
Is there any one could give me some suggestion? Thanks.
此致
    敬礼
张骥(博士研究生)
北京计算科学研究中心
北京市海淀区西北旺东路10号院东区9号楼 (100193)
Best,
Zhang Ji, PhD student
Beijing Computational Science Research Center
Zhongguancun Software Park II, No. 10 Dongbeiwang West Road, Haidian
District, Beijing 100193, China
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161027/403a8c60/attachment.html>
