[petsc-users] Moving from KSPSetNullSpace to MatSetNullSpace
Matthew Knepley
knepley at gmail.com
Tue Oct 25 18:59:07 CDT 2016
On Tue, Oct 25, 2016 at 6:22 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Oct 25, 2016, at 5:39 PM, Olivier Mesnard <olivier.mesnard8 at gmail.com>
> wrote:
> > On 25 October 2016 at 17:51, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > Olivier,
> > In theory you do not need to change anything else. Are you using a
> different matrix object for the velocity_ksp object than the poisson_ksp
> object?
> > The matrix is different for the velocity_ksp and the poisson_ksp.
> > The code change in PETSc is very little but we have a report from
> another CFD user who also had problems with the change so there may be some
> subtle bug that we can't figure out causing things to not behave properly.
> > First run the 3.7.4 code with -poisson_ksp_view and verify that when
> it prints the matrix information it prints something like has attached null
> space if it does not print that it means that somehow the matrix is not
> properly getting the matrix attached.
> > When running with 3.7.4 and -poisson_ksp_view, the output shows that
> the nullspace is not attached to the KSP (as it was with 3.5.4); however
> the print statement is now under the Mat info (which is expected when
> moving from KSPSetNullSpace to MatSetNullSpace?).
> Good, this is how it should be.
> > Though older versions had MatSetNullSpace() they didn't necessarily
> associate it with the KSP so it was not expected to work as a replacement
> for KSPSetNullSpace() with older versions.
> > Because our other user had great difficulty trying to debug the
> issue feel free to send us at petsc-maint at mcs.anl.gov your code with
> instructions on building and running and we can try to track down the
> problem. Better than hours and hours spent with fruitless email. We will,
> of course, not distribute the code and will delete in when we are finished
> with it.
> > The code is open-source and hosted on GitHub (https://github.com/
> barbagroup/PetIBM).
> > I just pushed the branches `feature-compatible-petsc-3.7` and
> `revert-compatible-petsc-3.5` that I used to observe this problem.
> Thanks, I'll get back to you if I discover anything
Obviously GAMG is behaving quite differently (1 vs 2 levels and a much
sparser coarse problem in 3.7).
Could you try one thing for me before we start running it? Run with
-poisson_mg_coarse_sub_pc_type svd
and see what happens on 2 procs for 3.7?
Matt
> > PETSc (both 3.5.4 and 3.7.4) was configured as follow:
> > export PETSC_ARCH="linux-gnu-dbg"
> > ./configure --PETSC_ARCH=$PETSC_ARCH \
> > --with-cc=gcc \
> > --with-cxx=g++ \
> > --with-fc=gfortran \
> > --COPTFLAGS="-O0" \
> > --CXXOPTFLAGS="-O0" \
> > --FOPTFLAGS="-O0" \
> > --with-debugging=1 \
> > --download-fblaslapack \
> > --download-mpich \
> > --download-hypre \
> > --download-yaml \
> > --with-x=1
> > Our code was built using the following commands:
> > mkdir petibm-build
> > cd petibm-build
> > export PETSC_DIR=<directory of PETSc>
> > export PETIBM_DIR=<directory of PetIBM git repo>
> > $PETIBM_DIR/configure --prefix=$PWD \
> > CXX=$PETSC_DIR/$PETSC_ARCH/bin/mpicxx \
> > CXXFLAGS="-g -O0 -std=c++11"
> > make all
> > make install
> > Then
> > cd examples
> > make examples
> > The example of the lid-driven cavity I was talking about can be found
> in the folder `examples/2d/convergence/lidDrivenCavity20/20/`
> > To run it:
> > mpiexec -n N <path-to-petibm-build>/bin/petibm2d -directory
> <path-to-example>
> > Let me know if you need more info. Thank you.
> > Barry
> > > On Oct 25, 2016, at 4:38 PM, Olivier Mesnard <
> olivier.mesnard8 at gmail.com> wrote:
> > > Hi all,
> > > We develop a CFD code using the PETSc library that solves the
> Navier-Stokes equations using the fractional-step method from Perot (1993).
> > > At each time-step, we solve two systems: one for the velocity field,
> the other, a Poisson system, for the pressure field.
> > > One of our test-cases is a 2D lid-driven cavity flow (Re=100) on a
> 20x20 grid using 1 or 2 procs.
> > > For the Poisson system, we usually use CG preconditioned with GAMG.
> > > So far, we have been using PETSc-3.5.4, and we would like to update
> the code with the latest release: 3.7.4.
> > > As suggested in the changelog of 3.6, we replaced the routine
> `KSPSetNullSpace()` with `MatSetNullSpace()`.
> > > Here is the list of options we use to configure the two solvers:
> > > * Velocity solver: prefix `-velocity_`
> > > -velocity_ksp_type bcgs
> > > -velocity_ksp_rtol 1.0E-08
> > > -velocity_ksp_atol 0.0
> > > -velocity_ksp_max_it 10000
> > > -velocity_pc_type jacobi
> > > -velocity_ksp_view
> > > -velocity_ksp_monitor_true_residual
> > > -velocity_ksp_converged_reason
> > > * Poisson solver: prefix `-poisson_`
> > > -poisson_ksp_type cg
> > > -poisson_ksp_rtol 1.0E-08
> > > -poisson_ksp_atol 0.0
> > > -poisson_ksp_max_it 20000
> > > -poisson_pc_type gamg
> > > -poisson_pc_gamg_type agg
> > > -poisson_pc_gamg_agg_nsmooths 1
> > > -poissonksp_view
> > > -poisson_ksp_monitor_true_residual
> > > -poisson_ksp_converged_reason
> > > With 3.5.4, the case runs normally on 1 or 2 procs.
> > > With 3.7.4, the case runs normally on 1 proc but not on 2.
> > > Why? The Poisson solver diverges because of an indefinite
> preconditioner (only with 2 procs).
> > > We also saw that the routine `MatSetNullSpace()` was already available
> in 3.5.4.
> > > With 3.5.4, replacing `KSPSetNullSpace()` with `MatSetNullSpace()` led
> to the Poisson solver diverging because of an indefinite matrix (on 1 and 2
> procs).
> > > Thus, we were wondering if we needed to update something else for the
> KSP, and not just modifying the name of the routine?
> > > I have attached the output files from the different cases:
> > > * `run-petsc-3.5.4-n1.log` (3.5.4, `KSPSetNullSpace()`, n=1)
> > > * `run-petsc-3.5.4-n2.log`
> > > * `run-petsc-3.5.4-nsp-n1.log` (3.5.4, `MatSetNullSpace()`, n=1)
> > > * `run-petsc-3.5.4-nsp-n2.log`
> > > * `run-petsc-3.7.4-n1.log` (3.7.4, `MatSetNullSpace()`, n=1)
> > > * `run-petsc-3.7.4-n2.log`
> > > Thank you for your help,
> > > Olivier
> > > <run-petsc-3.5.4-n1.log><run-petsc-3.5.4-n2.log><run-petsc-
> 3.5.4-nsp-n1.log><run-petsc-3.5.4-nsp-n2.log><run-petsc-3.7.
> 4-n1.log><run-petsc-3.7.4-n2.log>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161025/b6a697da/attachment-0001.html>
