[petsc-users] Using PETSc solvers and preconditioners with mfem
Matthew Knepley
knepley at gmail.com
Tue Oct 25 12:53:48 CDT 2016
On Tue, Oct 25, 2016 at 12:50 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Tue, Oct 25, 2016 at 12:19 PM, Stefano Zampini <
> stefano.zampini at gmail.com
> >> wrote:
> >> I have a working conversion from HypreParCSR to PETSc MPIAIJ format.
> >> I could add this code to PETSc, maybe in the contrib folder. Barry, what
> >> do you think?
> > No, no one looks there. Add it to src/mat/utils and make an interface
> > function like MatCreateFromHypreParCSR().
> Note that mhyp.c contains code to convert AIJ matrices to ParCSR. If we
> were to create a MatHypreParCSR implementation, we could use those
> functions for MatConvert_{Seq,MPI}AIJ_HypreParCSR and use your function
> for the reverse. That would be consistent with how external matrix
> formats are normally represented and may enable some new capability to
> mix PETSc and Hypre components in the future. Here, I'm envisioning
> PetscErrorCode MatCreateHypreParCSR(hyper_ParCSRMatrix *A,Mat *B);
> This way, if a user chooses -pc_type hypre, there would be no copies for
> going through PETSc. Similarly, if we implement
> MatSetValues_HypreParCSR, a pure PETSc application could use Hypre
> preconditioners with no copies.
This is a better way, but I did not suggest it because it entails the extra
work of implementing
the Mat methods for the new class. If Stefano has time for that, fantastic.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161025/94cd1a5d/attachment-0001.html>
