[petsc-users] SuperLU_dist issue in 3.7.4
Hong
hzhang at mcs.anl.gov
Tue Oct 25 10:38:03 CDT 2016
Anton,
I guess, when you reuse matrix and its symbolic factor with updated
numerical values, superlu_dist requires this option. I'm cc'ing Sherry to
confirm it.
I'll check petsc/superlu-dist interface to set this flag for this case.
Hong
On Tue, Oct 25, 2016 at 8:20 AM, Anton Popov <popov at uni-mainz.de> wrote:
> Hong,
> I get all the problems gone and valgrind-clean output if I specify this:
> -mat_superlu_dist_fact SamePattern_SameRowPerm
> What does SamePattern_SameRowPerm actually mean?
> Row permutations are for large diagonal, column permutations are for
> sparsity, right?
> Will it skip subsequent matrix permutations for large diagonal even if
> matrix values change significantly?
> Surprisingly everything works even with:
> -mat_superlu_dist_colperm PARMETIS
> -mat_superlu_dist_parsymbfact TRUE
> Thanks,
> Anton
> On 10/24/2016 09:06 PM, Hong wrote:
> Anton:
>> If replacing superlu_dist with mumps, does your code work?
>> yes
> You may use mumps in your code, or tests different options for
> superlu_dist:
> -mat_superlu_dist_equil: <TRUE> Equilibrate matrix (None)
> -mat_superlu_dist_rowperm <LargeDiag> Row permutation (choose one of)
> LargeDiag NATURAL (None)
> -mat_superlu_dist_colperm <METIS_AT_PLUS_A> Column permutation (choose
> one of) NATURAL MMD_AT_PLUS_A MMD_ATA METIS_AT_PLUS_A PARMETIS (None)
> -mat_superlu_dist_replacetinypivot: <FALSE> Replace tiny pivots (None)
> -mat_superlu_dist_parsymbfact: <FALSE> Parallel symbolic factorization
> (None)
> -mat_superlu_dist_fact <SamePattern> Sparsity pattern for repeated
> matrix factorization (choose one of) SamePattern SamePattern_SameRowPerm
> (None)
> The options inside <> are defaults. You may try others. This might help
> narrow down the bug.
> Hong
>> Hong
>>> On 10/24/2016 05:47 PM, Hong wrote:
>>> Barry,
>>> Your change indeed fixed the error of his testing code.
>>> As Satish tested, on your branch, ex16 runs smooth.
>>> I do not understand why on maint or master branch, ex16 creases inside
>>> superlu_dist, but not with mumps.
>>> I also confirm that ex16 runs fine with latest fix, but unfortunately
>>> not my code.
>>> This is something to be expected, since my code preallocates once in the
>>> beginning. So there is no way it can be affected by multiple
>>> preallocations. Subsequently I only do matrix assembly, that makes sure
>>> structure doesn't change (set to get error otherwise).
>>> Summary: we don't have a simple test code to debug superlu issue anymore.
>>> Anton
>>> Hong
>>> On Mon, Oct 24, 2016 at 9:34 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>> On Mon, 24 Oct 2016, Barry Smith wrote:
>>>> > > [Or perhaps Hong is using a different test code and is observing
>>>> bugs
>>>> > > with superlu_dist interface..]
>>>> > She states that her test does a NEW MatCreate() for each matrix
>>>> load (I cut and pasted it in the email I just sent). The bug I fixed was
>>>> only related to using the SAME matrix from one MatLoad() in another
>>>> MatLoad().
>>>> Ah - ok.. Sorry - wasn't thinking clearly :(
>>>> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161025/081faeda/attachment.html>
