[petsc-users] SuperLU_dist issue in 3.7.4 failure of repeated calls to MatLoad() or MatMPIAIJSetPreallocation() with the same matrix
Anton Popov popov at uni-mainz.de
Tue Oct 25 07:06:13 CDT 2016
On 10/25/2016 01:58 PM, Anton Popov wrote:
> On 10/24/2016 10:32 PM, Barry Smith wrote:
>>     Valgrind doesn't report any problems?
> Valgrind hangs and never returns (waited hours for a 5 sec run) after
> entering factorization for the second time.
Before it happens it prints this (attached)
Anton
>>> On Oct 24, 2016, at 12:09 PM, Anton Popov <popov at uni-mainz.de> wrote:
>>> On 10/24/2016 05:47 PM, Hong wrote:
>>>> Barry,
>>>> Your change indeed fixed the error of his testing code.
>>>> As Satish tested, on your branch, ex16 runs smooth.
>>>> I do not understand why on maint or master branch, ex16 creases
>>>> inside superlu_dist, but not with mumps.
>>> I also confirm that ex16 runs fine with latest fix, but
>>> unfortunately not my code.
>>> This is something to be expected, since my code preallocates once in
>>> the beginning. So there is no way it can be affected by multiple
>>> preallocations. Subsequently I only do matrix assembly, that makes
>>> sure structure doesn't change (set to get error otherwise).
>>> Summary: we don't have a simple test code to debug superlu issue
>>> anymore.
>>> Anton
>>>> Hong
>>>> On Mon, Oct 24, 2016 at 9:34 AM, Satish Balay <balay at mcs.anl.gov>
>>>> wrote:
>>>> On Mon, 24 Oct 2016, Barry Smith wrote:
>>>>>> [Or perhaps Hong is using a different test code and is observing
>>>>>> bugs
>>>>>> with superlu_dist interface..]
>>>>>     She states that her test does a NEW MatCreate() for each
>>>>> matrix load (I cut and pasted it in the email I just sent). The
>>>>> bug I fixed was only related to using the SAME matrix from one
>>>>> MatLoad() in another MatLoad().
>>>> Ah - ok.. Sorry - wasn't thinking clearly :(
>>>> Satish
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161025/e5f1a7a3/attachment.bin>
