[petsc-users] SuperLU_dist issue in 3.7.4 failure of repeated calls to MatLoad() or MatMPIAIJSetPreallocation() with the same matrix
Hong hzhang at mcs.anl.gov
Mon Oct 24 13:21:44 CDT 2016
 Anton :
If replacing superlu_dist with mumps, does your code work?
Hong
> On 10/24/2016 05:47 PM, Hong wrote:
> Barry,
> Your change indeed fixed the error of his testing code.
> As Satish tested, on your branch, ex16 runs smooth.
> I do not understand why on maint or master branch, ex16 creases inside
> superlu_dist, but not with mumps.
> I also confirm that ex16 runs fine with latest fix, but unfortunately not
> my code.
> This is something to be expected, since my code preallocates once in the
> beginning. So there is no way it can be affected by multiple
> preallocations. Subsequently I only do matrix assembly, that makes sure
> structure doesn't change (set to get error otherwise).
> Summary: we don't have a simple test code to debug superlu issue anymore.
> Anton
> Hong
> On Mon, Oct 24, 2016 at 9:34 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Mon, 24 Oct 2016, Barry Smith wrote:
>> > > [Or perhaps Hong is using a different test code and is observing bugs
>> > > with superlu_dist interface..]
>> >    She states that her test does a NEW MatCreate() for each matrix load
>> (I cut and pasted it in the email I just sent). The bug I fixed was only
>> related to using the SAME matrix from one MatLoad() in another MatLoad().
>> Ah - ok.. Sorry - wasn't thinking clearly :(
>> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161024/cdc484ad/attachment.html>
