[petsc-users] SuperLU_dist issue in 3.7.4 failure of repeated calls to MatLoad() or MatMPIAIJSetPreallocation() with the same matrix
Hong
hzhang at mcs.anl.gov
Mon Oct 24 10:47:47 CDT 2016
Barry,
Your change indeed fixed the error of his testing code.
As Satish tested, on your branch, ex16 runs smooth.
I do not understand why on maint or master branch, ex16 creases inside
superlu_dist, but not with mumps.
Hong
On Mon, Oct 24, 2016 at 9:34 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 24 Oct 2016, Barry Smith wrote:
> > > [Or perhaps Hong is using a different test code and is observing bugs
> > > with superlu_dist interface..]
> > She states that her test does a NEW MatCreate() for each matrix load
> (I cut and pasted it in the email I just sent). The bug I fixed was only
> related to using the SAME matrix from one MatLoad() in another MatLoad().
> Ah - ok.. Sorry - wasn't thinking clearly :(
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161024/22ee9b3f/attachment.html>
