[petsc-users] How to set up an interface-type problem
Safin, Artur aks084000 at utdallas.edu
Thu Oct 20 09:48:46 CDT 2016
Matt,
You use
  http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetLocalSubMatrix.html
  http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetSubVector.html
to put values directly into the subvectors and submatrices. This interacts well with MatNest, so it
can be optimized after you get it working.
Thanks, MatNest and VecNest is what I was looking for.
I have a one more question: if I generate a vector with VecCreateNest, will it be allocated separately, or does it somehow reuse the space from the original subvectors?
Artur
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161020/d3043c58/attachment.html>
