[petsc-users] [mumps-dev] MUMPS and PARMETIS: Crashes
Alfredo Buttari
alfredo.buttari at enseeiht.fr
Thu Oct 20 03:19:55 CDT 2016
Dear all,
this may well be due to a bug in the parallel analysis. Do you think you
can reproduce the problem in a standalone MUMPS program (i.e., without
going through PETSc) ? that would save a lot of time to track the bug since
we do not have a PETSc install at hand. Otherwise we'll give it a shot at
installing petsc and reproducing the problem on our side.
Kind regards,
the MUMPS team
On Wed, Oct 19, 2016 at 8:32 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Tim,
> You can/should also run with valgrind to determine exactly the first
> point with memory corruption issues.
> Barry
> > On Oct 19, 2016, at 11:08 AM, Hong <hzhang at mcs.anl.gov> wrote:
> > Tim:
> > With '-mat_mumps_icntl_28 1', i.e., sequential analysis, I can run ex56
> with np=3 or larger np successfully.
> > With '-mat_mumps_icntl_28 2', i.e., parallel analysis, I can run up to
> np=3.
> > For np=4:
> > mpiexec -n 4 ./ex53 -n 10000 -ksp_view -mat_mumps_icntl_28 2
> -mat_mumps_icntl_29 2 -start_in_debugger
> > code crashes inside mumps:
> > Program received signal SIGSEGV, Segmentation fault.
> > 0x00007f33d75857cb in dmumps_parallel_analysis::dmumps_build_scotch_graph
> > id=..., first=..., last=..., ipe=...,
> > pe=<error reading variable: Cannot access memory at address 0x0>,
> work=...)
> > at dana_aux_par.F:1450
> > 1450 MAPTAB(J) = I
> > (gdb) bt
> > #0 0x00007f33d75857cb in dmumps_parallel_analysis::dmumps_build_scotch_graph
> work=...)
> > #1 0x00007f33d759207c in dmumps_parallel_analysis::dmumps_parmetis_ord
> > id=..., ord=..., work=...) at dana_aux_par.F:400
> > #2 0x00007f33d7592d14 in dmumps_parallel_analysis::dmumps_do_par_ord
> (id=...,
> > ord=..., work=...) at dana_aux_par.F:351
> > #3 0x00007f33d7593aa9 in dmumps_parallel_analysis::dmumps_ana_f_par
> (id=...,
> > work1=..., work2=..., nfsiz=...,
> > fils=<error reading variable: Cannot access memory at address 0x0>,
> > frere=<error reading variable: Cannot access memory at address 0x0>)
> > at dana_aux_par.F:98
> > #4 0x00007f33d74c622a in dmumps_ana_driver (id=...) at dana_driver.F:563
> > #5 0x00007f33d747706b in dmumps (id=...) at dmumps_driver.F:1108
> > #6 0x00007f33d74721b5 in dmumps_f77 (job=1, sym=0, par=1,
> > comm_f77=-2080374779, n=10000, icntl=..., cntl=..., keep=...,
> dkeep=...,
> > keep8=..., nz=0, irn=..., irnhere=0, jcn=..., jcnhere=0, a=...,
> ahere=0,
> > nz_loc=7500, irn_loc=..., irn_lochere=1, jcn_loc=..., jcn_lochere=1,
> > a_loc=..., a_lochere=1, nelt=0, eltptr=..., eltptrhere=0, eltvar=...,
> > eltvarhere=0, a_elt=..., a_elthere=0, perm_in=..., perm_inhere=0,
> rhs=...,
> > rhshere=0, redrhs=..., redrhshere=0, info=..., rinfo=..., infog=...,
> > rinfog=..., deficiency=0, lwk_user=0, size_schur=0,
> listvar_schur=...,
> > ---Type <return> to continue, or q <return> to quit---
> > ar_schurhere=0, schur=..., schurhere=0, wk_user=..., wk_userhere=0,
> colsca=...,
> > colscahere=0, rowsca=..., rowscahere=0, instance_number=1, nrhs=1,
> lrhs=0, lredrhs=0,
> > rhs_sparse=..., rhs_sparsehere=0, sol_loc=..., sol_lochere=0,
> irhs_sparse=...,
> > irhs_sparsehere=0, irhs_ptr=..., irhs_ptrhere=0, isol_loc=...,
> isol_lochere=0,
> > nz_rhs=0, lsol_loc=0, schur_mloc=0, schur_nloc=0, schur_lld=0,
> mblock=0, nblock=0,
> > nprow=0, npcol=0, ooc_tmpdir=..., ooc_prefix=..., write_problem=...,
> tmpdirlen=20,
> > prefixlen=20, write_problemlen=20) at dmumps_f77.F:260
> > #7 0x00007f33d74709b1 in dmumps_c (mumps_par=0x16126f0) at mumps_c.c:415
> > #8 0x00007f33d68408ca in MatLUFactorSymbolic_AIJMUMPS (F=0x1610280,
> A=0x14bafc0,
> > r=0x160cc30, c=0x1609ed0, info=0x15c6708)
> > at /scratch/hzhang/petsc/src/mat/impls/aij/mpi/mumps/mumps.c:1487
> > -mat_mumps_icntl_29 = 0 or 1 give same error.
> > I'm cc'ing this email to mumps developer, who may help to resolve this
> matter.
> > Hong
> > Hi all,
> > I have some problems with PETSc using MUMPS and PARMETIS.
> > In some cases it works fine, but in some others it doesn't, so I am
> > trying to understand what is happening.
> > I just picked the following example:
> > http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/
> examples/tutorials/ex53.c.html
> > Now, when I start it with less than 4 processes it works as expected:
> > mpirun -n 3 ./ex53 -n 10000 -ksp_view -mat_mumps_icntl_28 1
> > But with 4 or more processes, it crashes, but only when I am using
> Parmetis:
> > mpirun -n 4 ./ex53 -n 10000 -ksp_view -mat_mumps_icntl_28 1
> > Metis worked in every case I tried without any problems.
> > I wonder if I am doing something wrong or if this is a general problem
> > or even a bug? Is Parmetis supposed to work with that example with 4
> > processes?
> > Thanks a lot and kind regards.
> > Volker
> > Here is the error log of process 0:
> > Entering DMUMPS 5.0.1 driver with JOB, N = 1 10000
> > MUMPS compiled with option -Dmetis
> > MUMPS compiled with option -Dparmetis
> > L U Solver for unsymmetric matrices
> > Type of parallelism: Working host
> > ****** ANALYSIS STEP ********
> > ** Max-trans not allowed because matrix is distributed
> > Using ParMETIS for parallel ordering.
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > probably memory access out of range
> > [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> > [0]PETSC ERROR: or see
> > http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> > OS X to find memory corruption errors
> > [0]PETSC ERROR: likely location of problem given in stack below
> > [0]PETSC ERROR: --------------------- Stack Frames
> > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > [0]PETSC ERROR: INSTEAD the line number of the start of the
> function
> > [0]PETSC ERROR: is given.
> > [0]PETSC ERROR: [0] MatLUFactorSymbolic_AIJMUMPS line 1395
> > /fsgarwinhpc/133/petsc/sources/petsc-3.7.4a/src/mat/
> > [0]PETSC ERROR: [0] MatLUFactorSymbolic line 2927
> > /fsgarwinhpc/133/petsc/sources/petsc-3.7.4a/src/mat/interface/matrix.c
> > [0]PETSC ERROR: [0] PCSetUp_LU line 101
> > /fsgarwinhpc/133/petsc/sources/petsc-3.7.4a/src/ksp/
> pc/impls/factor/lu/lu.c
> > [0]PETSC ERROR: [0] PCSetUp line 930
> pc/interface/precon.c
> > [0]PETSC ERROR: [0] KSPSetUp line 305
> ksp/interface/itfunc.c
> > [0]PETSC ERROR: [0] KSPSolve line 563
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Signal received
> > [0]PETSC ERROR: See
> > http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> > shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.7.4, Oct, 02, 2016
> > [0]PETSC ERROR: ./ex53 on a linux-manni-mumps named manni by 133 Wed
> > Oct 19 16:39:49 2016
> > [0]PETSC ERROR: Configure options --with-cc=mpiicc --with-cxx=mpiicpc
> > --with-fc=mpiifort --with-shared-libraries=1
> > --with-valgrind-dir=~/usr/valgrind/
> > --with-mpi-dir=/home/software/intel/Intel-2016.4/compilers_
> and_libraries_2016.4.258/linux/mpi
> > --download-scalapack --download-mumps --download-metis
> > --download-metis-shared=0 --download-parmetis
> > --download-parmetis-shared=0
> > [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
> > application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
Alfredo Buttari, PhD
CNRS-IRIT
2 rue Camichel, 31071 Toulouse, France
http://buttari.perso.enseeiht.fr
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161020/fe01fba0/attachment-0001.html>
