[petsc-users] Matrix is missing diagonal entry
Jed Brown jed at jedbrown.org
Tue Oct 18 10:45:41 CDT 2016
"Kong, Fande" <fande.kong at inl.gov> writes:
> Hi Developers,
> Any reason to force users provide a matrix which does not miss any diagonal
> entries when using a LU-type solver?
Automatically adding the entries for incomplete factorization is a
slight increase in complexity and means that "ILU(0)" actually has some
fill.  Note that a literal ILU(0) cannot work if there are missing
diagonal entries.
It's probably not a significant code complexity difference for LU.
> Sometime, it is impossible to have all diagonal entries in a matrix, that
> is, the matrix has to miss some diagonal entries. For example, there is a
> saddle-point matrix from the discretization of incomprehensible equations,
> and the lower part of the matrix is a zero block. The matrix usually looks
> like:
> | A   B^T  |
> | B    0     |
Just insert explicit zeros on the diagonal.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161018/770810cc/attachment.pgp>
