[petsc-users] preconditioner for contact / mesh tying problem
Jed Brown
jed at jedbrown.org
Mon Oct 17 20:49:20 CDT 2016
Hoang Giang Bui <hgbk2008 at gmail.com> writes:
> Dear PETSc folks,
> While searching literature on the preconditioner for contact/mesh tying
> problem, I saw the paper by Dr. Adams "Algebraic multigrid methods for
> constrained linear systems with applications to contact problems in solid
> mechanics, NLAA, 2004". Given the promising aspects the paper has shown for
> constrained linear system, I wonder if some code's also available in PETSc
> for testing/further extension?
This particular algorithm is not available within the PETSc library.
Mark might have some code around, but I doubt it's maintained or easy to
tinker with. You should be able to implement the algorithm fairly
quickly using PETSc. It would make a great example if you're willing to
contribute. And we can advise if you decide to write such an example.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161017/c9b41a66/attachment.pgp>
