[petsc-users] partition of DM Vec entries
Sang pham van
pvsang002 at gmail.com
Sat Oct 15 03:25:20 CDT 2016
Hi Dave,
Thank you very much for the useful examples! I have constant smoothing
length in my problem, so it fits DMSWARM very well, I am happy to be a beta
tester!
Any question while using DSWARM, I will drop into this thread.
Best,
On Sat, Oct 15, 2016 at 12:29 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> On 15 October 2016 at 06:17, Dave May <dave.mayhem23 at gmail.com> wrote:
>> On Saturday, 15 October 2016, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> Unless the particles are more or less equally distributed over the the
>>> entire domain any kind of "domain decomposition" approach is questionably
>>> for managing the particles. Otherwise certain processes that have domains
>>> that contain most of the particles will have a great deal of work, for all
>>> of its particles, while domains with few particles will have little work. I
>>> can see two approaches to alleviate this problem.
>>> 1) constantly adjust the sizes/locations of the domains to load balance
>>> the particles per domain or
>>> 2) parallelize the particles (some how) instead of just the geometry.
>>> Anyways, there is a preliminary DMSWARM class in the development version
>>> of PETSc for helping to work with particles provided by Dave May. You might
>>> look at it. I don't know if it would useful for you or not. IMHO software
>>> library support for particle methods is still very primitive compared to
>>> finite difference/element support, in other words we still have a lot to do.
>> If you are using an SPH formulation with a constant smoothing length
>> (such as for incompressible media), then DMSWARM will be extremely useful.
>> It manages the assignment of fields on point clouds and managed data
>> exchanges required for particle advection and gather operations from
>> neighbor cells required for evaluating the SPH basis functions.
>> DMSWARM is in the master branch. We would be happy if you want to be beta
>> tester. The API is in its infancy and thus having a user play with what's
>> there would be the best way to refine the design as required.
>> Take a look at the examples and let us know if you need help.
> Specifically look at these examples (in the order I've listed)
> * src/dm/examples/tutorials/swarm_ex2.c
> Demonstrates how to create the swarm, register fields within the swarm and
> how to represent these fields as PETSc Vec objects.
> * src/dm/examples/tutorials/swarm_ex3.c
> This demonstrates how you push particles from one sub-domain to another.
> * src/dm/examples/tutorials/swarm_ex1.c
> This demonstrates how to define a collection operation to gather particles
> from neighbour cells (cells being defined via DMDA)
> There isn't a single complete example using a DMSWARM and DMDA for
> everything required by SPH, but all the plumbing is in place.
> Thanks,
> Dave
>> Thanks,
>> Dave
>>> Barry
>>> > On Oct 14, 2016, at 9:54 PM, Sang pham van <pvsang002 at gmail.com>
>>> wrote:
>>> > Hi Barry,
>>> > Thank your for your answer. I am writing a parallel code for
>>> smoothed-particle hydrodynamic, in this code I used a DMDA background mesh
>>> for management of particles. Each DMDA cell manages a number of particles,
>>> the number can change in both time and cell. In each time step, I need to
>>> update position and velocity of particles in border cells to neighbor
>>> partition. I think I can not use DMDA Vec to do this be cause the number of
>>> particles is not the same in all ghost cells.
>>> > I think I am able to write a routine do this work, but the code may be
>>> quite complicated and not so "formal", I would be very appreciated if you
>>> can suggest a method to solve my problem.
>>> > Many thanks.
>>> > On Sat, Oct 15, 2016 at 9:40 AM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>> > Thanks, the question is very clear now.
>>> > For DMDA you can use DMDAGetNeighborsRank() to get the list of the
>>> (up to) 9 neighbors of a processor. (Sadly this routine does not have a
>>> manual page but the arguments are obvious). For other DM I don't think
>>> there is any simple way to get this information. For none of the DM is
>>> there a way to get information about what process is providing a specific
>>> ghost cell.
>>> > It is the "hope" of PETSc (and I would think most parallel computing
>>> models) that the details of exactly what process is computing neighbor
>>> values should not matter for your own computation. Maybe if you provide
>>> more details on how you wish to use this information we may have
>>> suggestions on how to proceed.
>>> > Barry
>>> > > On Oct 14, 2016, at 9:23 PM, Sang pham van <pvsang002 at gmail.com>
>>> wrote:
>>> > > Hi Barry,
>>> > > In 2 processes case, the problem is simple, as I know all ghost
>>> cells of partition 0 are updated from partition 1. However, in the case of
>>> many processes, how do I know from which partitions ghost cells of
>>> partition 0 are updated? In other words, How can I know neighboring
>>> partitions of the partition 0? and can I get a list of ghost cells managing
>>> by a neighboring partition?
>>> > > Please let me know if my question is still not clear.
>>> > > Many thanks.
>>> > > On Sat, Oct 15, 2016 at 8:59 AM, Barry Smith <bsmith at mcs.anl.gov>
>>> wrote:
>>> > > > On Oct 14, 2016, at 8:50 PM, Sang pham van <pvsang002 at gmail.com>
>>> wrote:
>>> > > > Hi,
>>> > > > I am using DM Vec for a FV code, for some reasons, I want to know
>>> partition of all ghost cells of a specific partition. is there a way do
>>> that?
>>> > > Could you please explain in more detail what you want, I don't
>>> understand? Perhaps give a specific example with 2 processes?
>>> > > Barry
>>> > > > Many thanks.
>>> > > > Best,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20161015/1affb886/attachment.html>
